Question about Garmin eTrex Legend GPS Receiver
Thumbstick not working
I got an eTrex Legend at a yard sale, and after using it for about a day, the thumbstick only wants to go up and down, not left and right. Anybody have any ideas about this?? thanks...
  • bdinmt Nov 14, 2007
    I have had the same problem occasionally.  My GPS is around 2 yrs old.  turning the GPS off/on, tapping/hitting it, or just giving it time has so far fixed the problem, but i would hate to be in a situation where I really needed the GPS to work, and have the thumbstick not work!  I have also started to have problems with the screen not working (blank, or a vertical line) similar to other people.
Mine wouldn't go right and after checking the ribbon cable, it still wouldn't work. I took alcohol and put a small amount on a cotton swab and worked it into the switch. I exercised the switch probably 20 times and they blew out the alcohol. Waited an our to check it out and it worked. I've been using it the rest of the day and it is working good so far.
Posted on Jun 26, 2011
Hi
there is no cable ribbon cable in the legend the problem is the thumb cover.
I have the same problem
I stripped the device and everything works fine.
Put the front cover on and it breaks again.
the front thumb cover is a little bigger than it should be.
i need to source a replacement one but not sure from where
Posted on Jul 06, 2008
When I had this problem, an update of the firmware was all it needed.
Posted on Jun 17, 2008
I have had the same problem on occasion. Usually turning the unit off and starting it up again fixes it, OR using the side toggle button to page through a screen or two, then try the thumbstick. I'm not certain it's a hardware problem or a software one - I won't take the unit apart. It hasn't happened to me in a while.
Through this site I just realized I was running an outdated version (2.33) downloaded 3.9 moments ago (thank you!).
Guess we'll see if that thumbstick problem goes away with the upgrade.
Posted on Jun 09, 2008
I was able to solve my sticky thumbstick with a nice firm whack. If the problem returns, I will break it down and check the ribbon cable
Posted on Oct 21, 2007
More than likely just a ribbon cable has come loose. See here.... http://tinyurl.com/2pstqk
Posted on May 27, 2007
Garmin etrex 12 channel gps, screen very dim contrast with new batteries
For the Etrex Legend you can click the page (top right hand) button till you get the main menu, select setup then display. Point the click stick down until the bar on the left is highlighted. You can then move the bar up and down until you get the contrast you want. You could first try clicking the square near the top right and selecting restore defaults, but if the default contrast is not to your liking then you can change it using the bar.
It is probably similar on related models such as the Venture or Vista, if in doubt check your manual.
Dec 30, 2010 | Garmin eTrex Legend GPS Receiver
The Main Menu on my Garmin eTrex Legend HCx has mostly disappeared. The only icons left are Mark, Setup, Proximity, Games. I've tried removing the batteries for a while, but that doesn't do anything....
Have you tried re-seating your micro-SD card to see if that clears up the problem? Sometimes the card unseats itself and the map data loss causes some of the icons to disappear. Reinsert the card, restart the unit and see if this fixes the problem. If not, come back and tell us and we'll see what else it might be.
Jun 17, 2010 | Garmin eTrex Legend GPS Receiver
Etrex legend joystick problems
could be the hardware switch itself
Oct 05, 2017 | Garmin eTrex Legend GPS Receiver
Etrex legend has stopped picking up satalites.
I have had this problem occasionally and if you use Restore Defaults it appears to fix it. Using the front button go to Main Menu, Setup, System, move left and press the button button. Before I did this I just used to leave it a few weeks and it would suddenly be working again.
HTH
Peter
Mar 04, 2009 | Garmin eTrex Legend Cx GPS Receiver
Map down load
You can view segments of the maps at the Garmin site and it will show you how much detail there is.
Go to http://www8.garmin.com/cartography/mapSource/topous.jsp#
and on the far right side of the page, you'll see a link to Mapsource Map Viewer Topo USA 2008. Click on that and zoom in to your area.
Yes, you can download the map segments to your unit.
Sep 09, 2008 | Garmin eTrex Legend GPS Receiver
How to enter waypoints
Press and hold the thumbstick on the front right beside where it says Etrex then the waypoint screen will pop up and allow you to name it etc.
Aug 29, 2008 | Garmin eTrex Vista GPS Receiver
Need details of internet setting of k220
hello i need the solution to use the garmin etrex legend gps .
Feb 12, 2008 | Garmin eTrex Legend GPS Receiver
Garmin etrex legend
I had this problem today, updated the software, now the unit seems to be working perfectly. The unit "crashes" (single line down screen center) as soon as it get enough satelites to work with WAAS.
Go to Garmin site for software updates. Download and install the WebUpdater. Once or unit is hooked up to your computer and you have internet access, the software will download and update your GPS with the latest software fixes. I had software Version 3.7. For the Legend, Version 3.9 fixes the problems with WAAS.
Jan 04, 2008 | Garmin eTrex Legend GPS Receiver
Garmin eTrex Legend GPS Receiver Logo
288 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
