Question about Ammco Combination Disc/Drum Brake Lathe
Rotor disc does not traverse - Ammco Combination Disc/Drum Brake Lathe
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
If it is an electrical problem,
check limit switch
Posted on Nov 21, 2012
To remove brake disc
All you need to do is remove the wheel, then the caliper assembly and the brake rotor just slides off.
Oct 05, 2012 | 2010 Chevrolet Traverse
Panasonic SA-HT75 need help turning the disc
Hi,from past experience I have found the spindle motor in the traverse assembly to go faulty.You are gonna have to to take it it to a technician to have the traverse assembly replaced.Thanks
Nov 29, 2011 | Panasonic Audio Players & Recorders
Every Time I Put IN A Disc To Play The Disc Plays About 20 Min. Then Startes Skipping This A Blue Ray Player, But I Don't Always Play Blue Ray Discs
If it does it on all disks, the traverse motor or drive is faulty or contaminated.
It requires servicing.
Jan 04, 2011 | Televison & Video
The Memorex DVD player makes clicking and either it stops playing or plays in fits a starts - It does this more than half way into the disc
That sounds like the traverse motor is having problems turning and moving the laser further out into the disk.
Check there is not a speck of hard dust on the traverse motor mechanics, cogs etc.
Oct 19, 2010 | Televison & Video
Break noise when you press break
I am not sure what kind of noise you are talking about as you did not post it. Jack up the car. grab the wheel top and bottom and try to move it. do the same side to side. if it will go up and down you either have a bad bearing, or a bad ball joint-if it move side to side, you have a bad tie rod. Pull off the wheel. Check that the pads are still good. Grab the brake caliper and try to move it. if it moves-check that the tightness of the bolts that hold it to the A-frame. If the pads are not worn, and everything else is tight, what you are most likely hearing is the metal in the pads grinding against the rotors, or brake dust buildup.If it is a squealing noise, Using a air compressor with a blower tip, blow out the caliper. You may also(for large buildup of brake dust) get a can of break cleaner and spray off the rotor and caliper. If grinding(and the pads are good), It may also have lost the noise reduction pad behind the brake pad that reduces that noise. This will not hurt the vehicle, but if you want it fixed, you will have to replace the pads, and have the rotor turned at you local brake shop, machine shop, or parts store. Usually about $5-$10 per rotor.
Sep 15, 2010 | 2009 Chevrolet Traverse
I need to know the procedure for r and r on a front rotor if this is something that can be done at home with limited tools?
1999 Taurus/Sable Section 06-03: Brakes, Front Disc 1999 Taurus/Sable Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 06/25/1998 Disc Removal
  1. Raise vehicle on hoist.
  1. Remove wheel and tire assembly. Be careful to avoid damage or interference with caliper bleeder screw fitting and front disc brake rotor shield (2K004).
  1. ani_caut.gif CAUTION: Handle front disc brake rotor (1125) and disc brake caliper (2B120) assembly in such a way as to prevent deformation of front disc brake rotor , and nicking, scratching or contamination of brake linings/rotor surfaces.
    NOTE: To prevent damage, do not allow disc brake caliper to hang by the front brake hose (2078) .
    Remove caliper anchor plate bolts and discard. Position disc brake caliper out of the way. Prevent separation of caliper housing from anchor bracket because contamination of guide pin journals can occur.
  1. NOTE: If excessive force must be used during front disc brake rotor removal, the front disc brake rotor should be checked for runout prior to installation.
    If additional force is required to remove front disc brake rotor , apply Rust Penetrant and Inhibitor F2AZ-19A501-A or equivalent meeting Ford specification ESR-M99C56-A on front and rear rotor/hub mating surfaces. First, strike front disc brake rotor between lug bolts (1107) with a plastic hammer. If this does not work, attach 2-3 Jaw Puller 205-D027 (D80L-1013-A) or equivalent and remove front disc brake rotor . Remove front disc brake rotor from wheel hub (1104) assembly by pulling it off the lug bolts.
Installation
  1. If original front disc brake rotor is being installed, make sure rotor braking and mounting surfaces are clean.
  1. ani_caut.gif CAUTION: Failure to clean rust and foreign material from rotor and hub mounting faces when installing new or old front disc brake rotors will result in high rotor runout, which will speed up the development of brake roughness shudder vibration.
    Apply a small amount of Silicone Brake Caliper Grease and Dielectric Compound D7AZ-19A331-A or equivalent meeting Ford specification ESE-M1C171-A to pilot diameter of front disc brake rotor.
  1. Install front disc brake rotor on wheel hub assembly.
  1. Install disc brake caliper and new caliper anchor bracket bolts on front disc brake rotor . Tighten caliper anchor bracket bolts to 88-118 Nm (65-87 lb-ft).
  1. ani_caut.gif CAUTION: Failure to tighten lug nuts (1012) in a star pattern may result in high rotor runout, which will speed up the development of brake roughness, shudder and vibration.
    Install wheel and tire assembly on vehicle. Tighten lug nuts to 115-142 Nm (85-104 lb-ft) using Rotunda Accutorq® Lug Nut Socket 164-R0303 or equivalent on a 1/2 inch air impact wrench, or use a torque wrench.
  1. Lower vehicle.
  1. Pump brake pedal prior to moving vehicle to position brake linings.
  1. Road test vehicle.
May 25, 2009 | 1999 Mercury Sable
Panasonic SC-HT75 Home Theater system
Laser/traverse deck needs replacement.Spindle motor fails to spin.If loaded disk will not turn give it a slight push to get it started.If it runs the motor is bad and the traverse deck needs replacement.Not an easy fix.You need to know specific procedures and alignments.
Dec 26, 2007 | Panasonic SC-HT75 System
Disc won't spin,
If your PS2 slim console is chipped for playing fake games then try it by replacing the modification IC otherwise replace the lens with new one and your problem should be solved.
Aug 21, 2007 | Sony PlayStation 2 Slimline Console
Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Jan 11, 2007 | Teac AD-600 3-Disc CD Changer
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Jan 06, 2006 | Panasonic DVD-LS55 Portable DVD Player...
Open Questions:
See all Ammco Combination Disc/Drum Brake Lathe Questions
Ammco Combination Disc/Drum Brake Lathe Logo
87 people viewed this question
Top Ammco Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Ammco Tool and Hardware - Other Expert? Answer questions, earn points and help others
