Spectroniq tv doesn't turn on, lights off.
YES Outlet works and cord is plugged in. Not even getting lights. Does it need a new fuse or something?.
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Posted on Nov 07, 2012
stradeteox
  • 88 Answers
SOURCE: LG l26lxd1 HDTV
Your power board has gone bad and is not supplying enough power to start up the inverters. The LED lighting at all shows that you do have standby power, but that is all. You will need to have the power board replaced. Hope this helps.
Posted on Jan 08, 2009
  • 33 Answers
SOURCE: no power inside tv outlet is good and fuse is
D10 is shorted. HER304 in middle of Power supply board near large electrolytic cap. Replace with Radio Shack 276-1144 3A 400PIV Diode. PLEASE BE CAREFUL WITH HIGH VOLTAGE PRESENT ON POWER SUPPLY BOARD. UNPLUG POWER CORD!!! OBSERVE PROPER POLARITY WHEN REPLACING DIODE-LOOK WHERE THE BAND IS.
PS- I just fixed the same model this morning.
Posted on Oct 06, 2009
SOURCE: TV won't turn on
Sounds like power supply died. Ours did the same thing a few weeks ago. Unfortunately we have been unable to locate a replacement as Protron (USA) has gone out of business in the Spring of 2009. What a great product...and Shop NBC should be ashamed of hawking this junk.
Posted on Jan 19, 2010
  • 11 Answers
SOURCE: Panasonic flat panel just lost power while on,
Me the same some one please help!!
Posted on Mar 20, 2010
budmrtn
  • 11361 Answers
SOURCE: I plug in my ViewSonic
Service manuals:
http://elektrotanya.com/?q=showresult&megnev=viewsonic&megnev2=n3250&kategoria=tv&kat2=all
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Parts: www.shopjimmy.com
Posted on Nov 19, 2010
Even when using remote still nothing, no lights, could it be in power cord ?
If total dead power cord is possible but rare---someone in that case will need to safely get the back off and follow the cord inside to check the main fuse is goes almost directly to.
Dec 05, 2012 | Spectroniq PLTV3250 32 in. LCD TV
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
My Remington Keratin Therapy Flat Iron Doesn't Turn On.
see thi steps and fix it.God bless you
If the iron doesn't heat, make sure 1) power is on to the outlet, 2) check the electrical cord and 3) check the thermostat and replace if necessary. Use the VOM.
Oct 15, 2012 | Remington Style Therapy: Keratin Therapy...
Hp PSC1210 All-In-One not turning on
HP makes a couple of different power cords for the PSC 1210 and their other printers. First make sure you are using the correct power cord (Amperage and voltage). Unplug the power cord (from the wall and the printer and from a power module if you have one). Leave all of the sections unplugged for at least 15 seconds to reset the power module/printer.
Next connect the power cord to the wall outlet and to the power module if present and check if the LED (if present lights up). If it doesn't try another outlet. In either case, check what the outlet voltage/amperage is at the end of the power cord with a multimeter (before you plug it into the printer). If you have a power module, then check the Amperage (it will be a DC current out).
If you are not getting the correct voltage and amperage out or the LED doesn't light (with a known good outlet), try a different power cord/module.
You can order these from HP.
If you have the correct power at the cord, plug the power cord into the printer and attempt to turn it on. (Press and release the power button.) If the printer still doesn't come on, the unit needs service. Contact HP if the printer is under warranty. Decide if it is worth fixing if it is out of warranty.
I hope this helps.
(I've had to use the HP Repair/Replacement service after a unit was in a home that was hit by lightning. Due to printer availability, an HP gift card was provided to buy a new printer.)
Dec 11, 2011 | HP PSC 1210 All-In-One InkJet Printer
THE T V WILL NOT POWER ON
plug the cord into the outlet. If the wall outlet doesn't work find a different one. If the tv doesn't turn on with the remote take the plastic off of the batteries in the remote. if this all doesn't work, then there's something wrong with the tv and you should return it and get a new one.
May 16, 2011 | Tatung LD30HL Television
The tv was working fine yesterday. but we we tried to turn it on nothing hapened. What can be the problem
could be a bad fuse inside t.v. check outlet where t.v. is plugged in.cord on t.v. could be bad.
Oct 11, 2010 | Spectroniq Protron PLTV-32 32 in. Plasma...
My tv turned off last night. No red or green light.
Check ur power source?Yes,than unplug,replug tv about an hour later.The tv,will reset it self back to factory setting.Tv should work now,not than the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 04, 2010 | Spectroniq PLTV-42HW68 42 in. LCD TV
What to do when the tv is not getting any power
Check the power source,like the wall outlet?Yes,take the tv aparts,where the board that the a/c power cord plug into it.That the power supply board.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jun 20, 2010 | Spectroniq PLTV3250 32 in. LCD TV
Not even 2 years old and no power
no red light on tv. no power only two year old, need help.
Oct 30, 2008 | Spectroniq Protron PLTV-32 32 in. Plasma...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
