Question about Panasonic KX-TG2740 Cordless Phone
My Panasonic KX-TG2740 will not keep correct time. It revert back to Pacific time from Eastern Standard Time. Help me Plaese.Thank You,Jerry Mays. Since the time never worked. you owe me to fix this problem not me pay you to fix your bad equipment. Do I have to get the BBB involved to get the problem FIXED? eMail me at jer77ry@yahoo.com within 24hrs. 2009 is not getting off to a good start, is it?
  • Anonymous Feb 10, 2009
    My Panasonic phones won't keep time either.
5 Suggested Answers
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
  • 4 Answers
SOURCE: Panasonic Kx-t7456 digital super hybrid system time setting question!
step 1 press "program" button, then **1234
step 2 enter 000
press next (or spkr phn button) for date
press next (or spkr phn button) for time
press fwd/dnd button
press fwd/dnd button again
press sel (or auto answer/mute button) to change am/pm
press store (or auto dial/store)
press end (or hold button)
press spkr phn button or pick up hand set and hang up to leave programming mode.
Posted on Jan 29, 2008
SOURCE: Panasonic KX-T7456 Corded Phone - Date & Time Display
The display on the phone ... to change back and forth between the date and time, and the extension information, press the "star" (or asterisk) key while the phone is on-hook, this will toggle the display back and forth.
Hope this helps, David B.
Posted on Mar 23, 2008
  • 108 Answers
SOURCE: Panasonic KX-T7436 - time/clock
Hi Juliana, to set the time and date you leave the handset on-hook, Press program * * and the user password ( default 1 2 3 4 ), display shows USR - PGM NO?, dial 0 0 0, press next, enter 2 digit year ( to change current entry press clear ), press arrow pointing to the right, press select until month is displayed, enter month, press right arrow, enter day, press right arrow, press select until day of week is displayed, press store, press next, enter hour, press arrow, enter minutes, press arrow, press select for am or pm, press arrow, press select for 12 or 24 hour format, press store, press end. Let me know how it goes. ...Mike
Posted on Aug 13, 2008
SOURCE: Panasonic phone KX-TG2740: instructions
I downloaded the instruction manual, based on someone else's solution to a different question about the same product.
Posted on Dec 17, 2008
Setting time for EST
IFM. If you don't ever get any phone calls, I imagine it would keep the correct time. So, call whoever is sending the time and tell them to adjust the clock for your region. In my case, It was an offset in the 8x8 box.
May 13, 2014 | Panasonic KX TGA641 Cordless Phone
At&t cl82401 date and time
I have the same question for my AT&T CL83212 cordless phone. I set the time, but when a call comes in the time reverts to 3 hours back - Pacific Time. We are Eastern Time. I called AT&T &
was send a new Uverse modem (???) - that did nothing. I am ready to return the phone.
Apr 20, 2013 | AT&T ATT CL82401 DECT 6.0 Digital...
Time reverts back 3 hours to DST
make sure unit is set for your "time zone" The adjustment button for pacific, central and eastern time zones is located on the back. Push the button until your specific time zone is reached.
Oct 29, 2011 | Eddie Bauer Wireless ClockThermometer
WhAT IS THE PRICE THE MODEL.KX-TG2740?.
Welcome to FixYa.
New = Unfortunately, there are no more new items for this phone. Used = $48.99 - $119 available at www.AMAZON.com (Good Condition) Refurbished = $127.99 - $129 available at www.AMAZON.com (Good Condition)
Thank you for sing FixYa.
Have a great day.
Jas247
Jun 16, 2011 | Panasonic KX-TG2740 Cordless Phone
How to set the time on Caller ID
Panasonic KX-TG2740 user manual is available in the following link,
http://www.fixya.com/support/p123254-panasonic_kx_tg2740_cordless_phone/manual-7363#
Page 20 contains the details about setting the date and time.
Page 40 contains the details for the caller ids service.
Good luck :)
Jun 07, 2010 | Panasonic KX-TG2740 Cordless Phone
How do you set the alarm for pacific standard time on the emerson
Here is the procedure for setting the time zones for your Clock/Radio. Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time I will give you the web link for the owners manual so you can find any other information you might need for your Clock/Radio. (http://www.emersonradio.com/owners/iPod%20Series/iC200_042007.pdf) copy this web address and paste it in the address bard of your browser and it will take you to a pdf copy of the owners manual. I hope this information help you with your problem.
Apr 27, 2009 | Emerson Smartset Clock Radio
Good Evening! I would like to have some assistance in regards to the Panasonic Cordless Phone Model No.KX-TG1033C. Here's my concern: Set Date & Time My boyfriend has given me the above-mentioned phon
Hello
Please note that I have not received a reply to my question. Also the product in question is the Panasonic Cordless Phone Model No. KX-TG1033C and NOT KX-TG1032S as posted on my request.
In any case I still would like to know how to cancel and delete my profile.
Thank You
Montsie
Apr 15, 2009 | Panasonic (KX-TG1032S) Phone
Dec 16, 2008 | Panasonic KX-TG2740 Cordless Phone
Time Zone Setting
Sorry it took so long to give you a answer to your problem. I hope this information help you with the problem. Thank you for using FixYa and have a nice day! Setting The Time, The First Time IMPORTANT: The first time you connect your new SmartSet® clock radio to the AC outlet the internal computer will automatically set the time correctly for the Eastern Time Zone, which is the initial default setting. The display will scan for a few seconds and then show the correct Day and Time in the Eastern zone. If you live in the Eastern Time zone, there?s nothing else to do. Your clock is set correctly and running. If you do not live in the Eastern Time zone you must change the default zone display to your own zone. You only do this one time and the SmartSet® will remember the new default zone setting and will always return to that setting after a power interruption. There are 7 time zones programmed into your SmartSet® clock radio as follows: ZONE 1 ? Atlantic Time ZONE 2 ? Eastern Time (Default Setting) ZONE 3 ? Central Time ZONE 4 ? Mountain Time ZONE 5 ? Pacific Time ZONE 6 ? Yukon Time ZONE 7 ? Hawaiian Time To change the default time zone display, depress the Time Zone button. The number ?02? will appear on the display indicating that the default zone is ZONE 2, Eastern Time
Nov 04, 2008 | Emerson Smartset Clock Radio
Honeywell RC182WB Atomic Alarm Clock with Temperature--stuck on pacific time!!!
I KNOW HOW TO FIX IT!
Take off the battery cover, and take the batts out, leaving the outside thermometer working...
You will have to reset everything but it automatically detects your time zone!
I just did it literally 2 minutes ago!
Nov 23, 2007 | Honeywell RC182WR Atomic Alarm Clock - Red
Panasonic KX-TG2740 Cordless Phone Logo
2,179 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
