Question about Kirby Vacuums
Tech drive slips and squeaks - Kirby Vacuums
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 88 Answers
Machine needs serviced, 39.95 the engineer will re-set everything
Posted on Jan 15, 2013
How do I fix a squeak in a hardwood floor
squeeks in a hardwood floor most times are caused by the hardwood separating from the underlayment (board) and hence it piviots on a nail and you got a squeak !! , there are a few ways to fix this "
if the squeak is located in a spot that is accessible from under the floor , see if you can determine what hardwood and underlayment thickness is , look around behind a floor casement or around a doorway trim with flashlight , find a wood screw that is 1/8 less than this number (two added together ) also locate a drill that is just size of screw shaft you found , drill hole from under the floor (underlayment) just deep enough to penetrate the underlayment (3/4 inch or so) use tape on bit as a gauge , don't drill into hard wood then drive wood screw into hole , the idea is that screw will pull hardwood down to underlayment , screw cant grip underlayment due to hole so this is piviot point . a shot of wood glue on screw threads helps it from coming out too !!
now if space under squeak isn't accessible this is a bit harder but not impossible to do , there are a few special items to get first , one is a glue injector needle !! this typically is used making wood furniture but I have seen a meat basting syringe used in a pinch too, locate the spot close to squeak from top , using a small drill dril down at seam (not in middle of board) just deep enough to hardwood Not underlayment , load up your syringe with wood glue and force it down into hole with needle takes some force to do this , wipe off spilled glue and set a heavy object on this spot for 24 hrs object can be a lg pile of books or I use cement blocks (4) set on a piece of butcher paper (not cardboard) after 24 hr remove blocks and ck for squeak if none use hard setting tinted wood filler to plug hole you made and top off with a dot of varnish to seal it when dry and flat if you still detect the squeak then move over a board or two and repeat process till squeak is gone
Jan 03, 2017 | Vacuums
What can you do to stop squeaking when I'm winding bobbin
Spray wherever the squeak is coming from with a dry silicone lubricant called 'Jigaloo' or WD40 Dry Silicone Lubricant. It is also great for sliding windows.
WD 40 300014 Specialist Water Resistant Silicone Lubricant Spray 11 oz...
Jan 13, 2016 | SewShop.com Singer Model CE200 Quantum...
Vacuum squeaking loudly!!!Help!!!!
Most likely has a bunch of hair wrapped around the beater bar. Get some scissors, razor knife and some needle nose pliers. Turn the bottom up and remove the cover and start digging the hair out. You may need a new drive belt too.
Nov 07, 2015 | Vacuums
Why is dryer squeaking,belt sprayed but still squeals.
If the belt is to lose it can slip and squeal. worn out belts do the same.
Jul 12, 2014 | Eureka 431BX Bagless Upright Vacuum
How to fix squeaking and bag full sign lit on the sebo x4 extra upright vacuum?
Check the main "kitchen roll" filter isn't clogged which is on the left hand side of the bag when the bin door is opened. There could be a clog, either behind the pick out metal grid below the filter roll, or the roll filter requires to be replaced. Can you add more info about the squeaking though? Is it a high pitched squeal all of the time or just intermittent and where it seems to be coming from - it could be excess air escaping from a pierced hose or a drive belt issue.
Oct 30, 2013 | Sebo X4 Bagged Upright Vacuum
My Generation 3 Kirby Vacuum is giving off a burnt rubber smell when I vacuum. I have tried to raise the height of the head but it still happens. Can you tell me what could be causing rubber to burn? ...
The belt driving the brush roller in the power head is slipping. It is really just a big thick rubber band. Where it wears out it slips and burns due to friction.
Look at the bottom of the power head. There is a cover plate held with 2 to 4 screws. Remove the plate and you will see the roller and drive belt. Slip the roller out and remove the belt.
Go to your local vacuum dealer and get a replacement.
Installation is the reverse of removal.
Mar 06, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Flair Cleaner makes squeaking noises
There are two items that could squeak:
If it squeaks when pushing/pulling it on carpet, WHILE NOT RUNNING, then the wheels are squeaking when they rotate on the wheel shaft. If so, one drop of oil at the shaft would fix it.
If it squeaks WHILE RUNNING, mostly while pulling backwards on carpet, then the belt is slipping. You may wish to set the nozzle height setting for a higher pile carpet, or could replace the rubber belt.
Oct 25, 2009 | Hoover Vacuums
How do I change the belt in a Hoover U4262-930
You got the second hardest part done; the hardest part is what you're asking about.
To get the new belt onto the drive shaft I used a long screwdriver for leverage and wrapped the end close to the shaft and with some elbow grease, got it to "slip" on to the shaft. It took a couple of tries, but once I overcame the fear of the belt breaking (because it has to stretch big time), I managed to get it one. Of course, the other end of the belt has to be wrapped around the roller first.
I found a link for a tech manual for this model, but it didn't help much....
good luck.
Mar 22, 2009 | Hoover Soft Light Supreme U4262-930 Bagged...
Owners manual
remove bottom plate, remove brush roll. slip new belt over motor shaft then onto brush roll. refit brush roll and bottom plate. its just meccano
Mar 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Vacuums Logo
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
