Question about HP Pavilion dv8000z Notebook
Quicktime always open on my Pavilion
Quicktime runs at start and even if I close it, it starts again ! Please help me !
  • 53 Answers
First go to wiindow media player. go to tools tab and select options. And then in File types tab, select select all and press enter.
then uninstall quick time and reboot ur pc and then again install it.
it would definately work. if not do tell me
Posted on Jan 05, 2009
Should I be using "Quicktime" on my PC
You can use both at a time however When you install QuickTime, or change your QuickTime settings, it may take over handling of Flash files. However, this can be fixed quite easily. To stop QuickTime from handling Flash files, do the following:
  1. Close Mozilla (or Firefox)
  2. Open the QuickTime Control Panel
  3. Select "Browser Plug-in" from the dropdown menu
  4. Open up the MIME Settings dialog
  5. Make sure "Flash file" is not selected. This is listed under Miscellaneous.
  6. Click OK, and close the QuickTime Control Panel
  7. Remove the file pluginreg.dat from your ProfileFfolder This file will be recreated next time you start Mozilla
  8. Remove npqt*.dll from your Mozilla or Firefox plugins folder. These files are not required, and can cause problems when QuickTime is upgraded
After doing this, you may need to reinstall Flash Player. These instructions should be the same for both Windows and MacOS X, with the exception of the last step.
Jul 22, 2012 | Acer Aspire 5100 Notebook
I am trying to download iTunes onto my computer, but when I get to the end of the process where iTunes and QuickTime are to be installed it wont. A small box pops up saying "iTunes could not be...
Hi there!
There can be several reasons why you are getting this error message. First, make sure that your user account is an administrator account. If you are sure that your account is an admin, follow this steps:
1. Choose Run from the Start menu. type %Temp% and click OK. delete all files inside the temp directory 3. Click again on run from start menu. Type cmd and hit Enter. 3. Drag iTunesSetup.exe from the Desktop into the C:\\WINDOWS\system32\cmd.exe window. 4. Add a space and then this text: /extract %TEMP% 5. Press return/enter. This will extract three Windows installer packages into your TEMP directory. 6. Navigate back to your TEMP directory. 7. Launch the AppleSoftwareUpdate Windows Installer Package. Complete the installation. 8. Launch the QuickTime Windows Installer Package. Complete the installation. 9. Launch the iTunes Windows Installer Package. Complete the installation.
Please reply if this will not fix the problem. Cheers!
Apr 23, 2011 | Apple iTunes
No sound at all..
I found several things to check about this issue.
First of all, make sure Windows Audio and Windows Management Instrumentation Services are running. Steps:
  1. Go to start -> run. If your keyboard has a ‘windows key’, which looks like the windows icon and is often located next to ctrl/alt, you can get away with pressing (and holding) this key, and tapping the ‘r’ key. I use this shortcut almost every day. On that note, windows-key+e I use even more- try it.
  2. type ’services.msc’, without the single quotes. This opens a list of the various services running on your computer.
  3. Make sure iTunes is closed.
  4. Locate “Windows Audio,” and see if it’s running. If it is, the status will show ‘Started’.
  5. No? Well guess what, iTunes needs this to be running in order to communicate with your audio device. Start it. There’s a link to start it along the leftmost column. Once it’s started, find a blank area within the services window, right click and hit refresh. Or just tap F5. Has the service died? If not, skip to step 7.
  6. The service died, didn’t it? Look for a ‘Windows Management Instrumentation’ service. This needs to be running for Windows Audio to be running, even though it’s not listed in the dependancies. Fire it up, then fire up Windows Audio.
  7. Fire up iTunes, and enjoy.
Secondly, you can open Control Panel and uninstall and then reinstall QuickTime. You can download QuickTime at this URL:
Third, you can try to reinstall iTune and allow any settings about playback and audio configuration with iTune during that.
Hope those helps.
Jul 09, 2010 | HP Compaq WF1907 Monitor
How do I start rental model 96.
Place the saw on full choke with the switch on. Pull the rope until it fires. Place the saw on half choke, and pull again, and it will start running. Half choke should release as soon as you hit the trigger.
Mar 23, 2010 | Husqvarna Chain Saw 20" Bar
My itunes does not start whwn i clicked on icon.
Here's some info that may help - picked up from other boards where similar problems reported.
First check to see if Quicktime works normally, iTunes will not work without it.
If Quicktime is OK, then use these troubleshooting articles: XP version Vista version
Have you installed any of the following: ACE & K-Lite mega codecs package, QT alternative, Storm codec, WinAVI video converter, Mpcstar, (possibly starcodec pack, 3ivx)
If so uninstall them, they are know to cause problems with Quickitme. Then download the version of Quickime without iTunes: Now Remove Quicktime using the method for Quicktime in this article (just Quicktime): XP Vista When you come to your C:\Windows\system32\ folder you can delete any file or folder with Quicktime in the name. Restart you computer Install the stand alone Quicktime and check if it starts. If it does you are in a position to find out if iTunes is OK.
If Quicktime is OK, do you get any error message when you try to start iTunes? If not, open your task manager after trying to start iTunes. Do you see iTunes.exe running on the processes tab. If there is no error and you see iTunes.exe running then iTunes is hanging and we need to look at a slightly different route.
Sometimes it is just a problem with the itunes database file when it won't open after an upgrade. Press and hold the shift key while trying to start itunes. Does it give you an option to choose or create a new library?
Bonjour is a common cause of iTunes hanging at start up. i.e. silent launch failure with iTunes.exe running on the processes tab. You can uninstall bonjour if you don't need it. However it is required for sharing libraries and other things
You could also try uninstalling it, then downloading bonjour from Apple and installing it directly.
Jun 15, 2009 | Apple iTunes
Can't play the videos I've recorded...
The panasonic vidoe are in quicktime - you will need to either download quicktime software to run the vidoe clips or you can convert the file format from quicktime into windows media player format. The codecs you are downloading may convert your files but I am not familiar with GO.
I suggest you download quicktime for now, so you can at least play your vidoes. be sure to check your operating system for the download.
At a later date, you may or may not want to edit them in which case you can download a conversion tool or do so online.
Mar 23, 2009 | Panasonic Lumix DMC-FX10 Digital Camera
Sony media manager error message
I had the same problem and couldn't find an answer anywhere, so I though I'd share how I got past it.
I did not have quicktime installed when I first ran the install for media manager, and as such it requested I install it from CD, which I did. It was after this was finished and returned to the main install that the install failed.
I found that quicktime did not consider itself completely installed until it was run for the first time. I booted up quicktime, allowed it to do it's first-time bits and pieces, until the default website appeared, then closed it.
I tried to install media manager again and it worked just fine.
Hope that helps.
Dec 26, 2008 | Cell Phones
Macromedia projector has stopped
You might try reinstalling Macromedia Projector (now Adobe Flash).
Sometimes if you use compatibility mode to run the game:
  • Click - Start, Programs, Accessories, Program Compatibility Wizard.
  • Follow the prompts to set up the compatibility mode.
  • Use Windows 98 compatibility, and disable visual themes.
Also you could change Apple Quicktime to run video in Safemode:
Quicktime Player > Edit > Quicktime Preferences > Advanced > and under Video Change from DirectX to Safe Mode (GDI)
You may need to reinstall Quicktime, but uninstall the old version first.
Nov 20, 2007 | Computers & Internet
Camedia 4.1 installation error
I have the answer!
I had same problema nd found solution on another board.
It is a quicktime error.
Download new quicktime software from here;
Then camedia will load/install.
Albert Teacake
Oct 07, 2007 | Moultrie MFH-DGS-100 Digital Camera
HP Pavilion dv8000z Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
