CYLIDER 8N A S55 AMG ,1997 IS MISFIRING - Computers & Internet
  • 3,606 Answers
Hello the fault could be:
A bad spark plug.
Ignition coil
Burned valve.
A injector coil.
Blocked fuel filter
Low compression on that cylinder.
Try make a compression test on that cylinder
The reading must be between 9 and 11 bar.
This is not a homejob let a qualified do the fault finding.
Because the engine is to expensive.It will cost you big time if something goes wrong.
Good luck
Posted on Nov 07, 2012
Is there a way to bypass the leveling system S55 AMG, can't load car onto trailer. It's too low
You can try and activate the air compressor at the pump relay, but if you have a serious leak that will not work.
Apr 15, 2016 | Cars & Trucks
Replaced shifter in 2002 s55 amg and now car wont start?
Check all wires around your replacement piece to insure that nothing came loose or is grounding out, it may have also overloaded a fuse if one wire is touching another, so maybe check fuses if nothing else.
Jan 14, 2015 | Cars & Trucks
2002 s55 amg doesnt have full power and back fires occaisionally. one catilyc converter get very hot fast.
the reason that the catylitic converter is hot is because of a rich condition in the engine, one cylinder is not firing. This is most likely the cause of the back fire that you are having. It may be related to the tapping sound if it is a valve that is bend or broken.
Apr 19, 2013 | Exhaust for Mercedes-Benz Mercedes Benz...
CYLIDER 8 IN A S500 AMG ,1997 IS MISFIRING
Change all the spark plugs in it, End if it has a lot of miles on it, Allso the plug wires,
Nov 06, 2012 | Cars & Trucks
Have a 2002 s55 and the washer bottleis
you can either pull it out and replace it or if you know were the leak is you can go to any parts store and get a plastic tank apoxy and repair it this only takes about two minutes to aply and if you let it set for a few hours you can use the squirts that day
Jan 14, 2010 | 2005 Mercedes-Benz Mercedes Benz S55 Amg
How to change trans fluid in mercedes 2003 s55 amg
there is a drain plug or nut at the bottom of that tank...open it and it will become empty...then again place that plug or nut....tight it with spanner and fill up the new fluid in that tank...
Aug 27, 2009 | 1998 Lexus Gs 400
Perfect tire pressure
The proper pressure is marked on the tire sidewall and on the sticker on the drivers door or door latch pillar.
Jul 20, 2009 | 2005 Mercedes-Benz Mercedes Benz S55 Amg
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
