Question about Toshiba satellite c660
Cant get f8 to work to re-boot my comp
A virusa has crashed my laptop. i dont kno0w how to re-sart it in safe mode
  • cupcakez2009
    cupcakez2009 Nov 07, 2012
    i tried it, it still didnt do nothing
  • max carson
    max carson Nov 07, 2012
    Sometimes you have to be persistant, repeat process. When you say,"it still didnt do nothing" can you be more specific, when you Cold-Start what happens when you reboot, does the pre boot screen come up at all , does the cpu activity light blink? Be a specific as you can.
  • Toshiba Master
  • 7,627 Answers
Try a "Cold-Start",Remove all media, DVD, CD, USB..etc., Remove AC plug, Remove Battery, Hold down on/off button for 10 seconds, Replace battery, Plug into AC outlet,Push on/off button and REPEATEDLY TAP F-8 until the options page appears. If you need further assistance respond to this post.
Posted on Nov 06, 2012
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: i can not boot into safe mode on my toshiba
Fixed??
The only two things you can do for a Processor is to,
A.Replace it
B.Clean the top of the Processor case, and the bottom of the heatsink that sits on it. Then apply new thermal paste.
I suggest you take this baby right back to this 'Tech', and tell them you need the problem fixed.
Slightly off topic, but I thought I would show you what I'm talking about.
The top of the Processor case is not perfectly smooth. It looks as though it is to the human eye, but it isn't.
There are microscopic hills, and valleys, and 'potholes'.
Same thing with a Heatsink. (The bottom of the Heatsink)
Thermal paste is used to fill these voids. Helps to transfer the heat from the Processor to the Heatsink.
A Heatsink is usually a copper, or aluminum plate with fins on it. Copper or Aluminum transfers heat very well.
Air is drawn over the fins, and draws the heat away.
(Works on the same principle as a radiator for a home, or a vehicle)
With a laptop the plate is connected to a tube, which in turn is connected to a finned piece.
This website shows the Toshiba Satellite A135, being disassembled right down to just the motherboard.
I thought I would include this so you can see what I'm taking about in reference to removing, and replacing the thermal paste, and what the top of your processor looks like, plus the Cooling Tube/Heatsink Assembly,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
This is Page 1.
At the very bottom of the page you will see in white -
Page 1::Page 2::Page 3::Page 4::Find another model
Left-click on Page 4.
Scroll down, and left-click on the photo to the right of Step 23.
The Cooling Tube/Heatsink Assembly is the gold colored part. Where you see 061224 upside down on that curved tube, is the Cooling Tube.
The square object under the 061224, is the plate that is right above the Processor.
Left-click on the photo to the right of Step 24.
This shows you the top of the Processor, with the Cooling Tube/Heatsink removed.
The Processor is marked CPU.
CPU stands for Central Processing Unit, or Processor for short.
What is hard to see is the actual top of the processor case itself. It is a small square that is right under the red letters CPU.
After the top of the Processor case is properly cleaned, a tiny pea sized dot of thermal paste is applied here.
Then the cleaned plate for the heatsink, is set down on the top of the processor case.
Other then that, they turned the screw on the left of the processor socket, (Circled in Red), removed the Processor, and replaced it.
(A replaced processor does require new thermal paste applied. Cost of thermal paste? About $7 USD. Enough to do 6 processors)
Posted on Dec 20, 2009
SOURCE: my nb205-n210 reciently underwent an unexpected
You will have to put a Windows DVD in and boot on that and do a "Repair" install, if that will not work, you will have to do a complete format and reinstall Windows.
But try the below first if you can.
1. Restart the computer.
2. Repeatedly tap the F8 key until you see the Advanced Boot Option Screen.
3. Select Repair Your Computerand hit Enter.
4. Select your country >> OK.
5. On the System Recovery Options Screen select Restore Application.
6. Follow the on-screen instructions.
8. When prompted, select on "Full Factory Recovery"
9. Select Next >> Yes.
10. After a couple of minutes the recovery will be completed.
Check to see if your PC will perform a Factory reinstall from a "Recovery partition" usually accessed via CTRL F10, or just F10 or F12 Check your manual, as if this is available it will restore your PC to a "From the factory state"
BTW, your hard drive may be ruined you may need to get a new one. Then reinstall Windows from DVD.
Posted on Feb 12, 2010
I want to boot my pc to the safe mood but i cant i've used f8, f10, and dont know wat to do now.
In order to get into Windows safe mode, you need to begin pressing the F8 key repeatedly AS SOON as you see the BIOS/manufacturer name come up, WELL before you see the Windows splash screen. Basically as soon as it goes to 'black screen', begin hitting the F8 key and while it may take a couple of times, you should get there!
Best of luck! Hope this helps!
Jun 21, 2011 | Toshiba Satellite A205-S5825 PC Notebook
I have a virus and need to go into Safe Mode. I can't load my comp into safe mode, even after pressing f8 several times
try allowing the bc to half boot up, before logon page and while the windows is loading screen is there, press and hold your power button until it foreces a switch off.on next boot you should be offered the safe mode option.
Apr 30, 2011 | Dell Vostro 1510 Laptop
Exployer 8 download crashed my intel asus p4pe with windows xp . I cant boot up. I get the voice welcome, then when it should boot up, it clicks and starts over. Never ending loop.
I would recommend booting your pc to Safe Mode and restoring your system back to a date BEFORE the crash happened. When you power on your pc, press F10 or F8 until you hear a beep. This will bring up a command function for you to select what you would like to boot to . Choose Safe Mode.
Good Luck
C2Solutions
Feb 13, 2011 | ASUS P4PE-BP Motherboard
How do i restart 1525 with a blue screen
Try pressing F8 repeatedly during boot sequence, select "last known figuration that worked".
If that doesn'e work reboot and do it again, select safe mode and try system restore.
Sep 18, 2009 | Dell Inspiron 1525 Notebook
What can i do if i dont remember my user account PLEASE HELP!!!
You can boot the windows in the safe mode by tapping the F8 key during boot. Selected the windows safe mode option in the windows advance menu. Click on Administrator .After logging go to control panel in user account,click on user user account and click on remove password.Restart the system and check you should be able to boot to desktop.
Aug 27, 2009 | E-Machines eMachines Desktop PC
Keyboard locks on startup, mouse pad works, FN & ECS (for Standby) works
your comp is infected for sure.i`ve seen many cases where my customer`s comp is infected and they face the same problem.
make sure you have ethernet cable plugged in to your laptop so we can use safe mode with networking. shutdown your computer.on top of the keyboard you have F8 key.the moment you`ll press the power button to turn on the computer start tapping F8. advance boot up options will appear. select safe mode with networking
try restoring your comp to a previous time when it was working. if it doesn`t work don`t worry just follow the steps below.In any case you have to clean virus out of your computer.
download,install and run this software.after running the scan clean all the infections and restart your comp.
http://www.download.com/Malwarebytes...dlPid=10878968
Good Luck!!
May 19, 2009 | Dell Computers & Internet
Cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode.  The most common reason that it will not work is that it is not pressed fast enough or early enough.  You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
May 08, 2009 | Acer Aspire 5100 Notebook
Crashes all the time
You could try to start in safe mode by pressing F8 and restore last configuration used to see if it works.
If not i am afraid you have to use the Windows CD and try the repair mode. If you have anything on it which you can't delete never format it.
But first try to see if you can boot in safe mode. If you can boot in safe mode we can turn off the setting so you can see what the blue screen is about. If you can't go in safe mode you have to use the Windows CD. Sorry....
Good Luck,
Jan 09, 2009 | Dell Latitude D600 Notebook
Acer aspire 5715z/5315, turned laptop on took time to load up wasnt responding,restarded laptop then it wouldnt restart then i turned it of manually, turned it back on,screen acer back ground in the bottom...
Reboot your system-press and hold F8 until you get a list of options-select Safe Mode-enter.Your system will run in Safe Mode,giving you a dropdown list as it progresses-check where it stops.In this way you can establish wether you have a corrupted or incompatible driver and which {Graphic ie} stop the system.You will have to reload the OS to solve the problem.If you cannot even boot into Safe Mode,your drive very likely crashed.Happy landing.
Jul 22, 2008 | Acer Computers & Internet
It wont start up
Could be this is a driver error on boot up, when it starts to boot up keep pressing F8, this will bring up the safe mode menu, look for the line and highlight 'Last Known Good Configuration' and press Enter. If this works all is well, but if not press F8 again o boot up but this time highlight the line 'Start Windows in Safe Mode'. If the laptop then boots up in safe mode without shutting down, run your anti virus and spyware programmes. If non found and the laptop still has'nt crashed, then it's a driver problem (as not all the drivers load up in safe mode) and you will need to try a system restore to before the problem started.
Oct 30, 2006 | Acer TravelMate 4150LCi Notebook
Toshiba satellite c660 Logo
111 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
