Question about Peg Perego John Deere Gator HPX
Broken front axel - Peg Perego John Deere Gator HPX
    Genius:
  • Peg Perego Master
  • 1,508 Answers
I can order you a new one if you still need one
Posted on Dec 10, 2012
Load poping noise coming from front axel on my side by side. Anyone know what this is?
I would check the hubs and make sure nothing is broken internally. Otherwise, you'll have to look at that front diff. If the oil leak is something new, you may have broken a ring or pinion gear in the differential. The pieces would be binding inside the housing, causing more damage. I would not drive it until it can be looked at, to limit any further damage.
Jan 12, 2016 | Cars & Trucks
Broken front passenger side axel
axel or tie rod end?? ` what make model and yr
Feb 12, 2013 | Cars & Trucks
I have a broken front axel and now it is becoming hard to steer can you please help me
if you have a broken front axle then you shouldn't even be able to drive it. if it still moves then stop driving it before you kill yourself or someone else. take it to a shop and have it repaired immediately!
Jan 04, 2011 | Ford Taurus Cars & Trucks
1993 Dodge Grand Caravan Transmission issue
A broken engine or tranny mount should not cause a front wheel to wobble. If this is happening with a grinding noise I'd expect more of a failing bearing or such. The grinding noise may also be a rotor of the brakes with poor pads. Yes, if a axel, or CV joint, is failing this can make noise too, often times a "clicking" type of noise. Best get the front of the van up on jack stands, remove the tires and inspect all of the front-end components; pay special attention CV joints, rotors and front axel area, loose movement in the axels?
I hope this may have helped,
Tom
Apr 16, 2010 | 1993 Dodge Caravan
Not kicking into 4 wheel drive
Check to see if the front drive shaft is turning. If it is and the wheels are
not moving. Check the vacum actuator, located under the battery pan.
Make sure there are no leaks or kinks in the lines, do the same at the vacum solenoid valve. If these check out. Check the clutch cable from
the actuator to the front axel. Make sure it's not broken or kinked, as
the cable engages and disengages the front axel. But if the front drive
shaft is turning. And it's an electric shift control check the fuse first.
If it is transfer case related I will need to know whether it's manual or electric shift. You can get back to us with that info if neccesery.
Or if you find a problem with any of the parts I have mentioned.
Hope this helps. Good luck.
Feb 06, 2010 | 1999 GMC Jimmy
The axle from a jeep 4x4 is broke , both axles, how do i take out the rest of the parts?
The front axel is a two piece assy. remove the 4wd
shift moter from the axel housing. Once the moter
and fork are off , remove outer axel.To remove inner
axel, remove differential cover and let it drain.
There is a C clip on the axel, remove it and work the
axel out through the axel tube.(if it is broken)
To remove the rear axel. Remove diff. cover and drain.
Remove the pinion lock nut(or spring clip) and slide
back pinion shaft. Remove retaining clip from axel
and remove axel. To remove broken piece I use to
use a length of an old whip antenna, to push it out.
If you can find a piece of heavy gauge wire to push
it out.(a plumbers snake may work)Also only have
one axel at a time out of either housing, this will
make it easier to reinstall the axels.
I hope I was of some help. Good luck.
Jan 30, 2010 | 1995 Jeep Grand Cherokee
4 wheel drive light is on in my jeep
vacumn pod on the front axel is stuck on. Jack up the front wheels spin both tires at the same time and see if the front drive shaft turns. If it does the 4x4 on the axel is engaged. The front drive shaft on these should not turn when vacumn pod is disengaged. YJ's have a split axel on the right side inner axel shaft.
Apr 10, 2009 | 1992 Jeep Wrangler
My front axel and back axel are both broken after an accident howmuch does it cost o and gas tan has hole in it???? plz hlp
you dont have a front axle on this you have control arms, this sounds like a costly repair i would just look to buy a new car. parts and labor could be 1500 to 3k easy
Mar 12, 2009 | 1996 Pontiac Grand Prix
Peg Perego John Deere Gator HPX Logo
44 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Lawrence Oravetz
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
