Question about Sportsart Exercise & Fitness
Cant find sportsart parts
I have a sportsart 1092f and the fuse blew so i replaced it easy right? no! new fuse blew right away, if i disconnect the motor it powers up fine but with motor on its just going full speed even when safety key removed. the display shows no speed so cant turn it down on there either so im guessing its the motor control board but cant find parts anywhere for this make and model???? please help!!
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
SOURCE: Need Front Control Board, Kenmore Refrigerator Model 106.4410230
Solved it through parts isolation and identification.
Posted on Apr 06, 2009
SOURCE: Jenn Aire Model SVE47600W
Thank you so much for this information. I can verify that this procedure worked (at least for me). I ordered the part from Digi-Key Corp (it was up to a whooping $.28), replaced the old capacitor, plugged everything back in and bam! A working display. There was a beeping and error message but after hitting the Cancel button on the stove, everything was working.
Note that this fixed the dimmed display only. All the other controls were still working--only the display was off. If you have other issues, this might not be a complete solution.
You need basic soldering skills, a small solder iron, a solder ******, and some rosin-core solder. The capacitor is labeled on the circuit board.
When taking the unit off the control panel the largest ribbon cable was clear plastic with embedded contacts. I'd never seen one of these before. The cable's contacts slide in behind the pins on the connector and are held against it by an insert in the connector. When I removed the insert, the clear plastic cable came completely out from the connector. I had thought I'd broken it. But just slide it back in behind the pins, aligning the cable contacts with the pins and put in the connector insert to hold them in place.
The Digi-Key part number for the capacitor is P10292-ND. I ordered 5, just to have a few spares. The 5 caps plus first class postage came to a total of $3.51. Quite a difference from the $160 for the whole unit!
Thanks again to ultigerfan for making this information available.
Posted on May 07, 2009
  • 3 Answers
SOURCE: Need new power/invertor board for Acer AL1711
R1 will be blown, replace it with a 10 ohm resistor. Also replace C6 and C22 with 220uf 25v Capacitors.
Posted on Jun 18, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
Hey Cameron,
I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
P1 Motor Control common
P2 Torque (to Motor Controller) see page 1-11 MAH3000
P3 Motor Control Tach (to control board input)
My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
I keyed in on this note;
The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
Then this note;
Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at dh1200s@yahoo.com. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
With my limited knowledge I will try to help you. Good luck. Rich
Posted on Jun 20, 2009
Testimonial: "Awesome help and advice -- thank you to everyone!"
40 amp. fuse keeps blowing out on 2008 harley
You have a short. Check the insulation on all wiring that carries + voltage - possible that some wire may have lost insulation and is abutting some metal part shorting it out.
Aug 24, 2015 | 2008 Harley Davidson FXCWC Softail Rocker...
How do I replace battery on sportsart C52r recumbent bike?
  • You will have to remove the left and right side covers to expose the inside of the bike, once locating the battery it is resting inside of an open bracket.
  • The removal of the old battery should be easy once you have exposed the inside.
  • Disconnect the positive and negative cables to the battery.
  • The part number for your battery is C52U-34 and it is a 6V battery.
Please be sure to be cautious when removing and installing electrical components.
If you need any further assistance please do not hesitate to call our Tech Support Team or visit us online www.sportsmith.net
Jun 13, 2015 | Exercise & Fitness
If i remove my dash clock can it affect my alternator
yes, and yes, you blew fuses ,
the alterator does use a sense line to dash IGN terminals.
forget that. you failed FSM rule one, disconnect battery neg terminal before doing electrical repairs.
test all fuses, no car, no year, no model stated, so cant show which fuse. 12vdc on boths sides of all fuses, key on, is GOOD.
fuse that look good can be bad.
you shorted out clock wires and blew fuses
easy peasy , prob.
Jan 18, 2015 | Cars & Trucks
Replaced horn fuse and it blew again right away this is a pontiac transport 1997 help
The fuse blows to prevent wire melting and eventual fire! If it blows straight away then there will be a short circuit somewhere in the circuit, which means the electricity is going from the battery positive to the fuse then straight back to the battery negative without any resistance. You would have to follow the wiring and test components until the fuse no longer blows. :)
Jul 01, 2012 | 1997 Pontiac Bonneville
Wiper fuse blows as soon as you insert one
first....be sure the fuse is the right ampage. second...if the ampage is correct, and it still blows, do the following. Disconnect the ground-side of your battery. Attached test lamp to ground-side of battery. Take probe end of test lamp and touch anypart of the motor body frame. If the test lamp (DOES NOT LIGHT UP), you have an electrical short. Recommend OBD (On-board Diagnostic) analysis test.
Apr 25, 2010 | 1998 Subaru Forester
Igniton fuse continuously blows on my 1995-96 dodge neon
Do you have an aftermarket stereo installed? Well, try this. Remove the ground cable from the battery. Install a new fuse. if it continues, Remove the center console. and check the reverse wire connected to the shifter. It did the same thing to me and all it was, was that wire was touching other wires
Jan 11, 2009 | 1995 Dodge Neon
I have an LCD TV and all of a sudden one day when we were watching it it just all of a sudden just turned off an lost all power. the TV was the only thing that turned off. And now will no longer power...
on these plasmas it is way easier to replace the power board then to diagnose and try to find parts, go to shopjimmy.com they will have your board for cheap, and its easy to replace. you should also alway post your model # and type of tv
Sep 10, 2008 | Televison & Video
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Soldered in new fuse, blew it right away...whats a good upgrade?
A new power supply will fix your problem, and when the fuse blows do not replace it. It blows to protect your computer. please replace with a new power supply.
Oct 28, 2007 | Okia / 450-Watt / ATX / 80mm Fan /...
Exercise & Fitness Logo
22 people viewed this question
Top Sportsart Exercise & Fitness Experts
Steven's...
Steven's...
L Pfaff
L Pfaff
Tom Chichester
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
