Hi, I am trying to connect my PS3 to my Denon UD-M31 with an optical lead but am not getting any sound.
I have gone to sound settings on PS3 and selected 'Optical Digital' but nothing has happened, any ideas!?
SOURCE: Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Posted on Dec 14, 2007
  • 120 Answers
SOURCE: denon 3801.cant display setup on tv
Hello gerrydav, What might be happenening is the refresh rate for your blu-ray is offsync for your preferred display. You should be able to change it by plugging it into another TV and playing around with the settings. If you have further problems please feel free to post again.
Please post what you do and how you did it. I look forward to your posts.
Posted on Nov 11, 2008
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
SOURCE: sony str bd-930 connected via digital input to ps3,no sound..
on the ps3 in audio options you have to set it so that the sound is going through the optical and not the hdmi. this it was I think the problem is.
Posted on Dec 30, 2008
  • 119 Answers
SOURCE: How do i hook up a PS3 through my denon avr1905?
ONCE YOU CONNECT THE OPTICAL CABLE AT THE DENON, YOU ALSO NEED TO CHECK THE AUDIO SETTING FOR THE INPUT USED AND MAKE SURE OPTICAL IS SELECTED AND LAST ONCE YOU SELECT THE SOURCE INPUT USED TO CONNECT THE PS3 TO THE DENON PRESS THE INPUT MODE BUTTON ON THE FRONT LEFT OF THE DENON UNTIL YOU SEE DISPLAYED THE WORD AUTO, THIS SHOULD GET YOU SOUND AS LOND AS THE PS3 IS OUTPUTING AUDIO OVER THE OPTICAL
Posted on Mar 01, 2009
How do I connect my tv to my UD-M31 - Denon CD Receiver
The receiver must have an optical "IN" port to be able to connect the TV to it.
Dec 07, 2016 | Denon Audio Players & Recorders
Denon ud m31
Get the manual and read it.
Aug 05, 2013 | Audio Players & Recorders
Mar 01, 2009 | Denon AVR-1905 Receiver
Dec 12, 2008 | Denon AVR-2800 Receiver
Denon D-M31. It's had a problem for a while where after a minute or so the volume control on the front works very intermittently. The remote control volume contro; still works fine though. I have heard...
Hi. It's called a rotary encoder.
You might get a replacement from Denon if you have soldering skills or can find a part number in the service manual. I'm unable to access the site just now:
Denon UD M31 Manual Compact Disc Receiver HiFi Engine
Jan 18, 2018 | Denon Audio Players & Recorders
Denon UD-M31. Circuit protect mode permanantly engaged.
Sounds like the output section is fried. See a repair guy.
Jun 02, 2008 | Denon Audio Players & Recorders
Denon UD M31 CD not playing
It is possible that the laser has gone, the part you require is:
Sanyo SF-P101N CD Mechanism - 16 pins (there are 15 pin versions available which have the same product number, the two versions are incompatible)
i have found the part on Ebay (UK) for less than £5, the shop that sells it also suggest replacing the flexible strip that connects that mechanism to the circuit board, the strip costs £2 and replacing it would seem to be a very sensible idea seeing as you have to completely strip the unit to replace the mechanism.
My UD-M31 is in bits on my work bench at present, awaiting the arrival of a new mechanism, i'll post again if replacing it solves the problem.
Jan 01, 2008 | Audio Players & Recorders
Subwoofer
what do i need to connect a subwoofer to my Denon UD-M31
Nov 15, 2007 | Denon D-M31S CD Shelf System
Nov 04, 2007 | Denon AVR-1803 Receiver
209 people viewed this question
 Grubhead
Grubhead
