Question about Samsung UN40C6300 TV
The picture is much lighter on the left side of the screen than that on the right
    Top Expert:
  • Samsung Master
  • 14,553 Answers
This set uses two boards--one for right half and one for left---different names used for different models like inverters, sustain, etc---Google the model number with parts-----there are a few sites that by model list and show all the boards used which they also sell.
Posted on Nov 07, 2012
How can I troubleshoot a video issue? I would like to know if it is the LCD panel or T-Con board.
You have to replace the TCON board to confirm the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 23, 2016 | Televison & Video
The picture is much lighter on the left side than the right
all use 2 boards: one drives each side of the picture---a Google search of the model with "parts" will reveal the location and photos of the boards this set uses by model number.
Nov 07, 2012 | Samsung UN40C6300 TV
I have a Polaroid 40" TLX-04011C. The screen resolution is fine except for about a 4" area along the right side from top to bottom. This area is lighter than the rest of the screen. The picture is still...
I have not repaired this particular model. But I have repaired another polaroid flat screen TV. I can tell you for sure, the biggest problem here are bad capacitors in the signal board. You may find 15 or 20 bad caps. On the power supply there may be a two or three caps that need replaced as they will be weak but not real bad. Yes,the majority of the caps will be found in the signal board. You will need a good capacitor checker to locate these. It will require patience and skill to remove and replace these caps. I cannot say enough of bad capacitors in this TV. Find a TV tech to help you! Thanks for asking, show me a few hands of appreciation. This answer is your best effort for repair!
Sep 19, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Kitchen scales & weights
Hope this helps,plz let me know
JonnieC
Weighing 1
006s1.gifWeigh 1 2 3 on the left and 4 5 6 on the right
If the weights are even go to Weighing 2a
If the left side is lighter go to Weighing 2b
If the right side is lighter go to Weighing 2c
Weighing 2a
006s2a.gifWeigh 7 on the left and 8 on the right
If the left side is lighter then weight 7 is the answer
If the right side is lighter then weight 8 is the answer
Weighing 2b
006s2b.gifWeigh 1 on the left and 2 on the right
If the weights are even then weight 3 is the answer
If the left side is lighter then weight 1 is the answer
If the right side is lighter then weight 2 is the answer
Weighing 2c
006s2c.gifWeigh 4 on the left and 5 on the right
If the weights are even then weight 6 is the answer
If the left side is lighter then weight 4 is the answer
If the right side is lighter then weight 5 is the answer
Mar 16, 2009 | Nintendo Professor Layton & the Curious...
Where is the fuse for the cigarette lighter socket?
under the left panel beneath the steering wheel is the fuse box. fuse #2 which is the first switch in the middle row is for the cigarette lighter.
Feb 27, 2009 | 2000 Volvo S40
Picture discoloration to left and right of screen.....
Hi! Guy,
This sounds like the G2 may not be properly adjusted, providing too much beam current.
This will some times cause feather edging, or lighter than normal raster on some scenes. This set should be serviced by a qualified service tech.
Toprol
Oct 10, 2007 | Philips 55PW9363 55" Rear Projection...
Side shadows on picture
it sounds as if there are speakers to close to the tv or the built in speakers are not magnetically sheilded properly (maufacturer defect) if u have or have ever had speakers on the left and right side of your tv then the magnets in them will discolor and distort the screen. sometimes even long after the speakers have been moved away from the tv it will still look that way. you may try going to the library( or online )and looking in tv repair books on how to build a homade degauser unless your tv has that feature built into it in the menu somewhere like some computer monitors do. I had placed the front speaker of a 5.1 surround sound system on top my tv and it cuased that same problem, but i found out that by placing a small round magnet with a hole in the center on top of the tv (after removing the speaker for good) right where the discoloration was.. had to flip it one side or the other to get proper effect...it immediatly took away most of the discoloration and over time it disappeared. I hope this helps. Please email me at agclay777@comcast.net as to your conclusion in case it will help others. thanks, Adam
Oct 10, 2007 | Philips 51PW9303 51" Rear Projection...
Samsung UN40C6300 TV Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
