Question about Frigidaire FRS26R4A Side by Side Refrigerator
Replace freezer bulb FRS26R4A - Frigidaire FRS26R4A Side by Side Refrigerator
  • Official Brand Answer
  • 4,342 Answers
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb on a side-by-side refrigerator you will need to follow the steps below:
1. Unplug refrigerator.
2. Wear gloves as protection against possible broken glass.
3. Remove light cover, if necessary.
4. Unscrew and replace old bulb with an appliance bulb of the same wattage.
5. Replace light cover, if necessary.
6. Remember to plug the refrigerator back in.
Posted on Nov 08, 2012
Not cooling or freezing
Hi Mick, this is AP.
I understand you are experiencing a no cool situation in your Frigidaire refrigerator. On your model, FRS26R4A, specifically the first thing to check it to make sure the refrigerator and freezer controls are not set to "0", turning the Freezer and Fresh Food Controls to "0" turns off the compressor and prevents your refrigerator from cooling, but does not disconnect the power to the light bulb and other electrical components. If you hear the noise coming from the freezer compartment it could be something blocking the evaporator fan which would cause warm temps in the fresh food and freezer section. If the noise is coming from behind the appliance it could be something in the condenser fan or the compressor may be locked up. I would definitely recommend contacting an authorized technician to repair your appliance if you find the temperature controls are not the cause of your high temperatures in the refrigerator. I hope this information helps.
Thanks,
Apr 01, 2014 | Frigidaire FRS26R4A Side by Side...
Frigidaire frs26r4a after opening and closing freezer door all panel lights are on - both cube and crushed ice panel indicators, and the light that illuminates the water and ice dispenser remains on until...
The only thing that I can see that would cause that is a broken freezer door light switch and possibly the power going through the adaptive defrost. Broken or fused to cause the power to come on when the door is closed...Click Here=> FRS26R4A I blieve i can help you with this if you are willing to work and communicate with me, Thanks Sea Breeze
Dec 25, 2010 | Frigidaire FRS26R4A Side by Side...
Frigidaire frs26r4a the freez and fridge stoped cooling found evaporator was cold but fan wasnt working replaced fan still did not work whats keeping the fan from working thanks
Either the defrost timer or the door switch...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | Frigidaire FRS26R4A Side by Side...
Freezer &fridge not cooling w/controls set lowest setting
I just had this problem and it turned out to be the evap fan. Located behind the panel in the freezer. Try spinning by hand and giving it a drop of oil. Replacement costs about $95.
Aug 11, 2009 | Frigidaire FRS26R4A Side by Side...
Ice Build Up in Freezer of FRS26ZSH
I had this problem. You need to clean out the drain under the freezer. The tech that came out used a squeezie bulb similar to what you use for a baby to clean their nose when clogged. You have to remove all the shelf's and the back plate. You need to use warm water to defrost the frozen ice and remove. use water and squeeze into the hole and **** out.. takes 10 minutes.. finally it will drain.. no parts are necessary. good `luck
Jul 23, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer works refrig part does not
You will probably have to completely defrost fridge, overnight. The air duct between the freezer and the fridge is probably frozen.
Jan 18, 2009 | Frigidaire FRS26R4A Side by Side...
FRS26ZXHWO SIDE BY SIDE
Check to see if the freezer side evaporator fan motor is running.
Sep 15, 2008 | Frigidaire FRS26R4A Side by Side...
Fridge / Freezer no longer cooling
 Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
59 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
