Question about LG DLE5977 Electric Dryer
WHIRLPOOL DRYER- CLOGGED WITH FLUFF DOWN THE BOTTOM
My dryer has a filter that you remove at the front, from a slot - this is easy and I can de-fluff easily and put back in. But the problem is that there is loads of fluff down the bottom of the slot - so my red light is permanently on, saying check the filter. I have tried to get the hoover down the bottom, a wooden spoon, but nothing seems to work.
I am worried that if the fluff isn't removed that it will start to burn or my dryer will stop working.
  • LG Master
  • 3,463 Answers
Try hooking it out with a long piece of fairly strong wire with a hook on the end.
It won't stop the dryer from working, but if it is vented , remove and clean the vent hose by running water through it, this will remove all traces of fluff, and make sure the outside is clear if it goes through a wall.
Plz rate my solution.
Thanks.
in the hse.
Posted on Jan 05, 2009
Am I suppose to clean the fluff from the inside of my dryer
get a piece of garden hose, about three feet long and tape it to the end of the long rectangular vacuum attachment. remove your filter and insert the hose going back and forth as you go all the way in and out. be sure to hold onto the hose and not the attachment.
Apr 26, 2014 | Whirlpool Dryers
Dryer heats in a 'no heat' selection
it sounds like you have a grounded heat element and the heat will stay on all the time,very easy to check,unplug the dryer,pull the two wires off of the heat element,with a meter touch one lead to the outside metal cover of the heater and the other lead to one of the element,then check the other side of the element the same way,if it shows continuity on one end of the element it's grounded and needs to be replaced with a new heating element.and every year or 18 months you have to clean out the dryer,i use a shop vac and a leaf blower,unplug the dryer,remove the bottom panel,remove the lint filter and the metal duct that the filter slides into,vac up all the lint you can see,brush out the hole where the filter goes and with a long thin screw driver dig out the lint that's in the right and left sides of the plastic slots where the filter slides in,now with the shop vac set it to blow and blow all the lint from the back forwards and blow the motor off and vac up the lint,after you clean out the cabinet go to the back and remove the vent line from the dryer,stick the leaf blower into the vent line and blow it out to the outside,if you do this every year you'll have less problems with the dryer,your clothes will dry on time and you don't have to worry about a dryer fire.
Feb 01, 2014 | Kenmore Elite HE4 Electric Dryer
Dryer was running and hot then just stop working
It may have overheated and tripped the little breaker on the dryer if fitted. If it is fitted there should be a small reset button on the rear of the dryer, once pressed it should work again. Cause of overheating may be caused by filter being clogged with fluff.
Dec 22, 2012 | Whirlpool Washing Machines
Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff .presumably from previous drying task.Is there a fluff filter...
I have the same problem with mine. There isn't a fluff filter that you can get to easily. When the engineer came to fix something else he showed me this big tube thing inside the machine that had the inside coated with fluff. The machine wasn't very old and I only use the dryer for underwear (apparently towels make it much worse). So ... you'll have to get someone to dismantle the machine to get to the fluff. I was wondering if it is covered by the guarantee because it is ruining my washing.
Feb 09, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Hi, i have a homebrand dryer. Model: TD50-89S. Without asking first,my son transferred washing to dryer. Unfortunately, there was alot of white fluff all over washing and he assumed the dryer could take...
Your duct work is probably clogged with the fluff, which will not allow the air to flow though like it should. When that happens, the heat builds up on the cabinet and the heat sensor shuts down the heat. Its an easy fix, it this is the case. Just remove the duct from the dryer, clean it out, clean out the fluff from the dryer duct connection, then go outside and inspect the outside dryer vent for clogs. Make sure the flapper is working on the outside vent as well. Good luck!
Oct 26, 2009 | Whirlpool LER7646E Dryer
Dryer runs no water enters condenser draw, empty water light on.
Remove the filter draw on the bottom left, and wash out under running water to flush out all fluff.
Reach inside opening and clean as much fluff anf gunge as you can from the cavity.
Get a plastic bag tie, reach and feel for a small at the rear of the compartment, and poke hole clear..
If this does not solve the prob, then it is probably a sticking or faulty float valve., or switch.
This involves a complete strip down to access these components.
Thanks.
Jan 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint dryer CTD00
Remove the lint filter at the front bottom left of dryer, and run water through it to clean all the fluff out. Clean the other filter, and make sure the air vents air clear.
Before you replace the bottom filter reach inside the opening and remove any build up of fluff and gunge that you can ,get a plastic bag tie or similar and feel for and poke clear a small hole that is located there.
I f it still does not work, then the element and or stats are probably faulty.
Thanks.
Jan 03, 2009 | Hotpoint Aquarius WD640 Front Load...
Empty water light staying on machine will not work
Probably sticking float switch
Remove lower bottom left filter completely run water thro it to clean all fluff out reach inside and clear any build up of fluff that you can see or feel.
At the back of this aperture is a small hole that gets clogged up,feel for it and poke a plastic bag tie or similar, and poke it clear, if this does not work then it would probably involve a strip down to access the float chamber and switch assy.
Thanks.
Dec 13, 2008 | Hotpoint TDC32 Electric Dryer
LG DLE5977 Electric Dryer Logo
87 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
