Epson projector h328b tech information
How to operate
The indicator of temperature is red, the indicator of the bulb is off and the fan after 3 o 5 minutes
PowerLite 7800p Multimedia Projector - Epson
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...oid...
EpsonPowerLite 7800p Multimedia Projector. Support ... Indicator Light, Status, Description... Temperature, Red, The projector is overheating, which turns the lamp off ...
PowerLite 735c Multimedia Projector - Epson
EpsonPowerLite 735c Multimedia Projector ... Indicator Light, Status, Description ...Lamp/Temperature, Red, The projector is overheating, which turns the lamp off ...
Maintenance Indicators - ManualsLib
www.manualslib.com > ... > Notevision PG-F212X > Operation manual
The warning lights (power indicator, lamp indicator and temperature warning... ... Redon. Normal (Standby). Green on. Normal (Power on). Red blinks. Abnormal ... Sharpmultimedia projector model xg-mb67x-l operation manual (71 pages).
Dec 14, 2015 | Office Equipment & Supplies
Connect epson projector laptop
This should be incredibly easy. You don't really need to know anything; this is something that Epson should have an automated solution for. But it's going to require YOU to put forth the effort to actually search for the answer. Just log onto the Epson site and actually search for the answer. An Epson Tech should be available to assist you if you need help. And the tech should be able to actually take control of your desktop, after you download a small file from them, and fix the error for you
May 05, 2014 | Samsung Computers & Internet
We have an Epson Powelite projector mounted in a classroom and just recently it is projecting everything with a purple tint to it. Before that the colors were not as vivid as when we first installed it. ...
An image is produced in these projectors by passing color through three different LCD panels. One is a Red, one a blue, and the last one a purple. It sounds like the green panel is damaged. The only way to tell is to take it to an Epson authorized service center.
Mar 08, 2011 | Epson - PowerLite S1+ Multimedia Projector
My Epson PowerLite 1725 projector has a wide green bar displayed in the middle of the screen with a purple shadow on its right. Do you think a bulb replacement would fix it?
im afraid that sounds like some dead pixels. and if thats the case then no a bulb wont fix it. call epson tech support and see if they will replace it for free.
Mar 05, 2011 | Canon LV-LP12 Projector Lamp for LV-S1,...
Projector will not power up. Temperature and lamp lights are displayed red.
I'm sorry to inform you that there is an internal error in the projector. Turn the projector off and unplug it. Contact Epson for help.
Feb 27, 2011 | Epson PowerLite® 83c LCD Projector
Projector will not turn on. Lamp light displays red and temperature light displays red.
My EPSON Powerlite 730c projector doesn't power up
epson will not sell parts to anyone who is not an authorized service center. sorry. if you can get the part from an asc, then you can replace it.
Aug 06, 2009 | Epson POWER SUPPLY UNIT: POWERLITE 730C...
Epson Powerlite 1815p screen projector - DVD playback video jerkiness when there is motion in the video
I am assuming that the DVD plays normally on the display of the Dell 745.
Then the issue(s) may be with the:
1. Networking configuration/set-up of the Dell and/or the Epson;
2. ethernet cable;
3. configuration/set-up of the projector or the Epson itself.
A couple of things you can try:
1. Optimize your networking throughput.
1.1 Increase your PCI Latency Timer to 128 or 255 in the Dell's BIOS/CMOS setup (if present);
1.2 Try running DRTCP.exe and/or TCPOptimizer.exe appropriate to the Dell's OS;
1.3 Disable all other networking activities on the Dell. This may include auto updates, security/antivirus checks, etc. while running the DVD;
1.4 Slim down Dell's startup programs to bare minimum;
1.5 Increase your OS' swap file to roughly double your onboard memory
2. Try running a hub midway between the Dell and the Epson.
3. Verify that it is not the Epson that is problematic by playing a video source to the projector’s Video or S-Video port. If it is, then you have narrowed down the problem to the playing capability of the Epson.
Alternately if all else fails, perhaps you can try using:
1. a DVD player to the projector’s Video or S-Video port; and/or
2. a USB external DVD drive or a CompactFlash card (with a copy of the movie) direct to the 1815p
while settling the main issue.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 07, 2008 | Office Equipment & Supplies
313 people viewed this question
jasbo
jasbo
