Sony bravia home button doesnt work - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
If its on the remote it may be dirty inside, if on the set that is a different issue.
If on the remote most of those can be taken apart and cleaned---usually a tiny liquid spill gets inside.
Posted on Nov 07, 2012
My sony tv has a line across the screen that says bx42, full hd1080p, digital noise reduction, usb play, hdmi2, bravia sync, pc input, 24p true cinema and i cant get rid of it.
Hi mike harris,
i think your TV is on demonstration mode.
To turn off the demo mode, press and hold the HOME or MENU button on the TV for more than 10 seconds. The messageDemo mode: Off will appear on the screen.
NOTES:
Mar 02, 2014 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Turn demo mode off on Sony Bravia TV 40"
Here'show to turn off the demo mode,
Power ON the television
(Use remote Commander)
1.Select "TV" mode (not AV, demo mode can't switch offwhen you are in AV)
2. Press the "home" button on the remote.
3. Select "settings"
4. Select "set up"
5. Scroll down to "factory setting" and restore them.
6. When it asks home or shop display select "home".
Feb 14, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Does this model have Bravia sync?
Yes it does per SONY web site:
http://www.sonystyle.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10551&storeId=10151&productId=8198552921665164630&langId=-1#specifications
BRAVIA® Theatre Sync™ technology
Sony® created BRAVIA® Theatre Sync™ to go beyond basic digital audio and video transmission. Based on the HDMI-CEC function, BRAVIA® Theatre Sync™ will be included on select BRAVIA® Theatre home A/V systems and components. This useful function reduces the hassle and time consuming job of powering up, routing signals, etc. to the simple push of one button.8 Want to play your DVD on your Sony® A/V system? Easy, just push PLAY on the BRAVIA® HDTV remote and everything is taken care of for you. Even when the system is off! Want to change from TV sound to digital surround sound through your Sony BRAVIA® Theatre A/V system? Just one push of the Theater Sound button on the remote and voila, surround sound through your system. Want to power down everything once you've finished enjoying it? Push one button and the TV and A/V system powers down. BRAVIA® Theatre Sync™ helps make things a whole lot easier to operate.
Feb 02, 2011 | Sony BRAVIA KDL-40V3000 Television
Demo mode keeps on popping up on sony bravia. how do i permanently remove it
hi,
you can exit the DEMO MODE by the following setup.
1. select "TV" mode (not AV, demo mode can't switch off when ur in AV)
3. select "settings".
4. select "set up" .
6. when it asks home or shop display select "home".
ok
Jan 11, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I bought a Sony Bravia EX7/40 today. It's store demo mode appears every 60 seconds. How do I turn this off
  • Press the home button on the remote to go to the cross bar thing.
  • Choose settings
  • Look For set up
  • Scroll down to factory setting and restore them.
  • After that it will go to set up mode when it asks home or shop/display select "home".
    This will disable the Demo Mode.
Nov 16, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do I change the clock on my sony bravia tv?
Press the HOME button on the remote. You want to find the CLOCK/TIMERS section. Navigate to SETTINGS. Use the arrow keys to select item. Use the arrow keys to set current time. Press RETURN to display the confirmation. Select YES to save the changes.
Sep 04, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Turn demo mode off on Sony Bravia home theater
On your remote;
Press the Home button
Scroll left to settings
System settings
Auto-start up - go through setup and select "Home" (not store)
Sorted
Dec 06, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
Sony tv comcast remote code the codes 0000,0111 dont work
if your remote has a red ok button then you need a five digit code. try 11100, 10000, 11317. if you have a remote with a gray ok button then 0000 should work. if this doesnt work, write me back telling me what color your ok button is and i will send you instructions on how to scan for your code.
Oct 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
The picture went out on our sony bravia lcd
If the unit is less than a year old, it should still be under warranty through the rental center. The inverter has failed. This is what supplies the light behind the panel. This is a relatively common failure and is easily fixed by a service center. Call the rental center for instructions on what to do. This is not a failure than can be caused by misuse. You should not be at fault here.
Dan
Jul 28, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Toshiba HDTV + SONY PLAYSTATION 3 + SONY Home Theatre DAVHDX265
I have looked up the infomation on your TV I noticed that your TV has two HDMI input plugs. Since your SONY BRAVIA is hooked up to one port, you need to buy another HDMI cable for your PS3. On your tv remote you should have an option to switch from video 1 to video 2 so then you can switch from the SONY BRAVIA to the PS3 the problem is you will only hear your PS3 Sound from you TV. If you want to hear your PS3 sound from your SONY BRAVIA you need to buy an optical cable (also called TOSLINK) to connect from your PS3 to the SONY BRAVIA.
Hope that helps!
May 01, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
