Question about Vacuums
Brushs will not work
Brishs will not turn when cleaning
    Top Expert:
  • Vacuums Master
  • 14,553 Answers
Look for the belt that wraps around the roller or look for hair or thread stopping the roller from turning at ends or middle.
Posted on Nov 07, 2012
Dyson DC23 canister vacuum turbine head stops spinning. Red on/off circle does not start the brush. If we cover the rubber 'u' gasket a tad, it will start spinning again normally. Putting the cover on does...
Hi Jyn, it's Jack at Dyson.
The rotating brush bar in DC23's Turbine head is powered by the vacuum's airflow. From what you've described, it sounds like there may be a blockage somewhere in the machine that's affecting the performance.
To locate and remove any blockages, please take a look at our online Support guide and follow the steps shown on each of the pages: http://www.dyson.co.uk/support/dc23/dc23-animal/my-machine-is-not-working/check-telescopic-wand-step-1-turbine-head
In normal use the pre-filter should be washed at least once every 3-6 months, using cold water without detergent. Even a filter that appears to be externally clean may still need a wash as fine dust particles may be contained within the filter material. The correct method is shown in the video attached. Make sure you allow the filter to dry completely for at least 24 hours before replacing it.
We would advise against attempting to modify the Turbine head in any way, as this could cause damage not covered under guarantee. If you'd like some further advice from our experts please feel free to give us a call - our contact numbers are: 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 23, 2014 | Dyson DC23ACTUSC Bagless Canister Cyclonic...
F7441-980 brushes won't turn
Paul:
Turn the vacuum over and remove the foot plate. Check the belt and manually try to turn the brushes. If the belt is OK, the brushes need to be removed and the roller bearings at the end of the brushes cleaned (hair, fibers, dust,) I remove the roller bearings and shoot them with alcohol while turning them until they turn free, then blow the alcohol out and lube them with one drop of light machine oil.
Nov 29, 2013 | Vacuums
Dyson DC08 turbo brush won't turn but have suction in tube
Hi Cathy,
I'm sorry to hear you're having difficulties with your DC08's turbo brush. As you've already checked the machine for blockages and washed the filter, I'd encourage you to get in touch with us directly so we can provide further assistance to help resolve this.
You can call us on 0800 298 0298 - our UK Helpline is available from 7am until 10pm, 7 days a week. It will help if you have the machine to hand when you call.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 26, 2012 | Dyson DC08 Hepa Allergy Bagless Canister...
I have dyson dc28 animal brush not turning how to fix
Your DC28 is not an easy machine to diagnose why the brush roll will not turn. If cleaning the hair and dust from brush roll doesn't solve it the first thing to do is replace the PCB. If that doesn't solve it then you need to install a new power nozzle assembly.
These repairs should be done by a qualified technician.
Feb 11, 2012 | Dyson DC28 Animal Bagless Upright Vacuum
Vaccuum brush not operating, only air passes through head
Hi I know its a silly question but an easy one to forget. Switch the knob on the dyson to brish rotate mode.
Feb 23, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Actually have model 6594. no suction. any suggestions?
If you hear the motor running and the vacuum is not sucking up debris, I would believe you have a problem with the beater brush. Problems with this brush are usually caused by 1 or 2 if not both of these problems: 1- The drive belt for the brush is broken. 2- The brush itself is frozen due to debris. Remove brush and clean all debris off. Pay special attention to end pieces of the brush that hold it in the vacuum. The brush should rotate around these two pieces. Clean ends and spray on a little WD40 and turn to work it so that the brush turns freely. If you find the brush is frozen and needs to be cleaned, probably a good idea to put a new belt on at the same time. Be sure the belt is put on correctly so the brush turns in the proper direction. Feel free to contact me if you have questions.
Sep 17, 2010 | Bissell 6596 Bagless Upright Vacuum
My roomba keeps telling me "error and to clean the brushes. I have cleaned the brushes and when I turn the roomba back on it keeps clicking underneath the roomba. I'm not sure what else to do.
I had the identical problem. I cleaned the brush but the problem persisted. I then put in a new brush that was provided in the box and the problem vanished. I have since used the cleaning tool on the old brush and will try and reinstall it to see if my cleaning worked. In any case a new brush will do the job.
Tim B
Apr 16, 2010 | iRobot 4150 Roomba Vacuum
Brushes won't turn
the mechanisam that makes the brushes spin are broken. take it into a shop dont fool with a roomba
Sep 11, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba keeps saying clean brushes yet are clean!
Make sure you take off the little cap at the end (the one that spins -- just grab it and pull it straight off) and clean under it too. The rest of the brush may look perfectly clean but what happens is that hair gets stuck under spinning cap and, like a slowly growing washer, it pushes the whole brush toward the gear box. When it gets pushed over enough, the large yellow ring starts to rub against the side of the brush deck making it harder for the motor to turn the brush and you get that "remove and clean brushes" message.
Jan 30, 2009 | iRobot Roomba 530 Robotic Vacuum
Brushes not working
brushes not turning are usually caused by the turbine bearings have seized. The turbine cost is about $35 average. on the bottom you can check a pull out filter to clean. there are also 2 screws that are recessd check by hand for tightness that hold the turbine. checkthe brushes for cleaning and free of debris. check the square shaft on the brushes as well. take it to a trusted vac shop who works on hoovers if you are not mechanically inclined for this type of repair.
Jan 15, 2009 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
