Flatron W2361VG can't get out of power saving mode
SOURCE: digital power saving mode
check your monitor power settings.
right click on your desk top then left click on 'properties' in the white box that appears.
this will bring up a 'display properties' box which should have a tab headed 'screen saver' amongst others.
select the screen saver tab.
in this tab there are 2 sections. one to select which screen saver you want to use (and what settings are applied to it), and another section which should be called 'monitor power'.
click the button here which says 'power...' to adjust your power settings.
in the next window there are 4 tabs. select the first tab (power schemes - which should be already selected by default) and you now have 4 options. leave the selected 'power scheme' in the top of the window as it is and just alter the settings for the selected power scheme.
your 4 options are: 'turn off monitor', 'turn off hard disks', 'system standby' and 'system hibernates'  i would recommend setting all of these to 'never', and don't forget to click the 'apply' button after you've done this.
i would also recommend disableing hibernation in the 'hibernate' tab (this is in the same window as the power schemes tab).
once you've adjusted your power settings, don't forget to activate one of your screen savers.  this is only important if you leave the monitor on for a long time with no changes taking place in terms of what is being displayed. if you leave a static image on for hours you will end up with permanent screen burn. (a ghost image that is always there - even when the monitor isn't switched on!).
i don't bother with screen savers personally as i find them annoying, and find it much easier to simply turn the monitor off whenever i'm not going to be using it for the next hour or more.
hope that solved your problem. apologies if it doesn't.
by the way, the tabs etc i described are what i have on my OS (windows XP pro) and may be named differently if you're using a different version of windows.  the 'power options' settings will still be accessible via 'screen saver' tab in desktop properties though.
good luck!
:o)
Posted on Oct 19, 2007
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
rajeish
  • 52 Answers
SOURCE: Power saving mode
Prevent the laptop/desktop monitor from going to power saving mode:
  • Click on Start | Control Panel | Power Options.
  • In the Power Option properties window, click on the Power Schemes Tab
  • Set the Turn off Monitor/ Turn off Hard Disks option when on Power (and also Battery for laptop users) to Never.
  • Now click on the Save as... button and assign a name to this power scheme... Let us call it 'Presentation' and then click on OK.
  • That's it congrats!
  • Posted on Aug 04, 2009
    SOURCE: LG w2361vg sometimes get stuck in DVI Power Saving Mode
    Maybe you can update your video card driver. My wife notebook is connected at times to my DELL17" flat screen and ever so often it cuts off in the middle of something. I update the video driver and reset the monitor to factory settings and it's working like a dream.
    I suggest, you use the menu buttons on the LCD and reset it ot factory settings, and possibly update your video card.
    Posted on Aug 13, 2009
    • 2841 Answers
    SOURCE: after starting, my monitor displays "power saving mode".
    Go into the menu and reset the monitor to factory defaults.
    Posted on Aug 28, 2009
    Stop my lg flatron w2053tq monitor going immediately into power saving mode
    How old is your monitor? You may have some bad capacitors. At any rate, you'll have to take the monitor to a Technician for troubleshooting. Good luck.
    Feb 28, 2015 | LG Flatron W2053TQ
    I can not turn off the sleep mode on my LG Flatron monitor W2361VG-PF
    This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). Open the monitor (snaps apart, no screws) and gently tug on each wire individually. One of them is causing the problem. You can replace the harnesses, try to fix them, or solder new wires directly to the pins.
    Feb 16, 2013 | LG FLATRON W2361V 23 inch LCD Monitor
    Flatron W2353 monitor wont turn on
    LG W2353 dvi power saving mode
    how to fix ?
    Dec 22, 2012 | LG FLATRON W2353V 23 inch LCD Monitor
    I have a LG W2361VG monitor and I can't get it off Power Saving Mode. How do I get it off of that sleep mode? And every time I turn on my computer, I tired moving the mouse or pressing a key on the...
    These are just suggestions, not sure if it will fix your problem (not listed in any order but only do one at a time)
    1. Change BIOS battery (reset BIOS)
    2. Clean out machine (dust, reseat cables, cords etc...)
    3. Try removing the power cord from the monitor, hold the power on button for ten seconds then put the power cord back on
    4. Try reseating the video card.
    Hope this helps.
    Oct 21, 2009 | LG L1915S 19" LCD Monitor
    After starting, my monitor displays "power saving mode".
    Aug 28, 2009 | LG L1915S 19" LCD Monitor
    Power saving mode
  • Aug 04, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
    Analog power saving mode?...
    I have a LG flatron wide keeps saying Analog power saving mode and than powers off how do I reset this?
    May 13, 2009 | LG 22" FLATRON LCD Monitor
    LG Flatron monitor
    Hi...there,
    In power saving mode to preventing further damaged to you monitor. You've got a busted backlight inverter that need to be replaced. Happy Holidays!
    Nov 06, 2008 | LG Flatron L1750S 17" LCD Monitor
    My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
    if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
    Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
    Computers & Internet Logo
    88 people viewed this question
    David Payne
    David Payne
