Question about HP Deskjet F4180 All-in-One InkJet Printer
My printer HP F4185 doesn't print but it scans and copies...
The printer is well installed but it doesn't display in the printer and faxes. but on my taskbar it states that the printer is installed and ready to use..
  • Angelattony Jan 17, 2009
    I HAVE BEEN TRYING TO PRINT OUT SOME VERY IMPORTANT DOCUMENTS AND MY HP ALL IN ONE PRINTER (4100 SERIES) DOESN'T WANT TO PRINT. THE ONLY THING THAT IT WILL DO IS COPY AND SCAN!
  • Anonymous Jan 23, 2009
    my printer will not print
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
My printer scans, copy but won't print from computer?
Did you set this printer as the default printer? To do this go to Start - Printer and Faxes, right click on HP printer, select Set As Default Printer. If you are not see your HP Deskject F340 there, that mean your printer driver is not installed. Please install your printer driver.
If you already set it as the default and it is still not printing. Restart your computer to try solve problem.
You said that printer scans so the connection between your computer and printer is fine. Problem is your computer doesn't take the printer as it's printer device yet.
Hope this will help. Thanks for reading
Jul 19, 2011 | HP Deskjet F340 All-In-One Printer
I can't get my HP potosmart C6180 ALL IN ONE PRINTER TO SCAN/COPY OR FAX WITHOUT GETTING A SCANNER FAILURE MESSAGE SAYING UNABLE TO SCAN,COPY OR SEND A FAX
Solved! I now can scan wirelessly throughout my network. I downloaded the drivers for a friends newer HP all-in-one scanner and I can scan. Look for the driver for the 309a series of printers and install it. Complete the install and set up your existing printer. You can now scan, print, fax wirelessly. It includes updated HP apps for these functions that work with OS 10.5. I didn't upgrade to the HP 1.1 drivers through Apple. The file name is: PS_AIO_05_C309a_Net_Full_Mac_WW_102.dmg
May 24, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hp 4355 reports no scan option when running under windows 7 It will copy to the printer
There is a workaround. As you no doubt know, windows 7 doesn't install HP solution center. So, to get a scan from your printer, or to send a fax etc,. you need to go to start > All probrams > Windows Fax and Scan.
From this program you gain all the functionality of your printer/fax/scanner, however the scan buttons do not work on the printer.
Nov 16, 2010 | HP Officejet 4355 All-In-One InkJet...
The scanner won't scan to the computer, but when I test it in scanners & cameras it says it is working.
This is my solution :
1st step : Turn on your *HP Deskjet F4185*.
2nd step : Click the Start menu.
3rd step : Click Devices and printers. A new window will appear.
4th step : Then, click the "Fax button ".The window Fax and Scan window will appear.
5th step : On the lower left corner , click "Scan" below the "Fax" button.Scanned documents (if there's any) will appear.
6th step : Click "New scan" button below the "File" button. And your printer will start! Glad to help..
Mar 29, 2010 | HP DeskJet F380 All-In-One Printer
IseMY Hp all in one 4355 printer is unable to scan
The HP Officejet 4355 can print, scan, copy and fax.
You need to install the printer software to print and scan. Copy and faxing does not required software installation.
Regards,
Rizwan
Feb 11, 2010 | HP Officejet 4355 All-In-One InkJet...
Scanner not working. HP deskjet f4185.
Aug 26, 2009 | Office Equipment & Supplies
Cannot scan with hp deskjet f4185 because....
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3177566&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB - here u can find the software
If helped rate fixya
Mar 07, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Hp deskjet f4180 all in one
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
Feb 15, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
SCAN,COPY,FAX PROBLEM
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.     Here is a manual if you dont already have one.   http://h10032.www1.hp.com/ctg/Manual/c00486336.pdf
Oct 26, 2007 | HP Photosmart 3310 Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
137 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
