Question about Sanyo DP42849 42 in. HDTV
How do I set the ECO level to 3 - Sanyo DP42849 42 in. HDTV
Yamaha ef 2800 i, fresh fuel, cleaned carb, major surge with eco. switch on, slight search, no load with eco. switch off. near perfect under 75% load. output steady 119.9 to 120.00 volts.
I hope you have not moved the genny from lower to high altitude b cause the carbs of these gen sets are tuned at the sea level and they give their best performence up to 1000 meters or so in altitude from sea level if you hav'nt moved the generator then check the air fuel mix screw on the carb that screw controls the the oxygen supply required inside to burn the appropriate quantity of fuel take a screw driver and adjust by rotating it anticlockwise on idle with eco switch on then put it on 75%load and try adjusting the screw both ways clockwise and anticlockwise with switching the load on and off with eco throttle off you will find a point where the engine will run smooth but mind it the screw has to be moved very slowly either side usualy these problems accur on high altitudes when the oxygen suppy goes less then the jet in the carb is to be reduced and air fuel mix has to be adjusted which is called re jetting of the carb You say you have cleaned the carb may be accidently while cleaning the air fuel mix screw might got disturbed just check
Aug 16, 2012 | Yamaha 2500 Watt Industrial Inverter...
I have an AV-S17 and it's stuck on eco mode. I have tried doing what the form has said for me to do and it doesn't help.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Aiwa-AV-S17-Receivers-manual/id/1076ag804/t/2/
Page 7:
To cancel the ECO mode
1 Press the ECO button to display ECO MODE while the unit is turned on.
2 Within 4 seconds, press the ENTER button.
3 Within 4 seconds, turn the MULTI JOG to select ECO OFF.
The mode will be automatically set after 4 seconds. It will also be set if the ENTER button is pressed within 4 seconds after step 3.
Mar 29, 2011 | Aiwa AV-S17 Receiver
This tv automatically switches itself off after 4 hours. can I disable this feature? Thanks
Yes you can. If it's exactly 4 hours, then you need to change the "Eco" power settings as follows;
1. Press the "MENU" button on your Sony TV remote control.
2. Use the circular arrow keys on the remote to highlight the flower icon for the "Eco" settings:
3. Press the large "+" key on the remote (in the centre of the arrow keys) to open the "Eco" menu.
4. Use the DOWN arrow button to highlight "Idle TV Standby". (The current setting will be 4h)
5. Use the LEFT/RIGHT arrows to set the value to "OFF" (1h or 2h can also be set).
6. Press the "MENU" button again to close the menu and return to watching TV
Hope this helps. Please post back if you are still unable to disable this feature or need further assistance.
Regards,
BElectric
Jan 05, 2011 | Sony KDL32BX300 32 in. TV
I've just bought the new LG Direct Drive, the problem is when I put it on ECO cycle it takes 3hrs 28 min to complete a cycle. Is this normal, I was under the impression a cycle should be about 30 min
Make sure that the water inlet pressure is good and there is no restriction ,
Now it is normal that the wash cycle is long as the dishes are put into and set to be done overnight.
But it will be good to clarify if the ECO wash takes so long as 31/2 hours, which could be fine with a high level wash.
Call LG Dealer to confirm as the set is new.
Sep 27, 2010 | LG Dishwashers
I own 3 Citizen ECO watches that have lost their charge.
Hiya Papahay,
are the crowns out at time set mode. This mode activates a 'hack device' ( a small spring in the watch) which will cut power to the circuit.
With the crown out and under light (even a desklamp directly with in a few mms above them) should do the trick.
These capacitors do need replacing, I suggest give the above a go for a least 24 hrs straight and go from there. When there are fully charge all you need to do is pull the crown out to time set mode and leave under light
Jul 11, 2009 | Citizen Eco-Drive Silhouette EW869452D...
I cannot set the date on my Citizen SkyHawk Eco-Drive
Just pull the crown out, turn it so that the bottom analog display is set on "CAL" and push crown back in. Voila!!
Mar 16, 2009 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Pump motor runs continuously, ''Eco'' flashes continuously
Hi
soyunds like it flooded the base
You need to dry out the base of the machine thoroughly and it should re set
Feb 14, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
My brightness keeps resetting
i had the same problem....... on the actual tv u have to press and hold the volume button and menu button together for about 5 seconds and then on the screen it should say dynamic and that hopefully will sort it for u. Worked for me :)
Dec 27, 2008 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
I can't set the date on my new citizen's eco drive BM8080-59A. I don't know if I'm doing it wrong or if the date setting function is broken. I have tried to change the date by pulling the winder to the...
Yes that is ok its right by pulling the crown winder in the mid level or half level,that is for calendar date.To check if function is ok or broken,just pull full the crown and set the time,see if the calendar date is changing or moving.Then if moving then its ok,the next step you do set is the calendar date,by pulling the crown half pull,then turn the crown counterclockwise for date and for the day turn clockwise.Feel free to post whatever the result of the setting...
Hope it may helps you;
Regards,
VOTIT
Sep 23, 2008 | Citizen Watches
Sanyo DP42849 42 in. HDTV Logo
62 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
