Question about TDK (CD-RW74HSFXS5) Storage Media
My PC does not read my 16GB TDK usb flash drive
  • TDK Master
  • 27,725 Answers
W7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp or earlier
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
hope it helps
Posted on Nov 07, 2012
My pc opening flash but my all file went ?
Posted on Jun 08, 2013
USB formatted or broken?
The most common reason is that your data on it lost.
Why not try recovery tool?
For example, 4Card Recovery, a very powerful recovery tool.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Posted on Apr 30, 2014
Hello, the problem is that your data on the USB flash drive hhas lost so your PC can not recognize it. You can use recovery tool to restore your data. Such as 4Card Recovery, which is very strong recovery software. Pay attention to it, do not cover your old data by new things.
Posted on Apr 02, 2014
4 Suggested Answers
laikexpert
  • 281 Answers
SOURCE: TDK usb flash drive 8GB can not hold more than 5GB
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format Flash Drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 08, 2010
AmitGoku
  • 125 Answers
SOURCE: service center of TDK USB flash drive 8gb
This flash drive is good
Posted on Oct 18, 2010
  • 8 Answers
SOURCE: Only 5GB on TDK TRANS-IT USB 2.0 Flash Drive 8GB
Not the solution you might like but there have been reports of bogus/ counterfeit smaller capacity sticks/drives relabeled and programed to report higher capacities. I've been told that running a formatting/partitioning application on them reflect the true capacity but have not had to try this solution myself..
Submitted for information only but please rate so I accumulate a lot of unanswered solutions, Thanks
Posted on May 11, 2009
I formatted my TDK 16gb udb drive and now my win7 does not recognize it at all.
Please check if it behaves the same on another computer system.
Otherwise reformat it again with FAT32 or NTFS format.
Nov 27, 2016 | TDK Electronics - Others
How to install tdk 16gb flash drive install
Just plug it into any usb the system should see it and mount it to your drive list.
Aug 13, 2014 | Electronics - Others
Is it ok if my PNY 16GB flash drive is flashing red but working fine?
You should first read the documentation to see exactly what the flashing read light means. It could mean that the drive is near full capacity. Try removing/transferring a few files to your hard drive to see if the flahing read stops. As long as it works ok, I wouldn't be too concerned.
Jun 24, 2014 | PNY Attach? 16GB USB 2.0 Flash Drive
My pc with W7 does not see the flash-drive in my usb-port.
Do you have a proper antivirus program (NORTON , AVG , KASPERSKY) cos sometimes due to viruses and cookies filled computer can not detect a usb ...
Jun 18, 2014 | TDK (CD-RW74HSFXS5) Storage Media
I can't add files to my 16gb TDK gold flash usb drive. I can remove them. even when there are no files in the folders at all, the info tab says it has stuff on it. so i looked for a 'format' tab and...
Try RMPrepUSB - Quick Size Test (it will destroy all data but test the drive) or FakeFlashTest. If it tests OK, reformat using RMPrepUSB - Prepare Drive.
Oct 25, 2013 | TDK Electronics - Others
Please insert disk into removable disk
have you tried other a different flash drive of something like a usb charger etc? If it works then then the problem is with the flash drive, if not them its with your USB port
Apr 28, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
I copied all of my data to 16gb tdk trans-it flashdrive.and when i wanted to work with my files it says insert disk in removable drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Mar 08, 2012 | TDK Electronics - Others
16GB Toshiba Flashdrive can no longer be read by my PC what can i do pls
try to read flash on another system if it reads ok, problem is with your sytem if not reading needs to be formatted and should work ok.
Jan 11, 2011 | Toshiba 1GB USB 2.0 High-Speed Flash Drive...
Mar 15, 2009 | TDK (MF2HD50PK) (50 Pack) (TDKMF2HD50PK)...
TDK (CD-RW74HSFXS5) Storage Media Logo
3,695 people viewed this question
Top TDK Electronics - Others Experts
 Grubhead
Grubhead
Sandy Moore
Sandy Moore
Jim Goldsmith
Jim Goldsmith
Are you a TDK Electronics - Other Expert? Answer questions, earn points and help others
