Question about HP Computers & Internet
Line down monitor screen
HP laptop
    Sergeant:
  • 279 Answers
That's a physical LCD issue, not a software one. Nort much you can do but send the LCD in for replacement.
Posted on Jan 05, 2009
Jonsnell electronic do you no about the blue line that comes and go down middle of screen pc
Probably a faulty screen, check by plugging in an external monitor. If the external monitor has no line, your screen needs replacing, if the line is still there and the line is not caused by a windows picture, the GPU is possibly in need of reballing or replacing.
Hope that helps.
Jan 04, 2016 | HP Computers & Internet
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
Line under the screen. cannot be removed from sytem configuration of laptop, video card and windows setup.
Some monitors and laptop displays have a protectice strip between the plastic frame and the screen. After awhile these strip begins to move and it works its way down onto your display. You may want to contact your Manufacturer if the laptop or Monitor is under warranty
Apr 18, 2010 | HP Computers & Internet
I am having problems with my screen on my hp dv5000 notebook. The bottom have of the screen will freeze and only the top part is scrolling down and moving. After a while my screen will start to get lines...
the fault could be from your laptops graphic card.
Connect your laptop to an external monitor, and if the screen still freezes on the external monitor, then the fault is truly from your graphic card.
But if the external monitor displays well, then it means the problem is from your screen inverter.
From which ever angle the fault may be coming from, you need to take the laptop to a repairer to fix the problem for you. I don't think either of the fault is what you can handle.
Take care.
Apr 14, 2010 | HP Pavilion dv5000z Notebook
25mm wide white line down the screen near center
Please make clear that whether it is showing from when you boot your computer to loading desktop then LCD is damaged mean to say its hardware problem so take your notebook to HP service center.
other wise remove VGA drivers and re install. To Check Driver Problem... Attach One Extra Monitor to your laptop and ensure that line is not showing on that monitor.
Mar 21, 2010 | HP Compaq nc8000 Notebook
3 year old HP laptop. First screen with diagonal
Hi:
I am not 100% sure, but you could have a problem with the onboard video on your laptop. If you hook up an external monitor to your laptop, and boot to the external screen, this will tell you if your laptop screen is ok, if the video displays the same on a external monitor. To get to the external display, some laptops require that you toggle to them, such as holding down the function key and hitting F8, but your model may differ.
Nov 10, 2009 | HP Computers & Internet
Black screen with vertical lines through it
Could be faulty graphics chip or faulty screen. If you can hook up external monitor and picture is fine then probably faulty screen. If external monitor shows same problem the faulty graphics chip. Take to repair shop and let them have a look.
Jun 10, 2009 | Compaq Presario M2000 Notebook
Blue vertical line in the middle of my laptop monitor?
Anytime you get lines inside of a laptop monitor, its a problem with the screen itself. You can verify this by hooking up an external monitor to the laptop and switch the output to it and you won't have lines on the external monitor. Get the laptop screen replaced.
Jun 09, 2009 | HP Computers & Internet
Lines on my laptop screen
I have a Toshiba that has done this. Your only option is to have the screen replaced or live with it. You could also hook it up to a desktop monitor when you don't need it to be mobile.
Apr 14, 2009 | HP Computers & Internet
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
