Question about Acer Aspire 6930-6455 Notebook
My computer froze up while doing a security scan
Is there a command or something i could do to ifix
  • Acer Master
  • 27,725 Answers
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
if this fails you might have to go back into safe mode
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
other than that you might need to do a format and then re install your operating system
hope this helps
Posted on Nov 07, 2012
Computer froze while running microsoft security essentials what can i do to fix
REboot. run again along with a good malware program like MALWAREBYTES :http://www.filehippo.com/download_malwarebytes_anti_malware/, RUN A FULL SCAN DELETE Results. also run and use often CCLEANER found here: http://www.filehippo.com/download_ccleaner/ RUN CLEANER AND DELETE Run regietry scan and delete results. There are many useful tools in CCleaner, like TOOLS> STARTUP to disable programs so your computer starts faster and runs a bit better, not so bogged down by unwanted/unneeded programs.
Nov 06, 2012 | Acer Aspire 6930-6455 Notebook
My 2006 jeep commander will not start.
Hello
The engine and automatic transmission in this vehicles drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump, engine coolant temperature sensor and MAF sensor for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL A TRAINED TECHNICAIN HAS DIAGNOSED THE PROBLEM TO AVOID SPENDING YOUR HARD EARNED MONEY ON PARTS THAT MAY NOT CORRECT THE PROBLEM
Aug 24, 2012 | 2006 Jeep Commander
How do I scan a document to my computer
  • First open the program that control the scanner.
  • Look for a command or section that say scanner or scan and click it.
  • Put the document to scan in the scanner.
  • Click the command in the program for scan the document
You can also use the scan tool that Windows provide that is really easy to use.
Jun 08, 2011 | Computers & Internet
How do I password protect my wireless router?
go to start> run> type "cmd" > the command prompt window opens up.... typr "ipconfig" in command prompt window.... note down the default gateway address below ethernet adapter local area connection... type the default gateway address(usually 192.168.2.1 for belkin routers) you ll login to the router page.... now search for the option like "security" below wireless... enable security to 64 bit WEP and enter a 10 digit number as a password in key 1....donot type anything in any other boxes....click apply changes...thats it....your network is secured....now goto your computer and delete all preferred wireless networks and scan and connect the secured network...it ll ask for the security key...enter the key and get connected....
Mar 30, 2010 | Computers & Internet
I have a virus thats taken over my computer and want to do a complete system restore. I have the discs. I press f11 and it gives me 2 options 1. to restore windows xp and 2 to do a complete restore when i...
You might like to try a WEB based virus scan before you try a complete restore. :-
Trend Micro HouseCall
Many computer users rely on Trend Micro for their antivirus needs but when you’ve got a virus, sometimes your installed version won’t boot up, so the company’s got a free online scan that can be used by anyone in this situation, not just Trend Micro users. It’s called HouseCall and it’s a free virus scan that you can get right now... just go to http://housecall.trendmicro.com. When you get there, click on Launch HouseCall 6.5 (you have to have Java or ActiveX controls enabled)
Norton Security Scan
Norton Security Scan is the online free security scan offering from Symantec, makers of the popular Norton Antivirus and Norton Internet Security products. If you want to start using this one, first make sure you’re running Internet Explorer 5.0 or above, and then head over to http://security.symantec.com and click Continue to Symantec Security Check:
Nov 19, 2009 | E-Machines eMachines Desktop PC
Everything was fine then computer froze so I manually shut it down. Now I hear and see the computer boot-up with the Windows Insignia & Gateway logo and the mouse pointer but then it's black, except...
Restart the computer and press F8 key after you hear a beep or before it gives you the Windows logo on Startup. It will give you then the Advanced Startup Options.
You could try the option 'Last Known Good Configuration'.
You may also try Safe Mode option and do a System Restore. On Safe Mode, System Restore will automatically loads up at startup. You can then choose the date and time where you had it last working before.
If those can't be done, you may want to run scan file checker and fix system errors for you. Do this from Start> All Programs> Accessories> right click on Command Prompt. Then select Run as Administrator.
On the Command Prompt, enter sfc /scannow
That will automatically repair system files. However, it may ask for Windows Setup CD.
Oct 14, 2009 | Samsung SyncMaster 2253LW Monitor
Computer froze when installing Trend Internet Security
Press F8
Choose "Safe mode with command line"
When you're in the command line type:
control appwiz.cpl
and just uninstall Trend Internet Security.
After that, check Trend website and search for known issues.
Sep 15, 2009 | HP Pavilion dv6000z Notebook
When I select scan it will not scan any work but all other features are working fine
scan is just a command by the computer so there is something wrong in the software driving that command. Try reloading software drivers.
Sep 14, 2009 | HP Photosmart 2410 All-In-One InkJet...
How to give command to check virus
You have to open your anti-virus software, whatever you have installed on your system, and run a scan of the computer. (Go to STart>All Programs>choose your AV or internet security suite>Computer Scan). The AV program is not a part of windows, so each one has a slightly different user interface, but what you want is to do a complete or in-depth scan.
If you suspect you have a problem with malware, I recommend you follow at least the first four steps of this malware removal guide.
Using MBAM to scan your system will often detect and remove problems your AV may have missed. It is one of the front-line tools in the parasite fight, used by experts and novices alike.
If you have any trouble, write back with the details and we'll be happy to walk you through it.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 10, 2009 | Microsoft Windows Vista Ultimate Edition
Acer Aspire 6930-6455 Notebook Logo
27 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
