Question about LaCie Wireless Space 2TB Wireless Storage Hard Drive
I don't see open share anymore
  • duchateau_er
    duchateau_er Nov 08, 2012
    The drive is connected to a router and for a while ik can put data on it, after some days when I restart my Mac, I don't see any data. Normally you can see a kind of directory called "Open Share" where all the data is storaged. This directory I don't see anymore and the system gives me a message that the drive is not reachable.
Fix Remote
You might be able to buy a universal remote that would control at least some of the functions.
Jun 15, 2013 | Televison & Video
Can't share photos on Kodak Easyshare site anymore!
Hello, Kodak is in bankruptcy as we speak, they have a lack of customer service so I do not think there is anything anyone can do except STOP BUYING KODAK PRODUCTS !!!!!!!
Sep 20, 2012 | Kodak EasyShare One Digital Camera
My windows are falling. Their motors won't raise or lower them anymore. We propped two of them up, can't figure out why they broke and need to know how to fix them. Any suggestions?
What your windows problems are---is broken window regulators
Most people say their off the track
That isn't true,the regulator pushes & pulls
the window up & down & either a plastic piece
or a cable assy breaks,depending on your type
You have to go to a dealer in most case,for the parts
& the prices
A company called Dorman also make some replacement parts
They can be found on the internet
You have to remove the inside door panel to examine your
issues & there are no instructions,even in factory service manuals
You can try YOU TUBE,they have some video on most all
car problems
Not a fun job at all & the pros don't even like that kind
of work.
Once the door panel is off,you need long sleeves & thin
gloves, if you can even use them. You will get cut up inside
a door. No way to avoid the share edges.
You won't have the expensive pop riviet tool, if drilling out
rivets is needed. You can use small bolts
You will have to test the motors & if good, swap to new
regulators
Your best in my opinion, to do this job yourself, if you want
it done once & done correctly
The problem is, do you have the skills & patience
Expect to spend $200.00 or more for parts
You may need 2 regulators,1 motor & a switch
You have to diagnose things to know that
Jun 04, 2012 | 2000 Pontiac Grand Prix
Fix selector button
Best word of advice...if you don't know, call an appliance tech. It will save you alot more time.
May 20, 2012 | Speed Queen Washing Machines
Spreadsheets
To open a spreadsheet 'FILE' you need a spreadsheet 'PROGRAM'. Unfortnately Apple don't give you one free anymore so you will have to buy one. Apple Numbers (part of iWork) or Microsoft Excel (part of MS Office) or you can download a freebie from the open office people.
Feb 12, 2012 | Apple Computers & Internet
My camera pictures have lines & it is not clear
you don`t say what model is your camera ?
I recommend www.ebay.com to get part used and lowest price.
Choose a dealer who ship to your country.
Is importan to people who share knowledge hear your comments or received rate points
Sep 16, 2011 | Samsung Cameras
No dash lights, power locks don't work, fuel gadge doesn't work, radio doesn't work.
all these circuits share some common fuses, check fuse #6 ( 10 amp ), fuse # 11 ( 15 amp ) & fuse #12 ( 10 amp ) all in the inside fuse box at the left end of the dash.....good luck
Jun 20, 2011 | 2000 Mitsubishi Diamante
I have Windows Vista and Internet Explorer 9. Skype was fine and now won't even open. A small box comes up saying 'Skype has stopped working'. I have checked for updates. Help please!
Try this, (Vista & Win 7)
1. Close Skype
2. Exit the Skype icon from the system tray(at the bottom right of the screen)
3. Ensure that "Show hidden files and folders" is switch is check & enabled
(i). Start-> type "Run" & press Enter
(ii). Type "control folders" & click OK
(iii). Select the View tab & ensure the relevant entry is enabled
4. Locate the shared.xml file
(i). Start-> type "Run" & Press Enter
(ii). Type "%appdata%\skype" & click OK
(iii). Delete the "shared.xml file" - (without quotes)
Restart Skype, a new shared.xml file will be created.
Hope it will help.
Jun 02, 2011 | Computers & Internet
I'm using NComputing X300 kit to connect sets of PC's running Windows XP SP2. I install windows 7 on the PC's and the NConputing is not supported any more. Can you help me to get the X300...
Hi enoonoo
Even though the product claims to be compatible with Windows and Linux, it has 1/ no drivers for any Linux system and 2/ does not work with Vista / Windows 7 .
It is useless , it will just don't work anymore .
You can always create a network , sharing all machines via a gateway . It also works between different OS versions like sharing a W7 unit with an XP one .
Best regards ,
fanaudi .
May 19, 2011 | Computers & Internet
I've had kodak easy share on my computer for years. Recently I tried to access the pictures and got "can not process your request..(error code 9477068x301x94770168x) I have called them &...
Forget easy share, just take out the memory card (SD card) from your camera and buy a SD card reader. Put this memory card in the card reader and plug the card reader in your computer USB. It will work like a normal pen drive and you will find all your pictures inside DCIM folder of your memory card. Copy all pictures in your computer HDD to be on safe side.
May 07, 2011 | Computers & Internet
Open Questions:
LaCie Wireless Space 2TB Wireless Storage Hard Drive Logo
100 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
