Question about Carrier Bryant Furnace Control Board HK42FZ017
Need help installing new control board on a carrier 58CTA090-16
Technician diagnosed the problem to be the control board. At the time I did not have the money at the time to repair. The technician rewired the board so I could manually get the fan on. I have the new control board now but not sure how to get the wiring back to the original with the new board
2 Suggested Answers
relaga58
  • 158 Answers
SOURCE: condensor fan not running after replacement
check fan rotation
Posted on May 31, 2009
What does F70 mean on a front load dryer?
Hello Carol;
My name is Peter. I am a retired field service appliance technician.
F70:
No communication between the electronic control board and the user interface control board assemblies.
Unplug the dryer. Check the wire harness connections between the main electronic control board and the user interface control board assemblies. If the connections are sound, have a technician diagnose the cause of the communication failure. The main electronic control board and/or the user interface control assemblies might need to be replaced.
Dec 06, 2014 | Whirlpool Dryers
What to do with err code e5e? help
Hi Friend, this is Z. Thank you for your question!
Typically error code E5E indicates that your Frigidaire washer is experiencing a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair your washer. Typically, a technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However if the wiring is good the main control board may need to be replace or if the problem is not corrected, the speed control board is possibly faulty.
Jul 10, 2014 | Frigidaire ATF6000ES Front Load Washer
Code 24 on carrier weathermaker 8000ts
Turn power off to unit. Open air handler and take a picture of the low voltage (tstat) wires and where they are landed. Remove all thermostat wires from control board. Then replace the 5 amp fuse that is likely on the board. Fuse likely looks like one for a car (blade style). Put a jumper (small piece of wire) from the R terminal to the G terminal and turn power back on to unit. This should bring on the indoor blower. Let me know how that goes!!
May 12, 2017 | Heating & Cooling
Frigidaire FTF530FS Front Load Washer will not advance through cycles... need to manually turn knob. New timer did not do the trick nor control panel...
Hi Jacquie, thank you for your inquiry! First, when you are referring to the control panel are you speaking about the motor control board? The motor control board advances the timer, and the timer will not advance if it does not sense that the door is closed and securely locked. Therefore, I highly recommend reaching out to an expert technician that can accurately diagnose the motor control board and/or door switch on this particular unit. The servicer will ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this information helps to some degree - thanks for your question, and please do not hesitate to reconnect.
Aug 10, 2013 | Frigidaire FTF530FS Front Load Washer
Kenmore Elite Smartwash Quiet Pak 9. Washing bedding on "bulky/bedding", washer beeps, get error code F then 11. Messed with it a bit, now in Control Locked. Yikes. Help! Robin
Washer will suddenly shows the F11 error code...at times it may show the FdL code. The washer will then not finish no matter what I do. If I unplug the unit from the outlet that does not guarantee that when I plug it back in it will start up. Fifty percent of the time it still shows the F11 error. It can take hours to finally get the washer to cancel out so I can take the laundry out that has not been spun out.
The F11 error code indicates a serial communication problem between the central control board and the motor control board. This can be caused by:
  • A loose or failed wire harness connection between the central control board and the motor control board.
  • A bad wire harness connection between the motor control board and the drive motor.
  • A failed drive motor.
  • A defective motor control board.
  • A failure in the central control board.
The diagnosis of this failure usually requires a technician. If you are able to unplug the washer and safely access the central control board and motor control board, you can check for a loose wire harness connection. Beyond that, I recommend calling a service technician to diagnose and repair your washer. The location of the internal washer components and component access for the central control board and the motor control board are in the images below.
Jan 06, 2011 | Washing Machines
We had a new Carrier Weathermaker Infinity Gas Furnace installed in our home on 9-21-99.The Carrier people said the furnace was in good condition this past October.But prior to that as of April 2010 the...
Your Carrier guys more than likely are Carrier dealers. I would get a second opinion. Most qualified HVAC techs can work on any and all brands. It doesn't need to be a Carrier dealer to work on a Carrier. AND, if they replaced the control board and didn't test the heat, that's a fault on their part. Anytime we change a board or even a thermostat, we check ALL modes and functions. SECOND OPINION!!!
Mar 10, 2017 | Heating & Cooling
Power button beeps three times. Lock button works. Nothing else works.Technician diagnosed microcomputer control board. Replaced board control 8183258. Still dead!- he never called back.......help
Try to unplug power cord for 10 minutes and plug in. If you have manual on hand, follow instruction to find error code on your machine. Please tell problems before it went dead. Thanks.
Aug 10, 2010 | Whirlpool GHW9200L Front Load Washer
Install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Nov 05, 2009 | Carrier Heating & Cooling
System Malfunction, No communication with outside unit
I work on Carrier Infiity systems. The outside board has a Model plug on it. This tells the system what size unit it is. They do go bad. You can reset your self by turning the power off to the Air Handler. These system have 10 year warranty and if you still have a problem have the replace the outside control board and model plug. Also you can contact Carrier on the their website and get answers. You may need to talk to a service rep in your area. Carrier is good about their Tech support. You should have to pay for a service call if you your problem continues. Sometimes power surges or stoem cause these problems but not often Rusty
Apr 26, 2009 | Heating & Cooling
Carrier Bryant Furnace Control Board HK42FZ017 Logo
59 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
