Question about JRC Richesons Unison Premium Surface Terra Cotta 140lb Paper 8x10 Inch Sheet ()
The bungee running through the poles on my jrc contact bivvy has snaped
This is the first section of the rib system, i just need to replace the bungee cord that runs through the aluminum poles
2 Suggested Answers
info76389
SOURCE: Hello, I need a power cable for my JRC 1000. How
Dear friend
I have few cables which can be used for JRC1000.
mail me on info@marinemarket.in
Posted on Jan 28, 2013
HOW CAN I REPLACE THE ELASTIC CORDS,ON MY SHOOTING STICKS?
Rafael, I am not aware of any camera repair station that will do this...., but as these tripods use the same type of bungee materials as tent poles..., I would contact a company in your area that does repairs on backpacking tents. I suspect that they can probably fix this for you.
Oct 04, 2014 | Stoney Point STON F2B33R1X FLDNG BIPOD...
Tesco 6 Person Vis-a-Vis Tent Instructions
Whoever they employed to write the instructions should be shot or go back to kindergarten....how difficult can it be?
Anyway, this tent is relatively easy to put up IF you know how to do it...which the instructions are painfully inadequate. It (un)helpfully uses colour coding on black and white print out and not explaining which way around the longer/shorter poles should be. Actually, once the poles are in, the instructions are ok....but it is a major point and wastes a shtload of time.
There are 2 LONG (well, slightly longer) poles, with a yellow sticker on the end (which comes off after 1 use of the tent). Start on one side of the tent with 2 poles (one longer, one shorter). Slide the long pole into the inner rib (ie towards the middle of the tent), then put in the shorter pole on the outside rib (i.e.the furthest away from the middle). You do need some grunt to force these into place, but at least they go (they won't if you put the wrong pole in the wrong slot). Then do the other side of the tent, longer first (inside), shorter second (outside). Then just pin everything else together like the instructions show.
The tent is ok, just ok, not great, not terrible, although it is pretty terrible in the wind, but what do you expect for 60 quid.
Jun 24, 2012 | Sport & Outdoor - Others
How do I put the saw on the pole
1. Remove battery from chain saw.
2. Separate main handle from chain saw
power head by pressing both release
buttons on main handle and pulling
apart. The release buttons are just in
front of the trigger.
3. Align rib on chain saw power head with
groove in power head adapter on pole.
4. Slide power head into power head
adapter until units "snap" together.
IMPORTANT: Both release
buttons on power head adapter must be
fully engaged.
5. Align rib on handle adapter on pole
with groove in main handle.
6. Slide main handle into handle adapter
IMPORTANT: Both release buttons
on main handle must be fully
engaged.
7. Slide battery onto main handle until
release buttons "snap" together.
Be sure the battery is charged.
To extend the pole:
1. Loosen the clamping
lever. Pole will slide
freely.
2. Pull inner pole section out to desired
length of extension.
3. To lock pole in position, tighten clamping
lever.
Sep 12, 2011 | Remington Cordless 18-Volt 8-Inch Cordless...
Hello there,
I also need this very same power cable. Did you find one already? maybe you can tell me wich one of the 7 input connections is the + and - DC power connection so I can connect this thing myself with a home made power cable. Greetings. Stan (holland)
stanvanroermund@hotmail.com
Thanks!
Oct 03, 2009 | JRC 1000 MKII Radar GPS Receiver
Trampoline bungee broke and I need to buy a replacement.
Hi ajrother...
Amazon provides many products, so take a look there. This one can help you Upper Bounce Replacement Elastic Bungee Cords for Trampoline Jumping Mats... (If fits of course).
Also you can contact the seller if helps. Hope this was helpful. enjoy
Oct 02, 2009 | Galt Folding Trampoline
Of the two main poles one of the sections has developed a split that now exceeds half-way. Have used tape to hold it together but need to make a replacement before long.
Try using small radiator clamps for now until you get time to order a replacement pole. You might want to order 2 it may be cheaper in the long run.
John
Oct 01, 2009 | Eureka Sunrise 9 Tent
I have a JRC NWZ4550 GPS. I've only used it once, I entered 3 way points and the system worked fine. Satellites lock on, all ok. I did a soft start, cleared the system, then started entering my way points....
If you are running a 4310 aerial with this unit the aerial ran out of date sometime in August 2008. You will have to buy a jrc 124 aerial. I had the same problem. Check with the agent TMQ International.You will find that the unit won't keep the date you have entered in it to set it up, it goes back to the year 1989 on the satellite page.
May 12, 2009 | JRC GPS
JRC Richesons Unison Premium Surface Terra Cotta 140lb Paper 8x10 Inch Sheet () Logo
46 people viewed this question
Top JRC Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a JRC Winter Sport Expert? Answer questions, earn points and help others
