Question about Brother SE-270D Computerized Sewing Machine
Thread not feeding
After putting thread through cassette and inserting it properly the thread doesn't thread nor does it come through to allow me to thread the needle.
    Champion:
  • Brother Expert
  • 300 Answers
The threading mechanism is jammed or out of alignment inside the machine, there is nothing you can do yourself. Bring it to a Brother repair shop, the mechanism is too complicated for a generic sewing machine repair shop to repair.
Posted on Feb 26, 2013
  • 201 Answers
SOURCE: needles keep breaking & bobbing wont feed thru
First try taking your bobbin case right out of the machine (not sure if this model has a top loading or front loading bobbin, but your manual will help you here) and floss out the tension slot with a piece of strong thread. Don't use waxed dental floss, but non-waxed would work okay. (The bobbin case is the piece that the bobbin sits in.) Look around while you have the machine open and remove any fluff and thread you can see - TURN MACHINE OFF BEFORE DOING THIS! Replace bobbin case. Replace bobbin and make sure it "clicks" into the tension slot.
Then unthread the top of the machine, clean the tension disks by passing a folded dollar bill (or any paper money, depends on what country you are in) through the disks in the direction you thread the machine. Do this several times. Re-thread making sure you follow the correct thread path.
Make sure the needle plate is on firmly.
If after all that it still won't work, I'm sorry to say that it sounds like you have a misaligned needle bar. This commonly happens after you have a major thread snaffoo and needle breakage. The needle gets caught in the thread knot, pulls to the side and breaks but if it gets seriously caught it can pull the needle bar out of place. You cannot put the needle bar back in place yourself - it's a job for the workshop. Don't sew on your machine until it is fixed. The noise you are hearing is likely to be the needle striking against the needle plate or even the bobbin. Your timing will probably need re-setting too and this needs to be done by a qualified technician.
If you really need to sew before you can get your machine into the workshop, and if you can move the needle position on your machine by pressing a "sideways" button of some sort, you could try to get the needle in the centre yourself using this feature. This will not help if it is the timing that is the major problem.
Pam M.
Posted on May 03, 2009
SOURCE: Brother SE 270D Cassette threader
I too have a christmas gift causing headaches - loopy embroidery. But at least this one I found a work around for... I thread the cassette according to the arrows but when I get to "6" I loop up around the left side and over the top of the bend but DON'T go far enough to cut the thread. I leave about 4 or 5 inches loose and hold the end at the top-right of the thread cassette at about the 2 o'clock position. I push the cassette down into the machine normally and right about when the 6 is below the window the thread will cut leaving you holding the left over piece. Continue pushing down until click and needle will thread. Have not had any threading problems since learning to leave a tail on the thread. Hope this helps.
Posted on Jan 25, 2008
talk2ginny
  • 34 Answers
SOURCE: Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
Posted on Feb 05, 2009
  • 1116 Answers
SOURCE: Brother 8500D sewing/emb machine - upper thread stops feeding
If the thread is hanging up at the spool - this could be the way it was manufactured, a nick in the spool end or the thread is unwinding too fast, puddling and wrapping around the spool pin.
Keep the bobbin case and surrounding area clean and free of thread tangles and snips. Thread tangles in this area can cause the machine to stop.
When the presser foot is down on any sewing machine, the tension closes and you cannot manually pull the thread through.
Sulky and C & C black tends to fray more than other brands of thread.
If the problem continues, the machine will need to be serviced by a professional.
Posted on Feb 24, 2010
SOURCE: I needle comes unthreaded whenever
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Posted on Sep 22, 2011
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
Top thread don't look right when i pull it it comes out
try changing the needle
try rethread the top thread
use every thread guide
use the right thread & needle for the fabric
adjust the top thread tension just a little forward, if that doesn't help
(write down where the top tension was before you moved it)
if adjusting the top thread tension doesn't help put the tension back
where it was
clean under the needle plate & in the bobbin are for lint
here is a link for a free manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000i_EN_2889.pdf
it's also possible that the machine could be slightly out of time
& it needs to be checked
Sep 07, 2012 | Brother CS6000i Computerized Sewing...
Big loops under the needle plate. The bobbin case is pulled towards the needle and lifted up in the front.
OK, Nylon thread and vinyl fabric are difficult. Try this:
1. Be sure your machine is *very* clean - no leftovers from previous projects.
2. Take the bobbin receiver out (need a screwdriver to hold the release), clean it and all around it and re-insert. When you re-insert in this machine, hold the release lever with the screwdriver, push the receiver away from you (under the feed dogs) then bring it back toward you so it catches before you release the catch.
3. Use a stitch length just a bit longer than you 'normally' would - 3+ for vinyl.
4. Wind your nylon thread onto a bobbin *very* carefully. It's easy to get it caught so that it won't feed evenly.
5. Be sure your upper thread is in properly, and that it doesn't catch on anything.
6. Adjust your upper tension tighter than 'normal' to accomodate the slippery thread your're using - do this a little at a time, it's easy to miss the 'sweet spot' if you adjust too much.
7. Be sure to bring up your bobbin thread and hold both threads as you start to sew - hold them for 3-4 stitches.
8. Sew slow - this machine can go *really* fast, but don't let it on this project. It will catch better if you take it slow and easy.
Hope all this helps. If not, you'd probably better take it in for service.
Aug 29, 2012 | Singer CG590 Mechanical Sewing Machine
Thread breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Aug 13, 2012 | Janome Sewing Machines
My machine started knocking & the lower thread jamming; how do i fix it?
have you tried a new needle
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check the bobbin to make sure it's not damaged
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or threads
also make sure the top thread doesn't come off the thread take up
lever
Jun 07, 2012 | Singer Confidence 7467 Mechanical Sewing...
Bobbin thread on excelw18 just pulls out after stitching
You have to keep the presser foot in the UP position in order to thread it properly. If presser foot is in DOWN position when threading, the thread cannot fall correctly into the tension discs.
Needle nice and new? Inserted all the way up as far as it can possibly go in the needle bar groove? Flat side toward back and thread inserted into the eye of the needle front to back? Feed dogs cleaned of broken thread?
If bobbin thread is problem, it's a threading issue. Did you actually put your threaded needle down into the needle hole and make a loop with your bobbin thread? Quite fixable. Relax, have a cup of tea and get away from machine for a good minute, then check all the things I just mentioned. Then you will be sewing happily in no time.
Jimmy
Apr 11, 2012 | New Home Sewing Machines
The bottom tension on my Pfaff 2056 sewing machine is loose and keeps jamming up.
check the top tension try a 3 or 4 but I wouldn't go any higher than 5
also put in a new needle
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
Aug 10, 2011 | Sewing Machines
I have threaded up my machine and have started to sew. The thread on the back of the fabric keeps catching and bunches up. What's going wrong?
try a new needle
keep a check on the thread take up lever that the thread doesn't come off of it
rethread the machine to make sure that the thread isn't catching on anything
clean under the needle plate for loose thread or lint & in the bobbin area also
Aug 04, 2011 | Bernina 1008
My Pfaff 4.0 breaks needles and shreds thread when free motion quilting
a sewing machine I work on last week, I put a new needle in the needle clamp & thought I had it correctly inserted,, but it wouldn't work,, so I went back & checked the needle again & found I had to unscrew the needle clamp screw even more than normal to insert the needle then it work perfectly.
some needles & thread don't work togeather--here's a tip
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also clean under the needle plate where the feed dogs are for lint
& also in the bobbin area for lint & loose threads
Nov 18, 2010 | Sewing Machines
Thread assembly unit for SE 270D has failed as when inserted a part within the machine when this is inserted has fallen off and won't allow the part to be inserted and then the door closed. Do not know how...
I don't have an answer, but yesterday mine jammed up too. When I put the thread cassette in, it got stuck on the little piece that slides up and down. I guess that I will have to take it in to the shop. I feel like this machine was a total waste of money.
Oct 18, 2009 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
76 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
