Question about Sony BDP-S300 Blu-Ray Disc Player
ITS REGION 2 I WANT TOO SWITCHE IT TOO REGION 1 ?
SONY 5000ES
  • hutaf70 Jan 06, 2009
    sorrey your anser is a joke you sed you give tecnical support ?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, you would need a special remote, a 7040 All4One remote. With that remote, key sequence are as follows:
Using the 7040 All4One remote
  1. Press DVD
  2. Hold the magic button until the DVD button flashes twice.
  3. Press 0533
  4. Hold the magic button until the DVD button flashes twice.
  5. Press 994
  6. Press Magic Key (don't hold)
  7. Press 1891 (this sets key 1 – the DVD button flashes twice)
  8. Hold the magic button until the DVD button flashes twice.
  9. Press 994
  10. Press Magic Key (don't hold)
  11. Press 2552 (this sets key 2 – the DVD button flashes twice)
  12. Hold the magic button until the DVD button flashes twice.
  13. Press 994
  14. Press Magic Key (don't hold)
  15. Press 0953 (this sets key 3 – the DVD button flashes twice)
  16. Hold the magic button until the DVD button flashes twice.
  17. Press 994
  18. Press Magic Key (don't hold)
  19. Press 2214 (this sets key 4 – the DVD button flashes twice)
  20. Hold the magic button until the DVD button flashes twice. .
  21. Press 994
  22. Press Magic Key (don't hold)
  23. Press 0795 (this sets key 5 – the DVD button flashes twice)
  24. Done - the remote is now programmed and ready to use
Now to make your player region free
  1. use the Sony remote that came with the player to bring it out of standby and wait while HOME is displayed
  2. Make sure there isn't a disc in the machine.
  3. Now on the OneforAll remote press 1, 2, 3, 4, 5 (The blue 24p light on the player will start flashing)
  4. Put the player back into standby with the Sony remote
  5. That’s it, the next time you turn on the player it will be region free for DVD playback
  6. If the blue 24p light doesn’t flash then it hasn’t worked, try a new set of batteries and start a fresh
An alternative is a OneForAll URC 7562.
Good luck and Thank you for using FixYa.
Posted on Jan 05, 2009
    Guru:
  • 859 Answers
Because this is a Sony player you will have to call the Sony Customer Service number associated with your player to have them instruct you on changing your region code. By default today, it should be worldwide. This is form court case law.
Sony co holds the patent on DVD players and as such there are rarely if ever now, region code hack. They will instruct you or do it for you on your request.
  • Glenn Rogers
    Glenn Rogers Jan 07, 2009
    Sorry, but you do own a Sony. Sony is leading the fight against copyright infringement. They make it nearly impossible for a quick trick solution to unlock your region code.
    You will in fact have to call them or go to a Sony Service Center. The courts have clearly spoken out in favor of the consumer on these Region Codes and Sony is under court order to change the Region on your request. That means you have to ask them and they will change it for you. Families in the military face the most problems with this issue and they know to just take it to a Sony Center where ever they move to.
    This is the number for the Sony Blue Ray Disc Player Tech Support: 1-866-909-7669
    You will probably have to be quite firm and insistent and in the end you may not be able to change the region code with out visiting a Sony Service Center.
  • 365 Answers
The region can be changed from the settings.i mean there may be some option to change the regional settings,which may be commonly with some codes.thank you
  • JITHIN ANTONY Jan 19, 2009
    does the problem solved
Change region code for Sony bdp-bx110 DVD player
Does anyone know the region code for sony bdp bx110? Thanks
Mar 22, 2013 | Sony Televison & Video
Tip
Sony DVP-NS725P Region free code.
This region free hack also works for the DVP-NS725P using the original remote control. If the first one fail try the second one, it works like a charm.
Thanks a lot....
SONY DVP-NS300, DVP-NS305, DVP-NS400D, DVP-NS700, DVP-S330, DVP-S335, DVP-S360, DVP-S336, DVP-S525D, DVP-S530D, DVP-S535D, DVP-S536D, DVP-S725D, DVP-S735D
Multi-Region:
Turn On the unit with the remote controller
Wait until "no disc" appears in the unit's display
Press Pause, 3, 1, 4, 1, 5, 9
The word "CODE" should appear in the display
Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
Put the player into Standby mode
Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
Press Audio and Return for auto-switching On
Press Angle and Return for MacroVision On
Press Subtitle and Return for MacroVision Off
on Mar 07, 2010 | Televison & Video
I want to reset my amps 5000es sony reciever you push 2 buttons at the same time and hold them for a minute i dont know witch 2 you push
There's a manual online for a BDP5000ES. Is that what you mean?
http://www.retrevo.com/support/Sony-BDP-S5000ES-DVD-Players-manual/id/23007dj384/t/2/
If not, resets are usually defined in manuals and a simple web search usually finds the manual.
Aug 18, 2011 | Audio Players & Recorders
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
May 15, 2010 | Sony DVP-NS330 DVD Player
I purchased dvds from ebay and they will not play on my dvd player. Is there a way i can unlock or change the region on my Sony DVP-SR200P DVD Player? Please help!!!
Or
Or
I found these codes for all the other DVP-SR series players, yours was not listed but I thought was worth a try.
Apr 14, 2010 | Sony DVP-SR200P DVD Player
Can I make sony NS400D multizone and if not, what does it play...we got it secondhand..ngcosgrove@hotmail.com
on the rear of the player will be a region code plate with a picture of a globe and a number next to it.
Or
Or
Mar 21, 2010 | Sony DVP-NS400D DVD Player
SONY DVP FX720 multi region codes??
The SONY DVP FX720 is region free. SONY is notorious for putting out DVD players that will not play all types of DVDs.
May 08, 2009 | Sony DVP-FX720 Portable DVD Player
Sony DVP-NS400D
try this:
Multi-Region:
• Turn On the unit with the remote controller
• Wait until "no disc" appears in the unit's display
• Press Pause, 3, 1, 4, 1, 5, 9
• The word "CODE" should appear in the display
• Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
• Again, within 5 seconds, press Pause and Power
hope it helps!
Oct 31, 2008 | Sony DVP-NS400D DVD Player
Ps2 region 1
the only way to do that, is if you A) send it back to sony, and let them do it for a huge service charge, and guarantee the work. B) take the drive out, and downlload a software that can crack the region coding.
Apr 14, 2008 | Sony PlayStation 2 (PS2) Console
How to make ps2 region free
you have 2 options to make your PS2 region free.
1:- you buy a bootdisk.
2:- you get a modchip fitted.
By default PS2s are region encoded to use in the set region.
PAL Region 2. N.T.S.C Region 1 et,c.
The disk you need is called Swap-Magic, this allows your console to play backup games, hence region free.
Mike @ compurepair.
Mar 28, 2008 | Sony PlayStation 2 (PS2) Console
Sony BDP-S300 Blu-Ray Disc Player Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
