Question about Dacor Ovens
Dacor Double Oven CPTS227 will not come on after power surge.
After a very close lighting strike our Dacor CPTS227 double oven will not come on. I did some checking on line and tried some of the obvious things like turning the breaker off for 30 minutes, and then turning it back on, but it still will not work.
SOURCE: kitchenaid double oven shut down!
The problem is they overheat because hot air is drawn in by the blower and overheats the outer chamber of the oven where the thermo fuse link is. The one or two fuse links are blown simple replacement but have to remove oven (two person job) remove outer shell and find it (them) in the back of the oven. Also the fuse link wire going into the main processor is probably blown.
Posted on Oct 05, 2007
vest6
  • 196 Answers
SOURCE: Whirpool double oven shutdown during self cleaning operation and now is completely dead and the top oven door will not open.
Too bad someone didn't answer this sooner. Caused be poor air circulation in the unit. There is indeed a thermal fuse used in this unit. This problem has been around for a while and no real solution has been found. The closest "fix" is to remove the fuse, turn it around and only hook it down with the screw that faces the panel. The other screw hole is then bent to a 45 degree upward slant. This give the fuse a little breathing room.
Posted on Jan 26, 2008
SOURCE: bottom oven of dacor double oven
I found the lower circuit breaker had been tripped. That didn't fix the problem but upon further inspection whoever had worked on the unit years ago had dropped a screwdriver that had lodged between the oven wall and the rear casing and shorted out the lower heating element. I removed the screwdriver and oven works fine now. I don't think that will solve the cmmclow problem but maybee the curcuit breaker is tripped.
Posted on Mar 12, 2008
  • 29 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
SOURCE: Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Posted on Nov 20, 2008
I try to set the clock on the oven but pressing the CLOCK touch pad or the TIME-TEMP pad has no affect. It is completely nonresponsive.
It sound like the board is faulty, its quite common after power surges can cause damage to small circuit boards like clocks, I would recommend changing it as the clock will also provide timing for switch on at a set time cook for time as well.
http://dacor.com/Search.aspx?query=ECS227 Epicure Electric
Hope this is helpful
Regards
John
Oct 31, 2014 | Dacor ECS227 Epicure Electric Double Oven
Display panel works, but oven will not come on
I take it the oven will not heat. there is a safety thermo inside the grilles. it can be reset.. turn the power off at the breaker... remove the grille..inside of the door. then look inside the thermo is has two wires going to it and a red button in the middle.. push the red button down it will reset the thermo with a click... replace grille and restore power... hope it helps.. replace grille
Sep 19, 2009 | Dacor Epicure 30" Double Wall Oven,...
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Dacor Double Oven
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
Bottom oven of dacor double oven
Dec 25, 2007 | Dacor ECS230 Epicure Electric Double Oven
Ovens Logo
32 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
Vitaliy Gins
Vitaliy Gins
ashburton
Are you a Dacor Oven Expert? Answer questions, earn points and help others
