Question about Hobart HL200-1STD Mixer
The mixer will not start
Power is on--- but mixer will not start
Mixer won't start
does it get power ? there is a thermal fuse inside the machine R&R and you might get one at Radio Shack 8 to 10 amperage value for about $ 8.00 if you know how to do electronics ...good luck ...15 minute job
Mar 22, 2014 | Cuisinart Food Mixers
Where can I find beaters at the lowest cost for the KitchenAid Ultra Power Soft Start 7 Hand Mixer?
We sell the beaters at The Mending Shed, they are $8.95 for the set of beaters.
Here is a link to those on our website: http://www.mendingshed.com/kahandbeater.html
Jun 15, 2013 | KitchenAid Food Mixers
Kitchenaid wont start
The possible problems could be in no real order>>>
1. your power outlet in your house
2 the power cord to the mixer broken or shorted
3 the speed control plate inside the mixer needs adjusting or replaced
4 the carbon brushes inside the motor head of the mixer need replaced
5 the armature a motor part
6 the stator a motor part
The first four are easy fixes the last two will require a full tear down. but there are lots of things to test first. let us know.
Feb 22, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Stoped working
kazikeva... It's not very clear what stopped working; the motor, the mixer, what, in particular? You don't tell me how old your mixer is and how much it's been used, all relevant towards pointing me to the problem(s). The more detail you can provide, the better my answer will be towards helping solve your problem. Are you getting any sound when you hit the start knob, or is it just dead silence? If you have dead silence, then it is definitely a power issue, which means it a couple of things could be conspiring to make your mixer not run. It may be a bad controller assembly (the speed knob), or it could be the motor, but either way it's something you can check yourself. I'd start with the controller assembly and inspect that first. It's possible a connection has come loose. Unfortunately whole controller assembly is on a little PC board filled with resistors, capacitors and diodes, which was not meant to be 'home fixed'. My 'expertise' ends at being able to recognize a resistor from a capacitor, but I don't get much deeper than that. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not. The next possibility would be with the motor itself, but electric motors are pretty simple mechanisms and generally don't fail. If you?re getting 'noise' from the motor but the mixer won't turn, then you've had a mechanical failure in the transmission box or planetary gear assembly of your mixer. The inspection and troubleshooting of the transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. You want Part No. 8212257 for your mixer, which you can download from KA customer service. I hope this helps! Howard, Burke, VA
Nov 04, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
The lever to start the machine the one that moves to the right to select the speeds won't move
Are you sure the bowl is locked into place? If it is, also check the safety mechanism that the bowl moves in order for the mixer to turn on to ensure that it isn't broken and is moving as the mixer won't turn on if the bowl isn't turning off this safety feature which is probably broken if the mixer start arm won't move.
Benjamin
Jul 09, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
My mixer wont start
First of all plug another appliance into the receptacle to make sure you have power there. If you don't have power at that receptacle you have blown a fuse or tripped a circuit breaker. good luck
Jan 16, 2009 | KitchenAid K45SS Classic Stand Mixer
Disc stuck in unit
Unplug power cord. Plug back power and keep pressing the eject button repeatedly while the unit starts up. Do this a couple of times, if you succeed in activating the eject before the system starts reading the disk, then it will eject.
If you do not get the disk out in this way, the only alternative is taking the unit apart, and removing disk from inside manually.
Oct 08, 2008 | Gem Sound CDM-150 Mixer
Mixer stuck
You will have to have the transmission serviced. sounds like the gears were ground out. you can do the service work yourself its not to difficult.
Apr 18, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
Hobart HL200-1STD Mixer Logo
42 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
