Question about Epson Perfection v600
Why does every negative scanned on the Epson Perfection v600 have a yellow line going vertically down on it?
The yellow line is faint, and goes straight through the centre of every image.
5 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: I have vertical lines in my photos when i scan them
If the lines are in the same location for all scanned outputs, it is clearly dust on the scanner glass. Clean it thoroughly.
S. Mohan, India
Posted on Jul 09, 2009
SOURCE: Epson V300 Photo Scanner Streak When Scanning Negative
I also own a v300, and I have noticed that I occasionally get rainbow streaks if I bump the scanner at all while it is scanning negatives, so this might have something to do with vibrations in the machine. Is it sitting on a stable surface?
Posted on Aug 05, 2009
  • 12 Answers
SOURCE: epson v500 not able to scan negatives! When I open
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Posted on Aug 22, 2009
tech-agent
  • 83 Answers
SOURCE: Epson perfection application not working on G5 10.5.8
hi there. you actually downloaded the right driver :
try this Run Photoshop in Rosetta mode; Epson Scan 2.77A only runs in Rosetta mode.
Follow the steps below to run Photoshop in Rosetta mode:
  1. Open the Hard Drive, select Applications > Adobe Photoshop, then select the Adobe Photoshop icon.
  2. Hold down the drv_mac_407_er.gif-I keys to open the Get Info window.
  3. Check the Open Using Rosetta option, then close the window.
  4. Start Photoshop.
Posted on Feb 20, 2010
I have printer plus scanner epson l200. and I thought there is option for scanning a film. but it turned out the option is greyed out. I wonder if this type is available for scanning film or there is
To scan film, your scanner needs a light above the film. Not just a light, but a calibrated light. That is why the scanners who can scan film and transparent sheets, have a lit with a light in it. Your scanner does not have this, so scanning film is not possible. One of the cheapest (flat bed) scanners from Epson is the V600 and costs about $200, Epson Perfection V600 Photo Scanner
Feb 04, 2015 | Epson L200 All-in-One Inkjet Printer 27...
I want to print the user guide for Perfection v600
Here's the webpage for the Epson Perfection v600 manual. You can either view it as a PDF or HTML. If you want to print it, then open it as a PDF and print it or save it.
Thanks for using FixYa.
Apr 07, 2011 | Computers & Internet
How do I scan a slide photo / negitive on my epson perfection V200 scanner?
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
Aug 08, 2009 | Epson Perfection V200 Flatbed Scanner
S. Mohan, India
Jul 04, 2009 | Epson Perfection V350 Flatbed Scanner
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
Epson Perfection 4180 won't scan my negatives
cant scan film with epson perfection 4180. how can this be fixed?
Jun 10, 2009 | Epson Perfection 4180 Photo Flatbed...
Scanning photos
i just had my CCD replaced before my warranty expired in Feb and it worked fine for a week. Now i'm getting a cyan line down all my negative scans. And since you can only scan negatives in one spot, I can't even use a diff part of the scanning surface to avoid this. Sounds like a downright cheap part and definitely can't do the job. Never buying an Epson again, esp since they closed down the repair center nearby.
Nov 13, 2007 | Epson Perfection V100 Flatbed Scanner
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Epson Perfection v600 Logo
145 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
