Question about Dryers
, ModelMy Maytag will run but not heat. The igniter coil lights, but the gas does not flow. What may be wrong?
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter will glow red, but the gas will not flow.
    Top Expert:
  • Dryers Master
  • 14,553 Answers
If the igniter works either a valve for gas or the thermocouple are suspect here.
Posted on Nov 07, 2012
Illeagle
  • 525 Answers
SOURCE: dryer wont heat
About all that is left to replace is the flame sensor mounted at 9o'clock on burner flame tube, but I would double check your airflow, This is CRUCIAL to the normal operation of the dryer.
Also, a lint filter with an invisible coating from fabric sheets can cause an airflow disruption, try running without clothes and the filter removed.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
  • 77 Answers
SOURCE: maytag gas dryer, no heat, ignitor wont glow
The machine will check all safety features first. check the overlimit by the burner. It may have a reset. If not, turn power off and check continuity (ohms). Good luck.
Posted on Apr 18, 2009
SOURCE: Maytag Neptune MDG 5500 AWQ heats sporatically
GAS DRYER WORK FOR MINUTES AND THAN STOPS!
Posted on Apr 19, 2009
  • 199 Answers
SOURCE: Dryer does not heat up
do you see the igniter glowing if so it is probably the thermocouple
Posted on Jun 24, 2009
My Maytag gas dryer, Model No, LDG7500AAW will run but not heat. The igniter glows red, but the gas will not flow. What might be wrong?
Replace the 2 burner coils ,if the igniter keeps cycling trying to start the flame. If it doesn't replace the flame sensor mounted on the side of the burner tube.
Nov 06, 2012 | Dryers
Ignition works but doesn't stay on long enough to heat dryer
its either the hi-limit switch is weak on the burner tube,or the gas valve coils on the gas valve are weak and can no longer keep the gas valve open to supply gas,if they appear warm after operation they are most likely bad
May 24, 2012 | Maytag Dryers
I have a older Maytag gas dryer DG612. The igniter comes on the gas lights, runs for about 5 seconds then shuts off. The process repets its self over and over again. It is trying to start but shuts off the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 16, 2010 | Maytag MDG7600AW Gas Dryer
Maytag Neptune gas dryer model nbr MDG 4000 BWW. Dryer runs well but doesnt heat up. ...
A very common problem in a non-heating gas dryer is what is called the gas coils, especially if it will light briefly and then go out and not relight. You should also check the igniter and make sure there are not cracks or burned places, also thermal fuse and thermostat could cause a no-heat.
Dec 01, 2009 | Dryers
Dryer won't heat
i only ask this because you mentioned the loud noise are you almost out of propane, is it a pop sound or ?
Jun 22, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag gas dryer runs but does not heat
If yo smelled gas then the ignitor may not be working.
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it)  It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off.  If the ignitor does not glow then the thermostat is bad.  If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced.   If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
May 30, 2009 | Maytag MDG2600BWW Gas Dryer
Maytag Gas Dryer doesn't heat up
The igniter is the part that ignites the gas in the Maytag gas dryer. Long time a go the dryers use to have a pilots. The pilots where on all the time, even when the dryer was not been use.
This wasted a lot of gas and a new design was needed. That is when the igniter or glow bar as is also known, came to be. A bad igniter could be the reason for your Maytag gas dryer not heating.
The radiant sensor is a small black box that attaches to the combustion funnel. The job of the radiant sensor is to allow the igniter to glow until it is real hot, then it shuts the igniter off and opens the gas valve to start the heating process. A bad radiant sensor could the the reason for your Maytag gas dryer not heating.
The gas valve has two coils or solenoids. These coils job is to open the gas chambers inside of the gas valve.
When one of the coils goes bad, the symptom is that the igniter glows, but the gas valve won't open to let the gas flow through the gas chamber to be ignited.
A bad set of coils could be the reason for your Maytag gas dryer not heating.
The hi-limit thermostat is located on top of the combustion funnel, and its job is to open the circuit to the gas valve if the airflow to the dryer is restricted for any reason.
The cycling thermostat is use to control the temperature inside of the dryer. It is factory preset at 155 degree, in other words it will open the circuit to the gas valve when the temperature reaches 155 degrees.
This thermostat is opening and closing all the time the dryer running. A bad cycling thermostat could be the reason for your Maytag gas dryer not heating.
The timer is the part that direct the electricity to the other parts in the dryer. This part works very hard and the contacts wear out and some times they burn out. If the timer contacts won't close, the dryer will not heat.
The motor switch is another safety device that only closes the heating circuit when the motor is running. When the motor is not running the circuit of the gas valve is open and the dryer will not heat. A bad motor switch could be the cause for your Maytag gas dryer not heating.
As you could see, there are a lot of parts inside of the dryer that have to be in good working condition for the dryer to produce heat.
May 27, 2009 | Maytag Dryers
Igniter works fine but there is no flame so therefore no heat
Replace the coils on this burner assembly. this will fix this issue you are having at this time.
The coils open and close the valves, which are responsible for gas flow. these coils are damaged.
May 25, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Sep 12, 2008 | Dryers
Open Questions:
Dryers Logo
78 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
