Question about Karcher 2500 PSI Pressure Washer
Need manual model #k22400hh honda 5.0 hp. gc160
I need a throttle return spring for my Honda generator model gc160
I found it at this website. Very inexpensive. Dave Delano
http://www.ereplacementparts.com/spring-throttle-return-p-554603.html
Nov 28, 2016 | GC160 160cc Engine - HE GC160LA PHA
Troy-Bilt 2500 psi / Honda GC160. 5.0 hp. No manual. What weight oil? Straight gas or also mixed with oil?
Hello, I have found this for you. The first link is to the engine manual page and, The second is to an owners manual that may be what you need.
hope this helps. :)
http://engines.honda.com/parts-and-support/owners-manuals/gc160
www.e-barnett.com/ProductDocument/10148/2490717_Owners.pdf
Aug 08, 2016 | Honda Garden
I have gas in my oil on my honda 5.0 gc160
Check the engine compression with a compression tester. Most likely you have a blown head gasket.
Sep 19, 2014 | replacehondaengines.com Honda 5.0 Hp...
I am getting gas In the crankcase. engine back fires run only with choke out
float is stuck, bad needle and seat, debris between needle and seat and check air cleaner made sure it not oil or fuel soaked even if dry replace
Sep 18, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
How do I get chemicals to pull through my power washer?
this is a downstream injector which will only activate under low pressure normally a black nozzle with a large hole.A good way of testing is disconnect gun and wand assembly leaving the hose on the ground turn water on let it free flow no need to start engine.You should hear or feel suction out of hose barb if not try starting motor this time but this time you need to grab the hose so that it would not swing and hurt someone with engine running causing more flow should activate it.
Jul 31, 2014 | Honda Horizontal Engine 5 HP OHC 3/4 x...
Wat is de klepspeling van een honda gc160 en hoe weet ik waneer ik de in laat of uitlaat klep kan stellen en wat voor olie moet er in
I have installed d530 sff mother board & processor is 3.0GHZ 800mhz error is showing.
Microcode update Error. Missing or Invalid processor microcode update. Please contact HP company.
D 530 SFF is support to 3.0 GHZ processor ?
Mar 02, 2011 | Pramac EG2800 T Handle Generator With...
Runs fine gc160 wont give me any pressure. i took the pump apart and cleaned it then put it all back together the pressure was intermediate but now nothing at all
if you give us a bit more information we may be able to assist!
is it a pressure washer you are trying to get running.
the number you give is the model number of the honda engine. 5.5 hp honda domestic use.
what does the pump look like. etc
Jul 18, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
