Question about ASUS P5LD2-VM Motherboard
Boot problem all cause of pc booting.?
    Champion:
  • 254 Answers
If your pc wont boot at all first try to clear you BIOS
your motherboard manual will have the details on the switch location .
you can also clear the cmos by removing the battery on the motherboard.
hope this helped
Posted on Jan 05, 2009
Dell latitude e6400 wont boot has black screen
Restart your computer and then press and hold F8 keys until you get Advanced Options menu screen.Use the arrow key to highlight Safe Mode, and then press Enter, your computer will boot automatically to safe mode.
If you able to start in the safe mode then Scan your computer for viruses. Some viruses can cause a black Screen , especially ones that infect the master boot record (MBR) or boot sector.
- Update drivers for your hardware. black Screens are hardware or driver related so updated drivers could fix the cause of the STOP error.
- Check for registry issues
If it didn't helps you then simply get the system utility program like PC Fresher that will fix windows errors that cause of black screen screen
Sep 16, 2013 | Dell Optiplex 755 Ultra Small Form Factor...
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
Power outage now my e machines el 1200 01h won't boot saying no boot file name revevied?
Try to enter your boot screen, usually by pressing F8 when booting up. Then go to your boot priority list and make sure it is booting from your hard drive. I'm not a fan of e machines, it is very possible that the power surge caused some memory or physical errors.
Apr 11, 2013 | E-Machines eMachines Desktop PC
Why my computer was unable to start
Hi
Does your pc have power or do you mean it has power but it wont boot up, this is a common problem and the cause is the boot up files have gone missing.
If you have the windows disk you can use the repair option to replace the missing boot up files by selecting the boot exe option.
This will replace the missing files so your hard drive can read them and (post) power on self test and boot up.
Cheers
Nov 22, 2012 | Computers & Internet
My system will not boot up.
It means that your computer starts up and freezes before it boots up. Please do the following:-
1. At boot up press F8 and select "Last Good Boot Up" or words to that effect. 2. It will restore to a date when your computer was booting up fine. 3. Try and remember what you installed that caused this problem. Do not install it again. 4. If this does not solve your problem then reinstall Windows.
Apr 15, 2011 | HP Pavilion 6835 PC Desktop
When i turn on my dell it boots and goes to the windows screen but then it returns too the boot screen again what might be the cause
Windows is corrupted. Since you don't have no idea what could have caused it the best solution is to reinstall. If you have files that you cannot lose then before reinstalling boot from a Linux Live-CD and copy them.
Sep 23, 2010 | Dell Dimension 3100 PC Desktop
I had to reboot my Eee PC; however, now a message comes up statting the following: "We apologize for the inconvenience, but Windows did not start successfully. A recent hardware or software change might...
If you added any exta hardware means kindly remove it and boot the computer
Then you try boot by selecting the option of Boot using last known good configuration.
If the boot is successful then you can boot later booting without any problem.
If boot is not successful and this problem is happened after installing any software or driver software means boot in safe mode by pressing f8 key and uninstall it
Mar 12, 2010 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Sep 08, 2009 | E-Machines T6528 PC Desktop
Computer not booting
Do you get anything on the screen at all? Is this a laptop?
Jul 07, 2009 | Dell Inspiron 1420 Notebook
ASUS P5LD2-VM Motherboard Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
