Question about Epson AcuLaser C900 Printer
Transfer Unit Replacement
Am having major problem in replacing transfer unit. Have slid out old unit and tried to slide in new unit but will not go in the last about half an inch for the screws to be done up!! I have tried to refrain from forcing it but appears to be catching on something but you can not see where any hold ups are. Is there any one that can help me with this frustrating problem??
  • Epson Master
  • 705 Answers
Hey Coldwell, Check my previous post about a similar problem and see if it helps you out with your situation. Previous Post: http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Posted on May 22, 2007
SOURCE:
Color Print Quality
In my experience, the fuser has always been the cause of the lines.
Jul 09, 2008 | Ricoh CL3000E Laser Printer
Transfer of live updates for a replacement unit.
Refer your inquiry directly to TomTom.
Nov 18, 2013 | GPS
Have a transfer belt error What to do?
To fix this error, you will need to replace the transfer belt and/or reset the transfer belt count on your printer. If you are happy the the print quality of the printer, then you can try to reset the transfer belt count and that will clear the error. Otherwise you need to get a replacement transfer belt and swap it out before resetting the count.
To remove your existing transfer belt, you need to open the front panel, and remove the imaging unit by pulling the green handle. The belt is located above the imaging unit. Pull the belt down to release and then pull it straight out of the machine. Take your new belt and slide the back into the machine and push the front of the belt up to lock in place. Then you need to reset the belt count.
To do this, follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Apr 02, 2011 | Samsung CLX 3160fn All-In-One Printer
WHERE IS THE TRANSFER UNIT LOCATED ON KONICA
Unit is in the right side cover. New one should have instructions with it, but I think you unlock a handle and swap, then lock handle again.
Apr 06, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Lexmark X500N says replace transfer belt, what is it, and how do I change it?
The transfer belt is located inisde the printer and is what moves the paper back out the printer. You will need to open the back cover of the unit then you will lift the top part of the printer off. This will expose the transfer belt. There is a bracket holding the transfer belt with two screws that will need to be removed. Then two more screws that are holding the belt assembly in place. Once those are removed then you can slide out the transfer belt assembly. The new replacement transfer belt assembly will slide back in replacing the old one. Then repeat the steps opposite to install. Then remove the four spacers on the new belt(on each corner). Then you will reset the counter for the belt and will need to run the printer alignment settings.
Nov 13, 2009 | Lexmark X500n Color Laser All-in-One...
Installing a Transfer Kit
i got this info from www.partshere.com site - they have most service notes for hp printer and sell most hp parts, including maintenance kits. I hope info. bellow is helpfu.
Replacing the transfer unit
Replace the transfer unit when the printer control panel displays REPLACE TRANSFER
KIT
. The image transfer kit contains a replacement transfer unit for this printer.
WARNING! Remove any jewelry or any other metal items from your body to avoid electric shock.
1. Lift the front door handle and pull down the front door.
2. Grasp the right blue handle. Press and hold down the blue button. Slightly lift the right
side of the transfer unit.
3. Grasp the left blue handle and lift to remove the transfer unit from the printer.
4. Using handles, remove the new transfer unit from the bag. Use the blue handles on both
sides to hold the transfer unit.
5. Place the new transfer unit on a flat surface. Remove the orange shipping locks.
6. Guide the left side of the transfer unit into the front door of the printer. Insert the two
pegs on the left side into the holes, and then lower the right side into the door.
7. Make sure that the blue button on the right blue handle has released (popped up). If the
button has not released, grasp the right blue handle and pull the transfer unit toward you.
8. Firmly close the front door.
9. After the front door is closed, after a short time, the printer control panel displays the
message NEW TRANSFER KIT.
10. If the message NEW TRANSFER KIT does not appear, you must reset the transfer unit
count. To reset the transfer unit count, go to step 11.
11. On the printer control panel, press to highlight YES, and then press to select it. The
transfer unit count is reset, the printer recalibrates, and then the printer is ready to use.
NOTE If the old transfer unit was not at end-of-life when it was replaced (for example, if it was
damaged), the transfer unit count must be reset using the printer control panel.
Replacing the transfer unit when it is not at end-of-life
If you replace the transfer unit when it is not at the end-of-life, for instance if it is defective,
you will need to reset the transfer unit count and then calibrate the printer, through the
control panel.
To reset the transfer unit count, do the following:
1. Press MENU to enter the MENUS.
2. Press to highlight Configure Device.
3. Press to select Configure Device.
4. Press to highlight RESETS.
5. Press to select RESETS.
6. Press to highlight RESET SUPPLIES.
7. Press to select RESET SUPPLIES.
8. Press to highlight NEW TRANSFER KIT.
9. Press to select NEW TRANSFER KIT.
10. Press to highlight YES.
11. Press to select YES.
To calibrate the printer, do the following:
4. Press to highlight PRINT QUALITY.
5. Press to select PRINT QUALITY.
6. Press to highlight CALIBRATE NOW.
7. Press to select CALIBRATE NOW.
8. Wait for the printer to calibrate.
The transfer unit count is reset and the printer is ready to use.
see pictures on link:
http://www.partshere.com/Models/Q5990A/CLJ_3550%203500%203700Installation_n_config.PDF
Apr 18, 2008 | HP Color LaserJet 3500 Printer
Transfer Unit replacement
Because the C900 does not have a button panel, there is no easy way of getting into a service mode to clear the counters. The short answer to your question is no
Have you considered trying to buy a used transfer unit from like of eBay
Oct 11, 2007 | Epson AcuLaser C900 Printer
Epson AcuLaser C900 Printer Logo
127 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
