Computers & Internet Logo
Anonymous Posted on Nov 06, 2012
192.168.1.1 i need tp reset my password
Anonymous
Level 3:
  • Master 2,878 Answers
  • Posted on Nov 07, 2012
Anonymous
Master
Level 3:
Answers
2878
Questions
0
Helped
488119
Points
8243
Look for and hold reset on router till cycles. This will clear most custom settings.
Vague details result in vague answers. GL
1helpful
Is there a default password on the hs107 smart plugs
Unsure if this free manual and FAQ is for the same product or not.
https://www.tp-link.com/us/support/download/hs107/
https://www.tp-link.com/us/support/download/hs107/#FAQs
https://www.tp-link.com/us/support/faq/802/
Quoting from link above: " What can I do if I forget my password of TP-Link Cloud account?
User Application Requirement Updated 05-27-2019 03:04:51 AM22539
This Article Applies to:
Our tpCamera app and Kasa app are based on TP-Link cloud, so they are using the same account which is TP-Link Cloud account.
Note:This FAQ is suitable for all TP-Link cloud cameras such as NC450 and NC260, and also suit for kasa device such as HS100, LB200 and KC100 etc.
If you forget your password of TP-Link Cloud account, please follow the steps as below.
For tpCamera APP:
1. Tap "Forget" in the home page of tpCamera app.
2. Please input the registered email address (very important) of your cloud account, and tap ">" icon, then you will receive an email which will guide you to reset the password.
3. Open the email, click on "Click to Reset Password", it will lead you to a reset password page in our TP-Link cloud website.
4. Input your new password for your cloud account and confirm password, then click "Save", you have finished password reset steps.
Now you can login your tpCamera app with your new password.
For KASA APP:
1. Tap "Forgot Password" in the Login page of Kasa app.
2. Please input the registered email address (very important) of your cloud account, and tap "Reset Password", then you will receive an email which will guide you to reset the password.
3. Open you email and click on "Click to Reset Password", it will lead you to a reset password page in our TP-Link cloud website.
4. Input your new password for your cloud account and confirm, then click "Save", you have finished password reset steps.
Now you can login your Kasa APP with your new password.
In our cloud website:
1. Go to www.tplinkcloud.com, on the login page, click "Forget password".
2. In the page below, type in the E-mail address you used to register the cloud account and click OK.
3. Then website will send an email to you as well, which is the same with the guide when using tpCamera app or Kasa app, you can follow the guide to create a new cloud password for your cloud account.
How To Fix TP-Link device Can't Log Into Web Management Utility Issue ?
You need to reset your TP-Link.
Before resetting it, you must know your subscription username and password from otherwise you will lose your internet.
1helpful
How do i change password for tp link wr741nd
If it's the security key just login to the router and change the password. If it's the password to login to the router UI you will need to reset the router to factory settings.
Modem error codes17002
Try resetting it, see this... http://setuprouter.com/networking/how-to-reset-your-router/ , then try the default Username & password... http://setuprouter.com/router/tp-link/passwords.htm
2answers
I cant remember the password of our wifi pls help here's my email...tnx!
You can reset to factory default by pushing and holding the RESET button for 30 seconds or so, release, that will restore the device to the factory default settings. Connect and reconfigure the SSID and Security Code. You may want to write down the Password for future use, just a thought. For info: http://www.tp-link.com/Resources/document/TL-WR740N_741ND_User_Guide.pdf
Cannot access my tp link TL-WA601G 108M Wireless Access Point
Use the Factory Default Reset button: First, turn off the AP's power. Second, press and hold the default Reset button then turn on the AP's power, until the system LED lights up (about 3 seconds). Last, release the reset button and wait for the AP to reboot.
Reset the factory defaults.
Here is your user manual:
http://www.tp-link.com/english/soft/20091515618.pdf
Default username and password is admin for both
10helpful
2answers
How to recover the password for 198.168.1.1
You will need to reset it then it will come to default
password. unplug power cable then while powering on press the reset button simultaneously.
ok
A user name and password prompt will appear. Type in admin (lower case) for the username and password. The username and password admin are the default username and password of TP-LINK Routers.
ok link
http://www.tp-link.com/support/showfaq.asp?id=10
I forget user name and password
These are the default settings:
When the login window appears, set the user name to Admin and leave the password box empty. If this doesn't work, you may also try admin for both username and password (all small letters).
If the default doesn't work, you may reset the password by pressing the reset button for 30 seconds. This will bring the router to factory default settings (including all the configurations set on the router).
Hope this helps.
2answers
Clarification on the router configuration
The defaults are:
username: admin
password: admin
To reset, hold the reset button for 10 seconds without powering off.
Here's the website, just for future reference:
http://www.tp-link.com/support/download.asp?a=1&m=TL-R402M
Hope this helps
Chris (ziraffa)
Grand Canyon Tech
Grand Canyon Tech
