Question about Microsoft Windows XP Professional
" windows cannot find 'regsvr.exe'.
Hi as soon as I login I get a message " windows cannot find 'regsvr.exe'.Make sure you typed the name correctly,and then try again.To search for a file,click start button,and then click search. " Before I got the same and you guies have sent me a solution to run a micorsoft malicious remove tool. I did and it worked well but now again few days back by mistake I double clicked some folder type application and my system once again got affected and now after running that malcious remove tool and restart my system it still shows the same error as soon as I login. Please help me
  • Sree Prakash Allu Jan 05, 2009
    hii I did that but I still get the message. Should I change General settings in msconfig. For my system it showed Selective Startup, so I changed it to Normal Startup and restarted my system and yet it didn't solve my problem, I still get that message after logging in.
  • Anonymous Jan 30, 2009
    Windows cannot find regsvr.exe. Make sure you typed the name correctly, and then try again. To search a file, click the Start button, and then click Search"
  • 3 Answers
Regsvr.exe file is a virus. In order to remove the startup error message you need to change a registry value using registry editor. the solution in detailed steps with screen shots is given in the site below:
http://techrena.blogspot.com/2009/03/remove-windows-cannot-find-regsvrexe.html
It is a simple one and it worked for me, hope it works for u also.
Posted on Mar 06, 2009
Goto Run-> Hey_LOCAL_MACHINE->SOFTWARE->MICROSOFT->WINDOWSNT->CURRENTVERSION->WINLOGON-> In the Panel U Can see the Key Name SHELL Check it if u find two keys means 1)Explorer.Exe 2)Regsvr.exe(after Just a Space)
Just Delete the Regsver.exe
Plz be careful keep ur system restore point
Create a Restore Point and do it its my soultion to this ERROR Its wworked in my SYSTEM
I am not resposible for your System Crash.
Posted on Feb 27, 2009
    Sergeant:
  • 191 Answers
Type in run "msconfig:
then go to starup then disable all.thenrestart the system.thats all dear .
Posted on Jan 05, 2009
My program file regsvr.exe delete.How restore this
Dear Amartya,
Here is a solution for your problem.
What the regsvr.exe virus does?
• This worm creates folders and a registry entry to enable its automatic execution at every system startup.
• This worm also creates a scheduled task to enable its automatic execution at a specified date and/or time.
• It also creates Autorun.inf file for its auto execution.
Solution to fix the problem:
1. If the task manager and registry editor is disabled then we need to enable them first. Read this post.
2. Delete the Autorun.inf file created by the virus. Read this post to know how to do that.
3. Now type msconfig in the Run dialog and click on startup tab.
4. Look for regsvr and uncheck any options, click OK.
5. Now traverse to control panel -> scheduled tasks, and delete the At1 task that might be listed there.
6. Type regedit in the Run dialog to open the registry editor.
7. Click on Edit -> Find and search for regsvr.exe
8. Just delete all the occurrences of regsvr.exe virus (do not confuse it with regsvr32.exe which is not a virus).
9. Navigate to entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon and modify the entry Shell = "Explorer.exe regsvr.exe" to delete the regsvr.exe from it.
I think it helps.Let me know
Best regards
Chandrashekahr Bhat
Dec 25, 2010 | Microsoft Windows XP Professional
I think i have a worm on my pc. my folders are duplicating with a .exe. pls help
TRY RUNNING SUPERANTISPYWARE i have used this program it works very well for removal of all varients and other little pesky varmint on your pc.
Jan 26, 2010 | ASUS Eee 4G Notebook
Cannot find gphone.exe
gphone.exe is a virus that affect google talk or yahoo messenger, to remove it you can download a copy of Eset antivirus.
You could have the same error after the antivirus removal but now the system is clear and you have to delete gphone.exe from your startup files list: start -> run -> msconfig -> go to startup and uncheck gphone. This should help you.
Jul 18, 2009 | Microsoft Computers & Internet
Regsvr.exe not found please help me
This is your problem i think: Windows cannot find 'regsvr.exe'.Make sure you typed the name correctly,and then try again.To search for file,click the start button,and then click search.
Most likely you had a virus that installed a Regsvr.exe reference into your Windows registry. If it shows as "missing" at start-up it's because your anti-virus software removed the program but not the reference. You need a registry cleaner tool like CCleaner. It's a free tool that can be used to clean both your registry and delete junk files from your hard drive.
I found a few things you can do: 1. http://tandt-u.blogspot.com/2008/11/remove-regsvrexe-virus.html
2. Just Google CCleaner - download and run it.
3. I found a site. just follow thes steps: http://amiworks.co.in/talk/how-to-remove-new-folderexe-or-regsvrexr-or-autoruninf-virus/
4. I found (maybe) the soultion.you got the error at startup say that regsvr.exe not found.
Plz find the process how to remove this error
Goto-> RUN-> Regedit->HKEY_LOCAL_MEACHINE->SOFTWARE->MICROSOFT->WINDOWS NT->CURRENT VERSION->WINLOGON->in the reght side panel u can see the key SHELL -> in that key u if u see the two names (Explorer.EXE Regsver.exe) plz delete only the regsver.exe(plz do not remove the explorer.exe) Just Press OK
PLZ BE CARE FUL WHEN UR DOING THIS UR PLAYING WITH SYSTEM FILES PLZ DO NOT REMOVE ANY OTHER KEYS
IF ANY SYSTEM CRASHES I AM NOT RESPOSIBLE
PLZ CREATE A SYSTEM RESTORE POINT BEFORE DOING THIS
if you find it difficult, i found a site with the same steps but with screenshots: I found the soultion for the same. http://techrena.blogspot.com/2009/03/remove-windows-cannot-find-regsvrexe.html
I hope it works for you. And please rate
Jul 08, 2009 | Microsoft Computers & Internet
When I open computer a message displayed cannot find regsvr.exe
Hi there.
You have a virus on the PC!!
2. Delete the Autorun.inf file created by the virus. First go to cmd (start menu, run or search, type “attrib X:Autorun.inf –s –r –h” without quotes where X is your drive name which is having the problem. Now the file is visible and ready to delete. After deleting the file, close the explorer and open it again
9. Navigate to entry HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionWinlogon and modify the entry Shell = “Explorer.exe regsvr.exe” to delete the regsvr.exe from it.
shell_regsvr.jpg10. Now to actually delete the virus from the system go to system32 folder and delete the regsvr.exe virus file from there (you will need to uncheck the option of “Hide Protected System Files and Folders” in Folder Options to view the virus file).
Reboot the system for changes to take place.
If this is too much for you to understand please post back for an alternative.
Good luck
May 27, 2009 | Microsoft Windows XP Professional
Windows cannot find 'gphone.exe'
Gphone.exe is worm which spreads via instant messengers. It usually affects Yahoo! Messenger and Google Talk applications. Gphone.exe send a message and invites victims to visit a website. If clicked upon, the link actually delivers a copy of Gphone.exe infection.
Most likely you have a security program that detected and removed the threat but windows is still trying to load the file on startup, thankfully it isnt able to because the threat is gone so windows is displaying that error message to let you know it was not able to load the file.
Go to Start > Run> type "msconfig" and press enter. click the startup tab and uncheck the box that says "gphone.exe". (it may have a long file or folder path in front like c:windowssystem32).
Go to this website if you need further removal instructions:
http://www.spywarevoid.com/remove-gphoneexe-gphoneexe-worm-removal.html
Jan 21, 2009 | Computers & Internet
Error in application download due to regsvr.exe is missing
Window is asking about Regsvr.exe file at the start up.
Dec 26, 2008 | Microsoft Windows XP Professional
Common Language Runtime and Windows cannot find 'regsvr.exe'
This is malware! Never click on an executable file that you do not know as you activate a worm or virus by doing so. A quick google search of the file name is prudent if you do not know what that file is. Now you should download the Windows Malicious Software Removal Tool from Microsoft here: http://www.microsoft.com/security/malwareremove/default.mspx Let me know if you need further help. Steve
Dec 19, 2008 | Microsoft Windows XP Professional
Whenever I start my system I first get an alert before login of profile as "crmgoldbpe.exe - Common Language Runtime Debugging Services Application has generated an exception that could not be handled....
click start -> run. Type msconfig hit enter. Goto the startup tab and look for anything containing crmgoldbpe.exe and uncheck the box next to it. Restart your computer. The error should be gone. This is part of a spyware program so you should also run an anti-spyware program such as spybot search and destroy from www.safer-networking.org.
Cannot find regsvr.exe
Download and run this:
http://piyushlabs.googlepages.com/Heal_regsvr1.0.zip
BTW...it's a virus you have. It will get worse if you don't clean it or restore your computer.
Oct 24, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional Logo
1,784 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
