Question about Xerox WORKCENTRE 6015/Ni Color
034-751 error code
This is a new all-in-one device; I've had it about 2 weeks. Incoming fax attempts prompt a "Communication Fail. 034-751 fax. Job Failure. Press (OK) Button. Why??
5 Suggested Answers
  • 110 Answers
SOURCE: Cyan Imaging Unit Failure, U28 Error Code
I just got that error couple of weeks ago on my 7300. I did everything you did and nothing so I ended up visiting www.iteminconline.com. I called them up and they told me to check all the cables on the engine control board 116-1538-00. I made sure the white data cables where connected and still nothing so they recommended me to buy a engine control board. That did the trick. Hopefully this will help you.
Posted on Oct 06, 2009
  • 30 Answers
SOURCE: Out going fax is O.K. During incoming fax
This means you have run out of something like paper or toner.
Posted on May 06, 2010
Evildice
  • 217 Answers
SOURCE: The Xerox Wokcentre XD100 is
check printer port from printer "Properties" menu.
Posted on Mar 19, 2011
  • 304 Answers
SOURCE: I have hte xerox phaser
13 Memory full The machine memory is full (there are too many documents that have been received but not yet printed, or waiting to be transmitted).
Print the received documents.
Delete or transmit in immediate mode the documents waiting to be transmitted.
14 Memory full Received document memory saturated.
Posted on Jul 13, 2011
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
FaultCode:0 faultString:'Error' faultDetail:'ioError: ioError'
Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motor like force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else.
Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; Otherwise, Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware. Hope this helps.
Dec 09, 2012 | Microsoft Internet Explorer 9
After printer said ink cartridge was empty I removed it & found it was not-I put it back in printer & now getting error message that the cartridge is used & needs to be replaced. How can I
your only option it to replace it with a new one . printer mfg's have chipped the cartridges and they can not be reused.unless the chip is recoded as new .
Aug 16, 2017 | Ricoh Aficio GX3050N Printer
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
Captcha images not showing. Hoping somebody can come up with a solution for my problem. A few weeks ago I had a virus - all cleaned up now, but since then I haven't been able to see ...
Try verifying that it isn't an antivirus client or ad blocking software blocking the images.
You can also attempt updating your Java & Flash clients to the latest versions.
May 05, 2011 | Computers & Internet
When I try to fax a document to another fax Machine ( either via feeder or through software), I am always getting an error message " A communication error occured..." (Error 387)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Dec 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Comm error 232
This is the common cause and solution: A communication failure has occurred between the two machines. On the other hand, the user at the remote machine may have pressed the Stop button. Alternatively: the power at the remote machine has been interrupted, or deliberately turned off causing the fax session to be interrupted.
Solution:
1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, and error correction is in use for the fax session, disable ECM . (See Error 222)
Good luck
Jun 12, 2010 | HP LaserJet 3050 All-In-One Printer
Error Code R.3.1
YOUR PROBLEM IS CAUSED BY STATIC ON THE PHONELINE NOT YOUR FAX. BOTH MACHINES TRY TO SLOW DOWN TO UNDERSTAND INTERNATIONALMESSAGE OF FAX COMMUNICATION THEY MUST UNDERSTAND 95% OF MESSAGE OR THEY WILL DISCONNECT YOU CAN TRY NEW PHONECORD 1.00 AT DOLLAR STORE ORCALL YOUR PHONE CO.
Apr 09, 2010 | Muratec F65 Plain Paper Thermal transfer...
What does communication error 20 06 mean on my brother intellifax 4750e? We have been having problems faxing out and customers have called with trouble faxing in. Yet, we have received faxes prior to them...
CRC error in answerback. It means the error correction digits didn't match the data that was sent. I've seen a few cases where this was bad phone line conditions - once I could see the phone lines scraping against the gutters in the storm outside the window - but usually it's a flaky Main Board in the fax.
Unplugging all the cables on the board and plugging them back in might clean a bad connection, but we're seldom that lucky.
Jan 27, 2010 | Brother IntelliFAX 4100 Laser Fax
Error code
Hi Mike,
The error message "A communication error has occurred during the fax transmission" normally indicates that for some reason the fax call was interrupted or there was some interference on the telephone line during the fax transmission. Some possible interruption/interference on transmission(s) are:
1. the telephone line is not a dedicated fax line - there could be an extension which was inadvertently lifted/used during a fax call;
2. noisy/dirty telephone/fax line - corrosion on the terminal, joints, connectors, pins, plugs, jacks, telephone outlet or even on the provider's system. This could be determined by using the handset of the fax machine, dialing a single digit (to make the dialtone disappear) and listening to the phone's earpiece. There should be no crackling sound or static but a clean/dead air. In some cases where the telephone/fax line is shared with the DSL, then it could be the filter/splitter used;
3. some phone lines can still accept an incoming even though in use (call waiting) - the ringing of the 2nd call is more than enough interruption/interference;
4. RFI (radio frequency interference) - an electronic device that transmits a radio signal such as a two way radio, a WiFi router or mobile phone; and/or
5. noisy/dirty power AC mains -the outlet/AC power line where the fax device is plugged in has some other appliances/devices that draws power from it that can cause static/transients/spikes along the power line. Examples are water dispensers with built-in cooler/heater, dehumidifier, aircons, refrigerators and any other that switches itself on/off. A simple solution would be to use a different outlet and/or use a surge suppressor.
As to the "error code number 321*", pls post back the make and model of your fax device. Alternately, you can reference this site. If your fax machine/device is an HP brand (and/or the receiving end's fax machine is), pls check this link.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 21, 2008 | Office Equipment & Supplies
Xerox WORKCENTRE 6015/Ni Color Logo
660 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
