Question about Poulan Weed Eater Electric Blower/Vacuum 12a
Manual for weed eater barracuda 2595? - Poulan Weed Eater Electric Blower/Vacuum 12a
5 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: starter rope on bv2000 weed eater blower needs to be replaced.
Hi, Try the following, But make dure you can wind the spring. If not the spring is broken.
Kurt
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Posted on Mar 23, 2009
bulldogchief
  • 388 Answers
SOURCE: Can't get weed eater started. Have an older weed
This is a common problem on older Poulan models. Press the primer button 10 times and pull the starter rope twice, then pull the spark plug and examine it. If the plug is wet that means gas is definitely getting to the combustion chamber. Next thing is to use a compression tester. If you do not have a compression tester but have an AutoZone anywhere near you, you can get a loaner from them. Screw the compression tester into the plug hole and pull the start rope 4 times. If the tester reads anything below 90psi, you have a bad ring and will have to take the motor apart to clean the piston and ring or replace the ring.
Keep me posted on what you find, ok? I can walk you through the procedure to replace the ring if necessary. Good Luck!
Posted on Sep 17, 2009
Testimonial: "thanks...I will give it a try and keep you posted"
suzukiracing
  • 200 Answers
SOURCE: my weed eater starts but won't stay running. what
Try a new spark plug.Thanks for asking and I hope it helps
Posted on Jul 21, 2010
SOURCE: My poulan gas weed eater won't start. It has gas.
You may want to take it down to access the muffler, remove it and check for carbon build up on the block where the piston is visible. My Poulan leaf blower quit working one day and refused to start, even with a new spark plug and fresh 40:1 mix ratio gas. I decided to take it down completely and discovered my exhaust port was nearly blocked all the way. I removed the carbon, regapped my spark plug to 0.025, and cleaned the magnets on the fly wheel and ignition module. Once put back together, it started up on the third pull and ran like new. Forgot to mention I took apart the carburetor completely and cleaned it.
Posted on Aug 25, 2012
I need the impeler part #530047702
Try White Jones, if they don't have it on hand they can order it for you....
Hope it helps...
May 09, 2013 | RTO Weed Eater Electric Barracuda 2595...
Need to switch weed eater barricuda from blower to Vacuum but no manual
http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/2500_series.html?idRes=15826113
Here is where you can find the manual to download for the 2500 series Weed Eaater blower/vac
Aug 29, 2011 | RTO Weed Eater Electric Barracuda 2595...
My leaf eater starts to smoke. Where, or is there a place to oil the moter?
the electric motor should not need oiling sounds like you are running on a lightweight ext cord and under powering motor try hooking up to a plug directly into outlet see if problem persist
Nov 07, 2010 | RTO Weed Eater Electric Barracuda 2595...
Looking to replace my vac, bag if possible
http://www.ereplacementparts.com/vacuum-bag-kit-fits-types-p-229821.html
Oct 29, 2010 | RTO Weed Eater Electric Barracuda 2595...
Where can I obtain a replacement vacuum bag (in Calgary). The zipper on mine has broken making it unuseable.
Go to http://www.ereplacementparts.com/weed-eater-parts-c-17589.html Enter your model number. Then click one of the thumbnails that comes up until you find the replacement bag. My model number was 2595. I clicked on the thumbnail in the top row on the right and found the bag (part # 15). You can order direct from them and they ship right to you.
Sep 29, 2010 | RTO Weed Eater Electric Barracuda 2595...
I have a weedeater leaf blower that will start when I put gas in the caberator but will not run otherwise
sounds like the carby needs an overhaul. bellows in carby that **** up fuel may need replacing
Jun 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
I have a Weed Eater Barracuda leaf blower but don't have the manual. How do I attach the vacuum bag?
http://72.3.225.179/manuals/545117523e.pdf
Copy and paste. It will take you to .pdf for your Barracuda
Apr 30, 2009 | RTO Weed Eater Electric Barracuda 2595...
Poulan Weed Eater Electric Blower/Vacuum 12a Logo
254 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
