Is SMP-N200 compatable with my old Sony Trinitron TV?? It does not have a HDMI slot.... is an HDMI required for function??
  • 3 Answers
Http://store.sony.com/p/Full-HD-streaming-player-with-Wi-Fi/en/p/SMPN200#specifications
If that's the device, then no. Standard RCA cables or Component Video Cables can be used. If your Sony Trinitron TV has Component Video connectors I would use those as they provide better quality video than RCA cables.
Posted on Nov 07, 2012
Have a Sony SMP N200. Was working great but suddenly one day nothing showes on tv screen. I tried unplugging all wires, exchanged them, swapped, tried hdmi and av but still nothing. Can anyone help?
Try doing the video reset. It seems to work the same for all SONY products. Hole the power down for a full cycle until it powers back off. I'm not sure if this will fix your issue, but it wont hurt to try. ^^ Good luck.
Jun 09, 2015 | Sony Video Game Consoles & Games
What product would I require to hook up my Compaq laptop to my old TV Sony Trinitron to be able to watch films??
It all depend what output is available on your laptop. From what i see on internet your TV has front input for sound and composite video (yellow plug).
If you have VGA connector on laptop than you can purchase VGA to Composite video adapter, sound will come from ear phone output on your laptop.
If your laptop has only HDMI output, than you can buy HDMI to Composit (S-Video) adapter. Those have also audio out since HDMI carry both sound and video.
You can check internet for where to purchase those in your area.
Feb 07, 2015 | Sony Televison & Video
Hdmi instructions
Hi Kelly,
I believe the Sony Trinitron WEGAs do not have an HDMI connection on the back of the TV. If they do it would be labeled as HDMI input below that familiar looking HDMI narrow horizontal connector. But I believe what you have is the RGB connector which looks like three round female connectors which are color coated Red Green and Blue. Now these RGB connectors are a form of high definition but it's not a direct connect for for your HDMI DVD player or your XBOX 360 or what ever you want to hook the TV up to.
You'll have to convert you HDMI to RGB. you can still purchase DVD players with RGB outputs but if you already have a device that requires a TV with HDMI, you can buy a converter. Go to RadioShack or BestBuy or search online for a HDMI to RGB converter cable . It should look something like the picture below.
RED GREEN AND BLUE for video. And then the white and red connectors that are banded together are for your audio.
Good Luck
Dec 12, 2014 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Connect roku tv to Sony Trinitron
The roku has a cable that you can connect to those 3 plugs. Take the HDMI cable back and give the salesman a piece of your mind. Once your roku is set up you can watch much more than NetFlix.
Jan 23, 2014 | Audio Players & Recorders
Smp-n200 shuts off after 10 seconds. reset button not effective. 6 months new
Simple fix when this happened to me... I replaced the battery on the remote controller and the media player started working and didn't shut off again. Apparently, when it first comes on, it does a self test. if it receives no input from the remote, it shuts itself off. Hope this helps... BTW, the battery for the remote is any 2030 battery. Just replace it and try it. let me know if it worked...
Dave
Jan 28, 2013 | Sony SMP-N200 Streaming Media Player with...
Sony SMP N200 Network Media Player - unable to connect to home wireless network
You may need to enter the SSID in the wireless configuration in the Sony.
Check the Netgear wireless setting ie. the SSID, WPA or WPA2 encryption key, then apply these settings to the Sony wireless card settings.
Mar 20, 2012 | Computers & Internet
TV is connected to a DVR with HDMI/DVI cable and the picture keeps blinking.
Try another HDMI scource to see what happens there. If the second HDMI works with no issues then it is just a compatability issue with the DVR to your TV. At that point you will have to use the component inputs which will offer high definition as well.
Nov 11, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Is the sony trinitron 23 inch tv hd ready
You will need a model number before anyone can even do any research.
In general, there were never many CRT (picture tube) TVs made with the required ATSC tuner and if your set is 5+ years old, it isn't compatible with digital reception.
Oct 11, 2009 | Televison & Video
DVI port on Sony Trinitron KV-32HS500 not standard.What fits it?
I've just recently connected my old 32" Sony KV-32HS510 to my HP G60 Laptop via an HDMI (laptop) to DVI HDTV port(TV) with a cable.
I'm running Windows Vista on my laptop with the nVidia software. Once I've plugged in the TV to the HDMI port, the software initializes (recognizes the TV) and then I can select it as my second 'monitor' in the nVidia control panel.
I found I had to tinker with the resolution settings in the nVidia program to find an optimal resolution where the sides of the screen weren't 'cut off' by the TV.. I finally ended up with the resolution 1152x768 (I believe). It might be different for everybody, as I'm told Vista might do things differently than XP... But you should be able to tinker with the resolution settings and adjust the screen size...
(hope this helps with the second post - above)
Feb 11, 2009 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
