Question about Betty Crocker Coffee Makers & Espresso Machines
Re: Betty Crocker BR-736 Coffee Maker. A cleaning solution of water and vinegar was poured into coffee maker. When switched ON the red light came on but solution did not circulate through unit. QUESTI
Question Title: Cleaning Coffee Maker.
SOURCE: Water all over the place
the tube that attaches to the heating element is calcified inside. water cannot flow through it. i have the same problem and havetried vinegar solutions and even straightvinegar to loosen up the clog. no help so far. i am looking for a new heating element to fix it
Posted on Nov 05, 2008
  • 131 Answers
SOURCE: bunn pour omtic 3 burner
I'm going to presume that your brewer is a VPS series pour-over brewer. This problem can be caused by several things, so I'll list the most common ones.
1) The on/off switch for the lower warmer could be burnt out.This switch also operates the heating element.
2) The high limit thermostat quite offen blows on the older VPS brewers. this is a small unit held down to the top of the tank and has 2 wires voming to it.
3) Look for burnt-off wires. These models sometimes burn off wires on the top of the heating element.
4) If none of these work, then your problem will be your heating element itself.
Parts for these models are readily available from your local Bunn repair shop.
Posted on Feb 12, 2009
  • 85 Answers
SOURCE: The red cleaning light on my cuisinart coffee
Hello sandra_strat,
There are two possible issues, but easy to do. When decalcifying your unit the solution should be 2 parts water and 1 part vinegar. So if you have a 12 cup maker it would be 8 cups water and 4 cups vinegar. Complete the process with a pot or two of fresh water to rinse. Second, there may be a water filter stick that is removable. Open the lid and look for it in one of the corners, pull it out and remove the carbon filter there. (You can get a new on Amazon). Then replace the stick.
I hope this is a help for you. If it is please leave positive feedback for me. Thanks! NormanZ
Posted on Jul 14, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Clean light continues to flash even after several
Unplug the coffeemaker for one hour or longer and it should reset itself.
Posted on Sep 29, 2009
SOURCE: I broke the 6 cup carafe and need a replacement
The model number is BC-1721 and you can order a replacement carafe for 12.99 CDN + 5.95 S&H by sending a cheque or money
order to E.F. Appliances Canada Ltd. 9033 Leslie Street, Unit #1,
Richmond Hill, ONTARIO L4B 4K3 (allow 3-6 weeks for delivery).
This info from the little booklet that comes with the coffee maker.
Has an replacement parts order form. They do not take phone orders.
Posted on Mar 10, 2010
Cleaning the coffee maker
Cleaning a coffee maker is simple.
Fill the carafe with 9-10 cups of Water and 1 cup drain cleaner.
Put a paper filter in the basket. Run the cycle. You will see lots of garbage in the carafe. Repeat with the same water.
Next dump the water into the sink and refill the carafe with fresh water.
Run again, several times to flush out the acid. remove the basket and scrub it clean. Your coffee maker should run like new.
Jan 30, 2014 | Rival Programmable 12-Cup Coffee Maker
Where can I purchase in Johannesburg South Africa another glass jug for a coffe maker as per product code below.
you can buy it online, they ship anywhere in the world. Just put the title in the address bar, Russell Hobbs parts and go from there
May 17, 2011 | Russell Hobbs RHCM3333 Coffee Maker
What can I clean my Bunn proffessional coffee maker with ?
mcdevito75 here, Contact Bunn for their recommended cleaning material for your coffee maker, or see any large store that carries coffee makers for their cleaning kits.
Jul 11, 2010 | Bunn VPR Coffee Maker
Coffee maker brews all but the last half cup, which vaporize the water and releases steams away for about 8 minutes. What could cause this to happen. The unit is several years old and gets daily use;...
mcdevito75 here, Your coffee maker may need cleaning as the water used to make the coffee contains impurities that clogg the coffee maker. Follow the instruction manuals instructions on cleaning your coffee maker.
Jun 19, 2010 | Zojirushi ECBC28 Coffee Maker
Cleaning light came on and now, coffee pot will not work
Automatic clean function
The coffee maker is equipped with an automatic clean function. After 60 brewing cycles, the clean indicator/button (22) lights up. This indicates coffee maker should be cleaned by using the automatic clean function and the charcoal filter (17) should be replaced.
NOTE: The coffee maker can continue to be used, when clean indicator/button (22) is on.
• To begin the cleaning cycle, remove the charcoal filter (17) from the water tank (10). Fill the tank with a vinegar and water mixture (1/2 vinegar and 1/2 water) or a descaling product. Press clean (22) button for three seconds. The clean indicator/button (22) flashes and the cleaning process begins.
Cleaning process:
• 24 cycles of 7 seconds brewing and 21 seconds off
• 30 minutes rest
• Brewing the remaining descaling solution
• After cleaning process is complete the clean indicator/button (22) goes off. Fill water tank (10) with clean water and run one brewing cycle to rinse the coffee maker.
• Change the charcoal filter (17) (ill. k). Reinsert the charcoal filter to the coffee maker (ill. l).
NOTE: You can use the cleaning function before reaching 60 cycles (especially if the water hardness is above normal). Press and hold clean indicator/button (22) for 3 seconds.
NOTE: The Cleaning Process takes 60 minutes to complete. You cannot cancel the cleaning process before it is complete. Unplugging the machine only delays the cleaning process.
Jan 26, 2009 | GE 106591 Coffee Maker
Cleaning my coffee maker
can the carafe of the stainless steel coffee maker go in the dishwasher?
Mar 19, 2008 | Cuisinart DCC-1200 Coffee Maker
Self cleaning coffee maker
Unplug the coffeemaker for one full hour, and the self-cleaning light will go off.
Mar 01, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee Makers & Espresso Machines Logo
42 people viewed this question
Top Betty Crocker Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Betty Crocker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
