Question about Air Tools & Compressors
Paslode nailer, driver wont come back the full way
I have replaced everything that would normally cause this problem, down to so basically only the body isthe original and trigger system, still wont come back, it will shoot a nail then come back with about a 1/4" still left and the next nail isnt able to get into place.
    President:
  • 1,388 Answers
You didnt mention a model number, however, here are some things to check. With nails removed and air hose disconnected, push the driver up manually with rod. The driver should not be hard to push back into place (Like pushing a cup of coffee with finger). If hard to push, check for oring too tight or bent driver. If easy to push and driver moves when you point nose of gun up then down, oring too loose. If driver seems ok, suspect check-band. Most nailers have a check band around the outside of the cylinder. The band could be an oring or a wide piece of rubber. Under the band are a series of holes. These vent holes need to be clean and the band needs to fit snuggly covering the holes. If band is ok, air is leaking down the nose of the gun when the piston is trying to move up the cylinder. Make a seal out of old bike tube or thin rubber to be placed under the bumper. Cut small hole for the driver to pass thru. This seal will prevent too much air from coming out of nose of gun when air is pushing driver up. If air is not escaping thru nose then suspect obstruction in the head area preventing discharge air to quickly exit the gun allowing the piston to reach top. Good luck
Posted on Nov 07, 2012
  • 1388 Answers
SOURCE: nail gun will not shoot
Not all 120psi air supplies are the same. Here are some differences. The pressure regulator has a great deal of effect on the performance of the air tool. Regulators are sold by the volume of air (cfm)that they can handle. The more cfm the larger the pipe fittings on the regulator. A 1/4 fitting regulator will restrict the air somewhat compared to a 3/8. Another difference is weather moisture is present in the air. Moisture will temporarily help seal the orings, however too much water in gun will cut the orings. The air hose and fittings will also stifle performance. Long small diameter hose will lower pressure at the gun. This can be measured by installing a guage on a T fitting on the end of the hose and watch the pressure as you fire the gun. Larger fittings and hose ID will improve performance. Finally, your nail gun should work on both compressors. To make your nailgun work at home, (assuming that there are no air leaks) lube the headvalve parts with silicone grease. (sold at lowes in plumbing dept) For best performance, replace the orings in the head valve, examine the plastic parts where the orings contact and look for wear and tiny scratches (use magnify lense). Replace these worn parts along with orings. Replace the head gasket and make sure that the body and the head-cap are not warped. Place sheet of fine sandpaper on flat surface, with cylinder removed rub the body of the gun on paper a few times to check for warp. Do same with cap. Parts are available at www.toolpartsdirect.com. Enjoy
Posted on Dec 14, 2008
  • 24 Answers
SOURCE: paslode framing nailer won't shoot
Take 4 bolts off of head . Clean and lube head valve with air nailer oil. Not wd40
Posted on Apr 14, 2009
  • 382 Answers
SOURCE: Hitachi NR83A2 nailer pushes next nail down
Are you using full round head nails?
The hissing indicates your O-rings are worn out and need to be replaced. This is not covered by warrenty and is common for all nail guns. Lots of kits are available on Ebay or your local Hitachi service center should stock them.
Hope this helps,
Cheers
Posted on Jan 22, 2010
rowdy45176
  • 2176 Answers
SOURCE: impulse gun wont fire and fan doesnt run
could be a bent probe not allowing full travel of the safety , fan motor, loose wire, or circuit assembly. If you are handy with tools, remove the battery and fuel cell. remove the 4 screws holding the cover on top of the cylinder assembly and down where the saety is remove the 2 screws there also. gently pull the cylinder off the tool. when you have apart check toe condition of the Oring on the top plate where the fan motor is. Now reinsert the battery and you will see a rocker switch towards the top, depress it and the fan motor should come on. if not try and depress the trigger switch and again the fan motor should come on. If neither start looking for loose or broken wires, if you find none then I would guess the terminal board would be bad. you can also remove the handle halves and look for a loose connection at the board itself, they sometimes wiggled loose where it plugs in. Good luck and let me know.
Posted on Apr 25, 2010
kirkx
  • 2019 Answers
SOURCE: Paslode finish nailer. Pull trigger
Try the other order, where you depress the gun first, and then pull the trigger.
Posted on Mar 12, 2011
I have a cordless paslode impulse finish nailer is missfiring. the battery is fully charged, the gas chamber is full.
Has the tool been striped down and cleaned lately? And are you using genuine paslode gas? If not, do these two fixes first and try again.
Sep 19, 2014 | Omega Paslode 901000 Impulse Cordless...
My paslodes will not fire with a fully charged battery and a new full cell. It only makes a sound like its engaging
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Feb 22, 2011 | RTO PasLode 900420 Impulse Framing Nailer
I have a charged battery, a new gas cartridge and a full sleeve of the correct nails but the nailer does not want to shoot a nail when I press the trigger. What could it be?
heatman101
Feb 08, 2011 | Omega Paslode 901000 Impulse Cordless...
Paslode model 900420. tool will not cycle. with the driver all the way back it will fire once but will not return. reed valves look ok
Check the o-rings on the firing pin...
heatman101
Jan 05, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode impulse finishing gun wont fire. battery fully charged and gas is full.
heatman101
Jan 01, 2011 | Omega Paslode 901000 Impulse Cordless...
Paslode im65 does not fire unless you push push down twice for it to fire. have cleaned it around spark plug ect any ideas much appreciated
heatman101
Dec 12, 2010 | Craftsman Nailer Kit, Palm Air Driver
My paslode impulse framing nailer fires intermitantly. New batt & fuel cell.
heatman101
Oct 23, 2010 | Palmgren 91232 Full Head Framing Nailer
Everything on my nailgun works but there is 1 problem. The gas is not getting to the spark. any solutions. Thanks.
heatman101
Sep 16, 2010 | RTO PasLode 900420 Impulse Framing Nailer
Paslode im 350 just cleaned it now it wont work,the led on the handle slowly blinks red/green
heatman101
Sep 10, 2010 | Craftsman Nailer Kit, Palm Air Driver
Can i use full round head 3-1/2 passlode nail in this nailer
The FC350A uses a 30- to 34-degree collated clipped head nail which is very similar to the Paslode 34-degree round head nail. Paslode's nails are unique because the round head nails collated very close together and the head of the nail is offset to the shaft unlike Porter Cable full round head are further apart and the head is centered on the nail. What does all this mean? The Paslode round head nail may work however the driver will deliver the blow off center to the shaft of the nail, This could cause the nail to bend as it enters hard wood and possibly jamb the gun. You should be able to exchange the nails (with small restock fee) at a major fastener store (not Lowes or etc. ) with out having purchased them at location because the Paslode nails are very popular and with todays economy the store will gain a new customer. If however you would like to try using the nails, try the following. Remove the head of the gun to expose the driver. Install the nails as usual and with **** of small hammer quickly and firmly push driver all the way down the cylinder to see if nail is easily pushed out of bottom of nose. (You can push driver back up with long thin screwdriver or allen) If successful, replace head and connect to air however lower pressure to 40-50 psi and nail into soft wood increassing the pressure little at a time with each test untill full pressure around 90-100psi. Good luck
Jul 19, 2010 | Porter Cable Cable No. FC350A Clipped Head...
Air Tools & Compressors Logo
112 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
