Question about Estate EED4400WQ Dryer
Dryer spins but makesclunking sound when clothes in it
When no clothes in the dryer, spins fine. when even just a few items in it makes clunking sound.
  • 4 Answers
The bushing in the back of the dryer is probley bad. to check and see take the top loose and look on the back of the dryer and see if the bushing is loose or out. to replace it you have to pull the drum. there also could be some screws on the back of the dryer holding it on.
Posted on Nov 06, 2012
3 Suggested Answers
  • 177 Answers
SOURCE: Dryer Drum won't spin
You probably have a broken belt, Are you up for a do it yourself repair? or call a service tech.
Belts cost about $8 on line, buying it from the tech who installs it could cost you $20+ and then trip charge, tech time etc.
Belt replacement is easy for those of us that have done it, getting the belt back on the drum and thru the motor is the worst.
Posted on Oct 02, 2008
  • 4 Answers
SOURCE: ELECTRIC DRYER TEDS840JQ0
its broke retern it
Posted on Jan 20, 2009
My Hoover 5020d dryer will not operate unless there are very few items in the machine at one time.
Hi Gary
The first thing that came to mind was some kind of weight sensor informing smart electronics that something is in the dryer.
Does it sense a heave weight of some kind?
Metal weight have any affect?
Mar 14, 2016 | Hoover Dryers
Hotpoint dryer will spin but stops with only few items in
sounds like you might need to replace the belt
Nov 25, 2013 | Hotpoint Dryers
My dryer (maytag atlantis) has started making a loud clunking noise with each revolution. its still drying fine but sounds terrible. any thoughts?
A loose belt will allow the drum to slip when clothes hit the paddles in the drum. It sometimes sounds like a pair of tennis shoes are in the dryer when it slips and is usually rythymic.
These machines also use drum rollers that can make a racket when they go bad.
http://www.repairclinic.com/Maytag-Dryer-Parts
Good luck.
Mar 02, 2011 | Maytag Dryers
Inteli dry regular cycle, timer gets stuck and won't advance. other cycles work fine. thanks
An unusual noise coming from a running clothes dryer can cause concern, although these noises are rarely indicative of a more serious problem. Once the source of the noise has been located, a few simple repairs or adjustments will usually solve the problem and restore peace to your laundry room.
    Gas
  1. A gas dryer may emit an occasional clicking sound. This noise is caused by the gas valve and is a normal operating sound. The clicking sound coming from the gas valve can not be eliminated and it does not indicate any mechanical problem with the dryer.
  2. Warm Up
  3. A newly installed dryer, or a dryer that has been left unused for a period of time, may exhibit a thumping noise during the first few minutes of the drying cycle. According to the Maytag company, this noise is normal and should not be a cause for concern. If the noise continues for more than a few minutes or repeats on subsequent loads, however, then steps should be taken to locate the origin of the noise.
  4. Clothing
  5. Clothing can become knotted and balled up in the clothes dryer. This can cause vibration or a load thumping noise. When this happens, open the dryer and remove the knotted clothing. Separate the articles of clothing and place them back in the dryer. The thumping noise should not continue unless the clothing has become knotted again.
  6. Vibration
  7. Place your hands on top of the dryer and push down firmly; if the dryer tilts to one side, the clothes dryer is not level. This can cause the dryer to vibrate during the cycle and if the vibration is severe enough, the surrounding walls could be damaged by the dryer. Maytag dryers have four leveling legs installed into holes on the bottom of the dryer. These legs are included with the dryer and should have been screwed into the holes during installation. A wrench can be used to adjust the legs until the dryer is stable and level.
  8. Foreign Objects
  9. Small objects such as coins, buttons, or paperclips can become lodged between the drum and the sides of the clothes dryer. These items usually end up in the dryer after being left in clothing pockets during laundering. Turn the dryer off and remove any clothes to a laundry basket. Allow the dryer to cool down so that you won't burn your hand on any metal surfaces inside the dryer which may be hot. Look inside the dryer and pay special attention to the front and rear edges of the dryer drum. Run your fingers along the grooves where the drum connects to the dryer to locate any foreign objects. These objects could be bouncing around the dryer causing noise during the cycle, and then settling into the grooves when the dryer stops making them difficult to locate. Remember to remove all items from clothing pockets before laundering in the future to avoid this problem.
  10. please comment on these solution on how helpful
Dec 30, 2010 | Maytag SDE5401AYW Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Clunking grinding sound
It sound like there is change or hard object in the inner dryer tumbler fins Not sure what model or make the dryer is need more info please.Maytag inglis??????
May 07, 2009 | Dryers
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Estate EED4400WQ Dryer Logo
57 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
