In the middle washing cycle machine stops and flashes lE
  • 3 Answers
SOURCE: washing machine stops in middle of cycle
This problem used to happen to me with an older washer. It also had a buzzer as well as a flashing light.
I discovered it was the "off-balance" warning.
Next time, try shifting the clothes around so that all the weight isn't on one side of the washer drum
Posted on Feb 09, 2008
IFIXALL
  • 868 Answers
SOURCE: Samsung washing machine won't complete cycle
If it is shutting off when its in the spin cycle than you either have a unbalanced load or a problem in the shocks that will trigger a false shut off in the spin cycle.Let me know what cycle it's shutting off in.Also if you can catch it right when it shuts off , then immediately try to turn it back on ,if it comes on without hesitation then you can rule out a failing motor .
Posted on Jul 13, 2008
SOURCE: Washer stops with 'LE'
Most likely lack of flow in drain water. Pump inlet could be restricted. I'm guessing it must be sudding up in the rinse cycle and shuts down when it spins up... This is from all the water in the tub.
1. pull the access door on the lower left. You will need a blade (flat) head screw driver for this.
2. You should see a hose. and a knob. Get a small bucket, or 1L soda bottle. Pinch the hose, pull the cap and let the hose drain the water. You might have to pinch the hose and cap it if your bucket gets too full so you can empty it. If you skip this and just open the pump trap, be ready for water to come out, unless it is the inlet port of the pump housing that is blocked
3. After the water is out, you can open the knob for the trap to the pump housing.
4. Make sure the trap is clean. If it isn't, then this is most likely your problem. If it's clean then you want to look into the pump housing before putting the trap back in. Use a flash light. I found a bottle cap ontime holding back the water, when i pushed it water came gushing out.
5. If you can't see a block from this method, either of the follow could be the problem.
A. Pump motor not working or power not starting the pump motor.
B. inlet or outlet hose have a major restriction or blocked.
In this case it will come down to fixing it yourself or calling someone.
Posted on Aug 26, 2008
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
  • 14 Answers
SOURCE: Samsung J1455AV: Washing cycle does not complete and then stops
go back to where you bought it and have the engineer look at it might have been faulty when bought.
Posted on Jul 07, 2009
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
My LG washer is flashing LE and won't contiue the
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Sep 06, 2009 | Washing Machines
Amana nfw7200 washer stopped in middle of cycle and is flashing ''nd''
is it full of water? if so there is a drain problem and may have to clean out the pump
Aug 23, 2009 | Maytag NFW7200TW Front Load Washer
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
LG Washer / WM2487H*MA...2 days old. Wash setting...."Bulky/Large QUESTION:::When attempting to select additional "wash options" from the Option Buttons panel, I keep getting a display...
My LG Tromm washing machine just stopped in the middle of the cycle, It started flashing the letters LE, what does that mean. I have had it for 4 years and this has never happened.
Jul 27, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
