Question about Garden
North Star pressure washer washer part ser # 03053627
PSI 2000 Max tem 140 VRX 2017V ARF 65110016 00 Parts needed, Seal kit and check valve
david04928
  • 102 Answers
SOURCE: north star petrol pressure washer.
Sounds like the regulator is sticking or is airbound. loosen the water connection and then tighten it back. Could also be that the trigger gun is faulty or needs adjustment. Hope this helped
Posted on Mar 15, 2009
  • 5 Answers
SOURCE: Need to lower 1750 psi to 300 psi on my portable power washer.
Don't starve the inlet to the pump. It will detroy it.
Buy a pressure regulating valve and plumb it in line per the instructions. Do not use a relief valve because you will have to have a return line or you will heat the water up on the inlet side of the pump depending on how the pressure washer is set up. It should already have a safety relief valve. You might look and also find a pressure regulator that is adjustable and all you problems will be solved.
Posted on Apr 25, 2009
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
motorhead427
  • 24 Answers
SOURCE: NO PSI
have you checked to make sure that keyway is installed between electric motor and pump. also adjustment on unloader valve may be incorrect. If the big brass nut on the unloader is able to be turned by hand, then this is probably your problem (running pressure and spike pressure needs to be set and locked down using a pressure guage). does water come out of nozzle at all? if not, tip being stopped up may be the problem. trash between unloader ball and seat can also cause no pressure (usually caused by a burr left inside brass pieces during the manufacturing process). I have seen all the check valves stuck on a brand new unit from sitting on the shelf for so long, but this is usually the case with General Pumps.
Posted on May 30, 2009
SOURCE: engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
Posted on Jun 01, 2009
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
I have a Honda pressure washer. Trigger must be pulled and held while starting. After starting the sprayer works OK but engine lugs down and dies as soon as trigger is released. Anything I can do, or need...
The problem with the engine is going to be a cleaning of the carburetor. Remove the carburetor and clean you may need a rebuild kit but try the cleaning first. The problem with trigger being held to start, I have herd this problem before and most people just except the fact that this is what they have to do to start. I would remove the pump and clean the check valves and unloader valve. If you are some what machanically inclined you can handle this, but if your not sure you should take this to the shop.If you need parts or just want to see a parts breakdown of pump and carburetor you can go to jackssmallenginerepair.com and go to parts look up and type in your model #. I hope this helps.
Jul 25, 2011 | Honda Black Max 2600 PSI Pressure Washer
Need to replace PC Valve. Engine oil pressure is above 140 PSI. Blows seal on oil pressure sending unit.
You need to replace oil pump oil pressure should not be highyer then 60 psi
Jun 26, 2011 | 1991 Buick Regal
We have a Black Max 3000 psi with a Honda GC 190 engine and the water will not come out of the power washer anymore
cud b a few things 1.check filter 2.check 2 c if water is returning tru the over flow 3screw down pressure valve as far as u can
Aug 02, 2010 | Honda Black Max 3000 Psi Pressure Washer
Karcher G2600 VH - low water pressure
If the spill valve activates is "spills" water under the washer. There is a restriction or the pump has become inefficient and will not pump the volume and pressure it should at full RPM.
Jul 20, 2010 | Karcher G 2000 MK 2000 PSI 20 GPM 87cc Gas...
I need the 1/8 in. one way valve that allows the soap to mix with the spray.
I've had good luck getting parts from rental centers. Since they have to repair what they rent, a lot of times they have the small parts at the shop. good luck.
Aug 07, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Compressor blows off, does not maintain pressure
Hi there. This is normal. The pressure is set to stop at around 120-140 PSI as a safety measure. It probably kicks in again around 80 PSI so as to remain pressurized between 80 and 140 PSI. Since most air tools operate in this range, it is ok for the compressor to maintain pressure in that range. You do not want to adjust the maximum pressure safety release valve as it could be extremely dangerous as certain components in the compressor may only be rated up to 140 PSI or slightly higher before they fail or blow apart.
Jul 25, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Unloader valves
Yes, your compressor will work just fine with a Load Genie continuous run unloader from www.grainger.com. The part number is 4tk14 with a cost of about 45.00. This unloader has a built in check valve so you can remove the present in-tank checkvalve and save it for later use. All that you need to do is install the unloader at the tank and compressed air in to top of valve. (you may have to buy extra fittings to make it work with your tubing size) Adjust valve to open just before the pressure switch cut-off setting. The unloader will bypass the compressed air and will have less stress on the motor. You will not need to use the present unloader at the pressure switch. The only caution is to manually unload the Load Genie upon initial start if there is pressure in the line. Good Luck with your project.
Mar 31, 2009 | Northstar Electric Stationary Air...
North star petrol pressure washer. working fine, then no high pressure, checked water feed, water filter , pressure relief valve and gun nosall well work sometimes and keep working, when you release the...
Mar 12, 2009 | Karcher 2500 PSI Pressure Washer
NO PSI
Jan 07, 2009 | Northstar Pressure Washer 3000 PSI
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
