Question about Kitchen Ranges
Electric fire place stopped working.. Changed fuse twice and it blew straight away...... Any ideas if its fixable, if not I might buy a new one.... Please help
    Master:
  • Kitchen Ranges Master
  • 689 Answers
If a fuse keeps on blowing there is a short,If you can get it apart, Check for burn,t wires, Or other signs of some thing be melted or burn,t.
Posted on Nov 06, 2012
2 Suggested Answers
  • 23 Answers
SOURCE: electrical fault
Might have issues with ignitor, or solenoid for gas
Posted on Dec 08, 2007
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Jun 04, 2015 | GE Microwave Ovens
Fan and element not working
hi not sure if you've had a reply but when my zanussi main oven stopped working i just changed the element (purchased from e bay).
open oven door and the back you will see 4 screws(basically 4 corners) remove these screws and you will see the element, pretty straight forward to remove, obviously fan wont work until you have heat (hopefully fan ok) you can give this a go, cheaper than buying a new oven. i have done this twice. hope this helps.
Mar 10, 2014 | Zanussi ZHQ575 Electric Double Oven
Blowing fuse on ada 8000
you need to look at this ,Very usefull
http://blog.newyorkbrass.com/2010/07/07/what-does-a-neve-1073-and-a-behringer-ada-8000-have-in-common/
Dec 28, 2012 | Behringer Ada8000 Ultragain Pro 8 Ch...
Replaced horn fuse and it blew again right away this is a pontiac transport 1997 help
The fuse blows to prevent wire melting and eventual fire! If it blows straight away then there will be a short circuit somewhere in the circuit, which means the electricity is going from the battery positive to the fuse then straight back to the battery negative without any resistance. You would have to follow the wiring and test components until the fuse no longer blows. :)
Jul 01, 2012 | 1997 Pontiac Bonneville
Wine cooler not working - checked all fuses and found the fuse on the circuit board had blown.Changed that fuse- reconnected and the fuse blew straight away what do I do next?
If the fuse blew immediately..then there is a hard short somewhere in the circuit...if you have an ohmmeter you will need to check the compressor, fan , and whatever type of controller for a short circuit
May 09, 2011 | Refrigerators
1992 Jeep Cherokee climate controls just stopped working
unplug the blower motor, try that, i have seen a direct short in the blower motor cause that. also check the blower moror resistor--again another fault---hope that was helpful
Aug 05, 2009 | 1992 Jeep Cherokee Briarwood
Door locks stopped working
check also the fuse of the door lock.
Apr 15, 2009 | 2000 Volvo S70
Worked well, then blew the fuse.
What you should do next is stop using an extension lead. As you've already discovered, there's a risk of the connection getting wet, which is potentially very dangerous, but this is probably not the main problem. Most extension leads (the normal domestic type) are simply not capable of carrying the current needed to run your pressure washer.
Rather than using an electrical extension, use an extension high-pressure hose and work further away from the machine (which also makes it easier to keep the machine dry).
If this doesn't sort the problem, please post here again and we'll try something else.  Good luck!
Mar 10, 2009 | Karcher K2.26 Electric Power Washer
Electrical fault
Oct 28, 2007 | Belling DB2 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
112 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
