Question about Garden
I have changed my spark plug and checked my fuel lines on my roybi 40cc chain saw and it will start but it will not stay running. where do i go from here
Have you checked for an air filter? It needs oxygen to operate. There mmay be a filter in the gas line and if it's clogged it can't get enough fuel once it starts.
Posted on Nov 06, 2012
  • 15 Answers
SOURCE: I have a Benchmark chain saw - replaced brittle fuel lines
sounds like your clunk has come free from fuel line or it is stuck at top of fuel tank. i would empty tank and see if clunk is free by giving the saw a good shake if you cant here the rattel of the clunk you have found the problem PS clunk is a weight attached to the end of your fuel line in tank it makes the line stay at the bottom of the tank
Posted on Sep 06, 2009
dontbother10
  • 2220 Answers
SOURCE: have craftsman chain saw, runs ok for a few
The plugged vent gets my vote. Loosen the fuel cap when it starts to starve.
All Poulan IPLs (exploded parts list) are here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
Find your model, what little fuel system detail there is can be found on it. HTH
Lou
Posted on Oct 04, 2009
dontbother10
  • 2220 Answers
SOURCE: mcculloch 3516 chain saw, does not always start.
It must have spark, fuel and compression to run. Your task is to figure out which is missing.
Sometimes electrical components quit operating once beyond a certain temperature. Does it always start cold and become tempermental when warm?
IMO most hard start problems on a chainsaw with a good fuel delivery system are flooded.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually first pull)
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) - Don’t pull with choke closed.
  4. Push (open) choke, pull starter until it starts. (usually first pull)
The 3516 is a MTD McCulloch (Chinese). These saws are in a class by themselves. Good Luck
Lou
Posted on Nov 15, 2009
dontbother10
  • 2220 Answers
SOURCE: Homelite XL 103 chain saw 1967 will not start-
Is this your saw?
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/cc8b1cfa0c6e498d88256c28006444b1?OpenDocument
If this grand old lady were mine I would part with a few $(40±) for a tune up and and maybe an additional $20 if carburetor needs rebuild at my friendly neighborhood Stihl dealer. They perform pressure tests most homeowners cannot. An undetected air leak can destroy your saw. She deserves better.
HTH
Lou
Posted on Feb 20, 2010
dontbother10
  • 2220 Answers
SOURCE: 142 chain saw. Starts but will not pick up when
Remove, clean and reinstall the muffler and spark arrestor, if no better the "L" needle may need adjustment.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
Most chainsaws die because they are are run lean. I am going to inject a little Lou theory here. Air leaks and defective fuel delivery systems account for most chainsaw failures. Constant adjustment of needle valves can easily camouflage more serious problems that result in burning up your saw.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
Homelite chain saw csp 3314 will start if i tip petrol in spark plug home but wont stay running
There could be a problem with either the fuel line going to the carb or the impulse line that's connected from the cylinder base that generates the 'pulsing' action that operates the diaphragm fuel pump. Today's alcohol rich gasoline has a tendency to weaken or even rot the rubber lines causing fuel delivery issues.
If you don't use your saw for extended periods, dump the tank empty then start the engine and run the residual gasoline from the line. This will help extend the life of the fuel lines.
Another possibility could be a blocked fuel filter, but that is remote.
Feb 22, 2015 | Homelite 12" Oregon Chain Saw Repl. Chain...
My Ryobi pcn 4040 chain saw does not start, there is spark at the plug but I am not sure how strong the spark should be. The fuel line was removed from the tank, not sure if I have mixed them up. Which...
Not too familier with this macne , however it is very important to get the hoses around the correct way, remember that the primer pulls fuel from the carb and dumps it back to the fuel tank, if you have it the other way round it will just flood all the time and will not start, as long as there is a spark at the plug that is good enought as they work off speed of rotation and will get bigger when it starts.
Apr 17, 2011 | Ryobi Factory Reconditioned 18" 40cc...
I have a Craftsman 2.5 Turbo 18" chainsaw. Yesterday it would start and run briefly and the die. I changed the sparkplug and cleaned the air filter and now the saw will not start. The plug is...
Seeing a lot of fuel line problems due to ethanol. Make sure your fuel lines and primer lines are in tact. If the fuel line has broken, you may also need to clean out the inlet screen in the carburetor which can also become clogged.
Feb 12, 2011 | Craftsman sears 18" Chain Saw Chain (...
Craftsman chainsaw 18" 42cc doesn't start
Remove the spark plug and test for spark. If nothing, try a new plug set to 0.020" gap. If ok, put a small mount of fuel mix in the plug hole and try to start. If you get several pops, then check the fuel filter, air cleaner and muffler for plugging. Check the fuel lines for rot or damage. Make sure to use fresh fuel premix (40:1) using modern synthetic saw oil in it's own can and shake thoroughly just before filling each time. If you got no spark in the first test, expose the flywheel and ignition module. Remove the wire from the module that goes to the ignition switch and check for spark. If still nothing, replace the module using a thin business card for a gap gauge between the module poles and the flywheel magnets. If you did get spark, then investigate the ignition switch and wire for possible grounding. Hope some of this helps!
Jun 24, 2010 | Ryobi Factory Reconditioned 18" 40cc...
My ryobi 40cc chainsaw wont start, spark at plug and sounds like it wants to go but there is no compression. any advice as to what im doing wrong
'No compression' usually means serious mechanical problems with the piston/rings, but if this unit has a compression release, then it may be 'set' which reduces compression considerably until the engine fires. Try putting some fuel mix into the cylinder head spark plug hole and reinstall the plug. If it runs for a few seconds, then look into the fuel delivery system (did the compression increase?). Check that the carburetor is bolted tightly to the engine and the fuel lines are intact. Make sure the choke will close all the way and the throttle opens all the way. Make sure that the primer bulb fills with fuel after several pumps. Assuming that the engine ran properly for the people that 'reconditioned' the saw, this unit should not be giving you problems like this.
Dec 29, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40cc chainsaw
Have you checked for spark? Sounds as though your ignition module has quit.
Remove the plug, connect a jumper wire between the threaded part of the plug and the cooling fins, Switch the ignition on, take it into a dark room and pull the starter. You should see a spark at the tip of the plug. HTH
Lou
Sep 17, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Describe your Husqvarna "Chain Saw -
Remove the spark plug and test for spark. If ok, try some starting fluid in the plug hole, install the plug, and try to start. If it runs a short time, it is not getting fuel. Check fuel lines including inside the tank. Clean or replace the air filter. If this saw is fairly old, the carburetor probably needs a re-kit and cleaning. Does it have good compression? Check the muffler for plugging. Make sure the fuel/oil mix is fresh. Good luck!
Sep 12, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
2 Cycle Gas Trimmer will not start
it is normal to see air bubbles in line when pumping the bulb. to make sure what the problem is, try starting several times, remove spark plug. if dry, yes no fuel, remove the carb. if wet, place plug on engine block and look for blue spark. no spark means you need new plug, plug cord or ignition module
Jul 24, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Saw was running and quit checked gas and oil both are full
Check to see if you are getting spark. If you are getting spark then it is not getting fuel. Try sparying starter fliud in the carb. If is starts then stops. Take the fuel line off to see if something is obstructing the line. Also the fuel filter can be changed.
If you are not getting spark with the spark plu relace the plug. Also to check the spark, remove the plug and put a screw driver in the plug wire and ground the screwdriver. a spark should come off the screwdriver
May 21, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Ryobi 18" petrol chainsaw won't start
my guess is that you have a crack or a hole in one of your fuel lines. this is very common in chainsaws and weed eaters because they are used very little and sit for a long time. try checking this and repair if necessary. let me know if this works.
Mar 08, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
