Question about Uniden DECT 6.0 Cordless Phone ID
Change ring from 2 to 5 before going to answeing machine
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Nov 06, 2012
My Uniden Z068 rings twice and then goes to messages. Can I make thhe rings longer?.
Yes. Try this:
1. Press [menu]
2. Scroll down to 'Answ Setup', press [select] or [ok]
3. Scroll down to 'Ring Time', press [select] or [ok]
4. Scroll down to highlight another choice than '2 Rings',
5. Press [back] or [off]
May 08, 2016 | Uniden Lands Phones
How can I change the number of rings before the answering machine picks up
Try this:
1. Press [menu]
2. Scroll down to 'Answ. Setup', press [select] or [ok]
4. Scroll up/down to highlight desired choice of '# Rings',
5. Press [back] or [END]
Dec 04, 2015 | Uniden DECT 6.0 Cordless Phone ID
My att cellphone only rings 4 times before voicemail
If the problem is with an AT&T cellphone you will need to call them or go log in online to change that feature, however if it is with a Uniden Cordless Phone (the product this question is linked to) the directions below found in their manual should help:
From the base
1) Press [clock/menu] three times. The base displays the current number of rings (2, 4, 6, or TS for toll saver) and announces the setting.
2) Press [>>/select] or [<</select] until the desired ring time appears.
3) Press [set]. A confirmation tone sounds, and the answering machine announces the new ring time.
From the handset
1) Press the MENU soft key. Select the ANSW. SETUP menu, and then the RING TIME submenu.
2) Move the cursor to select a Ring Time (2 TIMES, 4 TIMES, 6 TIMES or TOLL SAVER).
3) Press the OK soft key. You will hear a confirmation tone.
Hope this is of help
May 05, 2014 | Uniden Cordless Phone
Change number of rings for answeing machine
Select the model of your Uniden 5.8GHz system from the list beginning at http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=cordlessphones_mnl to download a copy of the manual.
Nov 14, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How to you set number of rings for Uniden 6.0
To set the no. of rings for a Uniden D1680 or similar, try this:
1. Press [menu]
4. Scroll down to highlight your choice, '2 Rings', '4 Rings', etc.
Apr 26, 2012 | Uniden DECT 6.0 Cordless Phone ID
Hi There my uniden 5.8GHz Digital rings only twice before answer machine starts how do i extent the time of ringing? thanks
For the TRU9380, you can set the number of rings for the answering system from the handset. Press Menu/Clear and select Answ Setup. Then choose the Ring Time submenu. Move the cursor to select the number of rings (Toll Saver, 2, 4 or 6 Times). Press Select to save the setting; you will hear a confirmation tone. (Note: the answering machine must be on.) In Toll Saver, it picks up after 2 rings if you have new messages and after 4 rings, otherwise.
You can find the manual for most Uniden 5.8 GHz phones by looking up your model here: http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%205.8%20GHz%20Digital . Check here if you have a different model.
I hope this helps.
Feb 10, 2011 | Uniden Cordless Phone
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
I HAVE A CANNON PIXMA MP830 IAM USING A ANSWER MACHINE ON MY PHONE I HAVE MY CANNON PIXMA ON "ANSWER MACHINE CONNECT" MODE SETTING BUT WHEN A FAX IS SENT TO ME THE PHONE RINGS THE ANWSER MACHINE...
the connection should be phone cord to the fax then to the answering machine. answering machine answers first (rings to answer must be lower than the fax).
Nov 21, 2008 | Cannon Office Equipment & Supplies
How to get the telephone to ring only a few times.
on the 2080 series it is:
press MENU/SELECT button
scroll to ANSW.SETUP
scroll to RING TIME
press MENU/SELECT
scroll to # of rings you want
press MENU/SELECT
remote pin is under ANSW.SETUP --> SECURITY CODE
May 21, 2008 | Uniden DECT 6.0 Cordless Telephone...
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Uniden DECT 6.0 Cordless Phone ID Logo
94 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
