Question about Compaq Computers & Internet
Failing Laptop Cmos battery and need bigger HD
I have an old Compaq 12xl300 Laptop. How do I change the CMOS battery and the hard drive? I have lots of experience in in desktop computer, but not laptops. I am certified A+, NET+ MCSE , and CAlif electronic tech.
  • 144 Answers
As a general rule of thumb , the CMOS battery can be found underneath the keyboard. The keyboard can generally be removed by inserting a screwdriver into the thing gap at each side at the top and then gently lifting the meyboard up. Be careful with the cables connecting the keyboard to the motherboard though!
I cannot find a removal guide for the hard drive. However , look for a slot or cover on the side of the laptop , similar in size to your cd drive. Then turn the laptop up side down and unscrew one of the screws thats somewhere near the slot or cover , remove the cover and slide the drive out, If you can get the cover off but not get the drive to slide out , try unscrewing another screw as most laptops have a few screws holding the cover on and another to release the drive.
Posted on Jan 05, 2009
How to baypass bios password on sumsung np300e5x
You can't bypass BIOS password. All you can do is to RESET BIOS, by removing CMOS battery and waiting some time till it discharges completely.
After you reset BIOS, you shuld enter BIOS at startup and input your setup values, so before doing this, you should check your BIOS setup. See some video tutorials but be careful. Dismounting a Laptop is not a joke. You may end with some parts in a shoebox rushing to your repair service...
How to reset BIOS on laptop
How to remove Hard Drive and CMOS Battery from an HP Compaq 6735b Laptop
Reset Clear CMOS on Laptop and Desktop Tutorial 2015
Tutorial How to replace the CMOS battery in your laptop
Jul 24, 2015 | Computers & Internet
How to reset bios on compaq v2000 laptop
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
Jul 02, 2014 | HP Compaq Presario V2000 Notebook
Gateway cx2610 laptop hd password protected cant locate cmos battery
These WEB sites may help you remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Dec 01, 2012 | Gateway CX2610 Notebook
Why my hp compaq nc6000 laptop failing to boot from cd after selecting multbay
hi ,
go into your cmos or setup for the computer , find boot setup and change it to drive c:\ or hard drive 1 .........good luck Roy
Feb 18, 2012 | HP Compaq nc6000 Notebook
I need instructions on replacing cmos battery? Where is it located on the hp compaq nc 6220 laptop
if you see the motherboard on the laptop, it is a Circle shaped battery which is on the lower right side of the processor normally. To replace CMOS, make sure you turn off the pc, remove the cables the battery, remove the screws at the back, remove the hard drive, remove the optical drive, remove the fan , remove the heat sink, remove the keyboard plate, and then if the motherboard is displayed, remove the CMOS by pushing the eject button right beside the CMOS. Insert it the way you lift the battery in a counter situation. Then placed the parts on the descending manner that I enumerated earlier.
Aug 19, 2010 | HP Computers & Internet
Ide controller for dell inspiron 2500 laptop
Any 20GB disk-drive has built-in drive-electronics,
which interface with the IDE hardware on the motherboard of the laptop -- typically, laptops do *NOT* have "plug-in" adapters for such "basic" functions, unlike desktops, where you can change video/audio/network hardware via add-in cards.
You probably can use any disk-drive that is _smaller_ than 32GB -- disks larger than 32GB require newer motherboards, due to the larger capacity of those disks.
Dec 11, 2009 | Computers & Internet
Have a Compaq CQ50 and don't know the BIOS password....how to i reset it
remove CMOS battery and after 5 minutes install the CMOS battery ,it will crack the bios password,you might be knowing where the CMOS is else i am just guiding you...i am providing you link to the manual that will give you 100% information for you CQ50
MANUAL
click on the link above
thanks and regards
kindly rate this solution
Oct 28, 2009 | HP Compaq Presario CQ50-110US Laptop
Where is the CMOS battery on my Compaq Presario 1210 laptop?
you have to open back side of ur laptop and u can find ur mother board...on that u can see cmos battery...
Dec 11, 2008 | Compaq Presario Notebook
Cant find Cmos command Desktop pro
Have you tried the F1, F2, or Del keys instead of F10?
Nov 23, 2008 | Compaq (166361-001) Motherboard
Computers & Internet Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
