Question about HP Pavilion dv6000z Notebook
How to reinstall from the recoverydisc drive in hp laptop
How to install the backup files which are stored in the recovery discdrive in hp laptop with microsoft vista home edition operating system
    Scholar:
  • 80 Answers
You have to create the recovery disk and than you can restore the same. How to make the recovery disk is shown in the manual you received with laptop.
Posted on Jan 05, 2009
  • 144 Answers
When you boot the computer , look for something that says System Recovery and press the button next to it
My HP Pc Shows it when the HP Logo comes on and the key is F10 but it may be different for you
F11...system recovery in hp laptop
System recovery is for serious disk/operating system corruption problems. There is a system recovery partition on HP laptops that contains routines to restore your laptop to the configuration it came from the factory with. Backup all your personal files to a CD or USB stick or portable hard drive before using system recovery as it will erase anything you have added to your primary hard drive since it left the factory. That can especially be a problem if you have upgraded to a newer version of Windows than what your laptop came with, as HP is somewhat 'known' for not upgrading the recovery partition if you don't have recovery CD's for the new operating system bought from HP. If your recovery partition has been erased or corrupted, you will have to either use HP recovery CD's (which may be available from HP if your laptop is new enough)
or do a format and complete installation from the proper Windows installation CD. Either way, your personal files are toast if you don't back them up first. In some cases of operating system failure, you can get an external USB drive box, put your old HDD in it and use another computer to try and read files from the disk to try and save your personal files.
Jul 23, 2014 | Computers & Internet
I just restarted my HP and now it says there is no hard drive and I dont have a recovery disk
try disconnecting the drive and reseating it first.
If you enter the bios (f10 on startup) does the computer even detect the drive? If not - try reseating it - don't forget to power off first
Failing that try the hp recovery partition
Press the power button to start the HP. Press and hold the F11 key to launch the HP Recovery Manager from the recovery partition.
Backup any files you want to save. Follow the HP Recovery Manager instructions to save any important files before continuing with the recovery process.
Continue the recovery process. After backing up files to an external device or CD/DVDs, select the option to perform a system recovery.
Obtain and install updates for the HP. After your system reboots, use HP update manager as well as Windows update to restore all critical updates to your HP computer.
5
Make a set of recovery disks. Use HP Recovery Manager and select "Advanced Options" to create a set of recovery disks that can be used in the event that your HP cannot access the hard drive.
Feb 25, 2011 | HP G60-235DX Notebook
Going to reset my computer. Where can I find the reset button?
If you're trying to restore the Computer to factory settings, then you can use the VAIO Recovery Center that is shipped with the Computer.
NOTES:
  1. Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
  2. In the Windows Help and Support window, click Backup & Recovery .
  3. Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
  4. In the VAIO Recovery Center window, under Choose a program , click to select the desired option: NOTES:
    • It is strongly recommended that recovery discs be created to help restore files if the operating system will not start. Recovery discs are bootable and can be used to perform a recovery on a properly functioning hard drive.
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Windows Vista® operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
    • Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
    • One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
    • The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
    • Choosing Restore Complete System will restore the entire (C:) drive, while removing or restoring the Recovery Drive partition. Modifying the size of the hard drive partitions is also an option with this type of recovery. This option requires you to insert Recovery DVDs created using the Create Recovery Discs option.
    • To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option. This option is provided for the convenience of advanced users who want to install a different operating system, and who want to ensure all data has been removed from the hard drive first. All other users are strongly urged to avoid selecting this option.
May 17, 2010 | Sony VAIO® VGN-CR120E PC Notebook
My c drive was formated but they did not back up Bioscrypt. I have it on another backup drive. How do I reinstall
Please re-install the OS and then connect the another back up drive to copy the Bioscript in C drive to get it re-install.
Nov 11, 2009 | HP Pavilion tx1000z Notebook
How do you install xp over windows vista in a lenovo x61 tablet ? I have 3 backup disc 1.a product recovery dvd 2.rescue and recovery cd 3.suppemental recovery cd . can some one tell me how to get...
If the backup and recovery disk are for that model of computer , just remove VISTA or Reformat the hard driver using software outside of Window, then reinstall all the Xp stuff, just as if you had a new hard drive. Save all personal files first, of course..
Feb 22, 2009 | Lenovo 3000 C200 Notebook
Windows vista wont load
Hi I believe that wouldn't be a problem. If you want to do a system recovery, the laptop usually comes with a back up partition where all the files to do system recovery is stored. You can use these files to restore the setting back to the point when you first purchased the item.
REMEMBER: All your datas will be erased when you do the System Recovery.
For me guide you on have to access the files, I need the make and model of your laptop.
NOTE: If the RECOVERY or FACTORY_IMAGE partitions on the hard drive have been deleted OR the files in these partitions have been deleted, these steps will not work. You must use recovery discs.
  1. Turn off the computer.
  2. Disconnect all connected devices (such as the Personal Media Drive, USB drives, printer, and fax), remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord.
  3. Turn on the computer and immediately press the F11 key repeatedly , about once every second, until Recovery Manager opens.
  4. Click Next .
    A Microsoft System Restore screen opens.
  5. Select No, I would like to see other options , and then click Next .
    A System recovery screen opens.
  6. Click Yes , and Next to continue the recovery process.
    The Recovery Manager gives you the option of backing up your data files. To do so, read Backing up your files .
  7. To continue recovery, select No , and then click Next .
    A recovery progress screen opens. Wait while files are restored.
  8. When System Recovery is complete, click Finish
  9. The computer restarts and continues into Windows setup.
  10. Complete the setup screens and wait until the computer finishes the setup.
  11. Turn off the computer, reconnect all peripheral devices, and turn on the computer.
  12. Before using the computer, update and protect it by reinstalling any virus and security software that was installed before the System Recovery.
  13. Reinstall any software applications that were added after purchasing the computer, and replace any files that were backed up.
Please rate this solution.
Jan 14, 2009 | Computers & Internet
Forgot my admin password for my notebook
No worries about taking the Backup of data before reinstalling the Operating System in your Notebook.
I recommend you to remove the Hard Drive of the Notebook and connect it to the USB Port of any other computer using some cables that will be available in most of the computer part stores and copy the required files in the computer to which the hard drive is connected.
You can find the required instructions to remove the Hard Drive of your Notebook from the Manual which is available in the link below :
http://h10032.www1.hp.com/ctg/Manual/c00737799.pdf
You can find the required instructions to remove the Hard Drive of your Notebook starting from page number 100 of 233 in the Manual.
Find some cables which can be used to connect the Hard Drive of the Notebook to another computer by clicking HERE
Once the required data is saved, reinsert the Hard Drive back in the Notebook and perform a full recovery by following the instructions listed below using the Recovery Partition  with Vista :
Restart or Start the Notebook and start tapping the F11 key immideatly after the Notebook restarts.
This will take you to the Recovery Manager window.
In this, click on the Advanced button.
In this, you will get the following options :
a) Computer Checkup
b) Microsoft system restore
c) File backup wizard
d) System recovery
Click on System Recovery.
In the window that opens, you will get the options...
Do you want to back up your files first (reccomended)
or
Recover without Backing up.
You can take a backup of the data in the Hard Drive if you have any External storage devices like External Hard Drives connected to the Notebook.
Select the required option to proceed with the Recovery.
The Operating system in the Notebook will be reinstalled along with all the Preinstaled Applications and Drivers to factory default settings.
Hope this helps....
Nov 01, 2008 | HP Pavilion dv6000z Notebook
I could not start my Hp pavilion, then I use the restore system by using F11 and start my computer. Now all my files (my document) is gone. How I can recover my files.
f11 takes you to the BIOS/CMOS settup, and a system restore cannot be accomplished there. i suspect you went into the recovery console (notice i said recovery, not restore). in recovery, you have two options, non destructive recovery whitch only reinstalls the factory operating system and keeps your files. it does however changes the location of your files and you have to explore around to find them. a destructive recovery completely rewrites the non-partitioned segment of the hard drive which erases all files.........but............if you have done a backup which stores the files in the partitioned area of the hard drive, you can restore that backup with the back-up and restore utility.
Oct 07, 2008 | Computers & Internet
Restore3
I found these instructions for you on the Sony support site.
Solution
sp.gif sp.gif IMPORTANT:
  • Before performing a recovery, go to the Sony® eSupport Web site at http://esupport.sony.com and check your model-specific support page. Look for software and driver updates or check for knowledge base solutions that may help you solve your computer's issue.
  • This model does not require Recovery CDs. Recovery data is included on a special partition of the hard drive.
  • Do not interrupt the power during the recovery process.
  • Before performing a recovery, disconnect any external devices not supplied with the computer such as printers, network cables, cameras, or external storage devices, like hard drives or flash drives.
  • Customers who purchased the Symantec® Norton Internet Security® 2007 software from the Sony Style® store with their computer must create a Norton Account to save their product key prior to a system recovery or the software cannot be reinstalled.
NOTES:
    NOTES:
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Microsoft® Windows Vista™ operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
Please update me on the same.
Regards
Sammy
Jul 10, 2008 | Computers & Internet
Many things going wrong
It seems some thing is going wrong in your operating system. It might be caused by a virus or misshandling of your OS.
Anyways to overcome this problem HP gives you to make restore factory setting for your lap.
WARNING: MAKE BACKUP OF ALL YOUR IMPORTANT FILES AND DATA, BECAUSE ALL YOUR PROGRAM AND DATA WILL BE LOST WHICH YOU HAVE INSTALLED AFTER FIRST RUN OF THE LAP. SO BEAWARE BEFORE MAKING SYSTEM RECOVERY.
Restore the PC to original condition with the HP Recovery Manager Follow the steps below to use HP Recovery Manager to return your notebook to its baseline factory condition, then allow the PC to run all the setup programs.
  1. Press the power button to turn on the PC, and press F11 on the keyboard immediately while the computer is starting up. The HP Backup and Recovery Manager window will appear.
  2. Click Advanced options , select the System recovery option, and then click Next .
  3. If the Recovery Manager can access the hard drive it displays a prompt to backup up user files before continuing the recovery. You may either backup your files, or skip the backup and recover the operating system.
  4. If the Recovery Manager cannot access the hard drive to fix the system errors, use the set of Recovery disks that you created to recover the hard drive to its original condition.
After the hard drive is returned to its original condition, restart the PC and allow the PC to run all the setup programs For more details you can surf the HP website Thanks Iqbal
Mar 23, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
